    Plugin SJ Add DC Attribut
    28 Posts 9 Posters 8.4k Views 8 Watching
      JIA6598
      @simjoubert said:
      @jia6598 said:
      Thanks for the useful program. When I add the attribute, the group rotates 90 degrees
      Hello,
      If the rotation is abnormal, tell me more!
      To find out if it's a bug and if it can be reproduced!
      Please attach your model as an attachment. And if it's confidential, you can send me a download link, WeTransfer or similar in private message.
      Have a good day
      Hey
      I use Profile Builder 3
      1. I draw the element in the direction of the red line
      2. I cut the element with the section tool
      3. After that, I use Add DC to add an attribute
      4. The element turns, in the direction of the green line.
      But
      ... If I draw the PB3 element in the direction of the green line, the element does not rotate.
      But ++
      I normally draw a group or component
      The program works flawlessly
      The program is useful and I found many uses for it.
      I hope there is a solution to this
      thank you
      • simjoubertS
        simjoubert
        @jia6598 said:
        @simjoubert said:
        Hello,
        Have a good day
        Hey
        But
        But ++
        thank you
        Good evening,
        Thank you for this additional information.
        I will try to reproduce this bug, and fix it quickly.
        Glad to read that you find many uses for the plugin.
        Do not hesitate to like the plugin in the plugin store and on my page.
        • simjoubertS
          simjoubert
          Hello
          Publication of a corrective version
          https://www.sketchup.simjoubert.com/images/Files/plugin/Add_DC_Attribut/Logo SJ ADD DC ATTRIBUTE200px.png
          last version SJ Add DC Attribute 0.3.2 MAJ of 25/09/2022
          Download link:https://www.sketchup.simjoubert.com/my-plugins/sj-add-dc-attribute.html
          or on the Plugin Store https://sketchucation.com/plugin/2537-sjadddcattribute
          **Release Notes: **
          V.0.3.2 2022/09/25
          Fixed a bug on the transform that rotated instances, if they didn't have a rotation attribute and were rotated around an axis
          • P
            pibuz
            Hi Simon! I recently discovered you plugin and it's brilliant!!! Thanks a lot!
            Although I'd like to suggest you a couple upgrades, to improve usability even more.
            1. First thing, the possibility to save a set of favourite attributes to be used in other skp models. This is very convenient when you have a set of fixed attributes you always want to load for any of your components. Could be useful to name the set so the plugin can load the relative attributes
            2. Second thing: the possibility to add to the selection a set of attributes (the thing we saved at step 1) so that the plugin can import a number of attributes without having to manually select them one by one.
            Tell me what you think! Thanks again a lot!
            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
            • simjoubertS
              simjoubert
              Hello Pibuz
              I am delighted to read that this plugin is useful to you! 😄
              Your suggestions join the evolution plan of the plugin for the next major version. With the introduction of group of favorites:
              • The import-export of its groups.
              • One-click addition of an attribute group to a selection.
              We will have to be a little patient, but this is a reasonable objective.
              In the meantime, I'm counting on you to promote the plugin, and buy me a coffee! 😉
              Have a nice week end
              • simjoubertS
                simjoubert
                Hello
                last version SJ Add DC Attribute 0.3.3 MAJ of 24/01/2023
                **Release Notes: **
                V.0.3.3 2023/01/24
                Fixed a bug that left the progress bar in an endless loop in some cases.
                • simjoubertS
                  simjoubert
                  Hello
                  For those who have downloaded the plugin in version 0.3.3 before 10:15 a.m. on January 24, 2023 (Paris time)
                  Please download the file again and reinstall it.
                  A file was missing!
                  All my excuses ! 😳
                  Simon
                    andreimd87
                    very useful addon. but it does not work for me. or maybe i an missing something. i set an atribute NAME and the value. and after aplying there is still nothing in the component atributes. 😕
                    • simjoubertS
                      simjoubert
                      @andreimd87 said:
                      very useful addon. but it does not work for me. or maybe i an missing something. i set an atribute NAME and the value. and after aplying there is still nothing in the component attributes. 😕
                      Good evening
                      To create a new attribute or edit an existing attribute:
                      Select an existing attribute in one of the lists (Attribute of a component of the selection, or an attribute placed in favorites, or an attribute of the list to create, modify) or create it from scratch.
                      Once the values have been entered, it must be added to the list of attributes to create/modify. The attribute appears in the list, in case of duplicate an error message appears asking you for confirmation before overwriting the existing one.
                      At this point, nothing is changed in the components of the selection. It is only after clicking on the button create the attributes of the list that the components will receive the new attribute or its new values in case of modification. You can thus create several attributes at once.
                      https://www.simjoubert.com/biblio3D/gif/SketchUp_giD89sPb5K.gif
                        sebelus13
                        Salut simjoubert,
                        i think your plughin is very very good, I will use it for shure,
                        my wish would be that you add a funktionality not only to add new attributes with new values or strings, but also change existing strings or values in existing attributes, that would be really nice for me.
                        A second thing would be nice: Add the possibility to assign a sequential number additionaly to the text, perhaps like String&seyuentialnumber---> perhaps EL_1 ...EL_2...EL_3 and so on
                        Si vous le souhaitez, je peux vous aider à traduire en allemand...
                        Cordialement
                        sebelus13
                          mea10 Newcomers
                          Re: Plugin SJ Add DC Attribut
                          Hallo,
                          it's possible that this plug in doesn't work at Mac OS (M1) ?
                          We can install it but the massage window ist empty.
                          Alrich
                          B 1 Reply Last reply
                          • B
                            bruorlando @mea10
                            Hallo,
                            We can install it, but the message window is empty.
                            Alrich
                            Same problem here… I would love to use this plugin… It's exactly what I've been searching for!
                            Bruno!
                            • 2 / 2
