    Plugin SJ Add DC Attribut
    28 Posts 9 Posters 8.0k Views 8 Watching
    • simjoubertS
      simjoubert
      SJ Add DC Attribute is a plugin for Sketchup that allows you to create or modify one or more attributes common to a selection of groups or components.
      This video shows you how to duplicate an existing attribute in a component, and create it on a selection of groups or component that did not have this attribute.
      You can find more information on my website http://www.sketchup.simjoubert.com
      Download from my site or the Sketchucation PluginStore: https://sketchucation.com/plugin/2537-sjadddcattribute
      • simjoubertS
        simjoubert
        SJ Add DC Attribute - Save an existing attribute to the list of favorite attributes.
        This video shows you how to save an existing attribute to the list of favorite attributes.
        This list is saved in the model. Later, you can reuse this attribute and apply it to other groups or components.
        SJ Add DC Attribute - Add description attribute with HTML tags
        This video shows you how to create a description attribute with HTML formatting. When you expand the input field by double-clicking, a toolbar is displayed if you edit a description or summary. It allows to inject HTML tags at the location of the cursor.
        • simjoubertS
          simjoubert
          SJ Add DC Attribute - Import option list from CSV file
          This video shows you how to import a list of options for an attribute from a CSV file.
          • simjoubertS
            simjoubert
            Hello
            Publication d'une version corrective
            https://www.sketchup.simjoubert.com/images/Files/plugin/Add_DC_Attribut/Logo SJ ADD DC ATTRIBUTE200px.png
            Dernière version sj Add DC Attribute 0.3.1 MAJ du 12/09/2022
            Lien de téléchargement :https://www.sketchup.simjoubert.com/my-plugins/sj-add-dc-attribute.html
            ou sur le PluginStore https://sketchucation.com/plugin/2537-sjadddcattribute
            **Notes de versions : **
            V.0.3.1 2022/09/12
            • Correction d'affichage des longues listes dans la fenêtre d'import CSV qui obligeaient à scroller la fenêtre modale.
            • Correction d'affichage des longues listes d'options qui masquait les boutons dans certain cas.
            • Correction du remplissage du formulaire après avoir sélectionné un attribut dans les listes.
            • Les unités par défaut pour les longueurs sont définies selon l'unité du modèle.
              JIA6598
              Thanks for the useful program. When I add the attribute, the group rotates 90 degrees
                JIA6598
                Thanks for the useful program. When I add the attribute, the group rotates 90 degrees 😕
                  JIA6598
                  Addition inverts the group
                    JIA6598
                    Addition inverts the group 😕
                    • simjoubertS
                      simjoubert
                      Hello,
                      If the rotation is abnormal, tell me more!
                      To find out if it's a bug and if it can be reproduced!
                      Please attach your model as an attachment. And if it's confidential, you can send me a download link, WeTransfer or similar in private message.
                      Have a good day
                        JIA6598
                        @simjoubert said:
                        Hello,
                        Have a good day
                        Hey
                        I use Profile Builder 3
                        1. I draw the element in the direction of the red line
                        2. I cut the element with the section tool
                        3. After that, I use Add DC to add an attribute
                        4. The element turns, in the direction of the green line.
                        But
                        ... If I draw the PB3 element in the direction of the green line, the element does not rotate.
                        But ++
                        I normally draw a group or component
                        The program works flawlessly
                        The program is useful and I found many uses for it.
                        I hope there is a solution to this
                        thank you
                        • simjoubertS
                          simjoubert
                          @jia6598 said:
                          @simjoubert said:
                          Hello,
                          Have a good day
                          Hey
                          But
                          But ++
                          thank you
                          Good evening,
                          Thank you for this additional information.
                          I will try to reproduce this bug, and fix it quickly.
                          Glad to read that you find many uses for the plugin.
                          Do not hesitate to like the plugin in the plugin store and on my page.
                          • simjoubertS
                            simjoubert
                            Hello
                            Publication of a corrective version
                            last version SJ Add DC Attribute 0.3.2 MAJ of 25/09/2022
                            Download link:https://www.sketchup.simjoubert.com/my-plugins/sj-add-dc-attribute.html
                            or on the Plugin Store https://sketchucation.com/plugin/2537-sjadddcattribute
                            **Release Notes: **
                            V.0.3.2 2022/09/25
                            Fixed a bug on the transform that rotated instances, if they didn't have a rotation attribute and were rotated around an axis
                            • P
                              pibuz
                              Hi Simon! I recently discovered you plugin and it's brilliant!!! Thanks a lot!
                              Although I'd like to suggest you a couple upgrades, to improve usability even more.
                              1. First thing, the possibility to save a set of favourite attributes to be used in other skp models. This is very convenient when you have a set of fixed attributes you always want to load for any of your components. Could be useful to name the set so the plugin can load the relative attributes
                              2. Second thing: the possibility to add to the selection a set of attributes (the thing we saved at step 1) so that the plugin can import a number of attributes without having to manually select them one by one.
                              Tell me what you think! Thanks again a lot!
                              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                              • simjoubertS
                                simjoubert
                                Hello Pibuz
                                I am delighted to read that this plugin is useful to you! 😄
                                Your suggestions join the evolution plan of the plugin for the next major version. With the introduction of group of favorites:
                                • The import-export of its groups.
                                • One-click addition of an attribute group to a selection.
                                We will have to be a little patient, but this is a reasonable objective.
                                In the meantime, I'm counting on you to promote the plugin, and buy me a coffee! 😉
                                Have a nice week end
                                • simjoubertS
                                  simjoubert
                                  Hello
                                  last version SJ Add DC Attribute 0.3.3 MAJ of 24/01/2023
                                  **Release Notes: **
                                  V.0.3.3 2023/01/24
                                  Fixed a bug that left the progress bar in an endless loop in some cases.
                                  • simjoubertS
                                    simjoubert
                                    Hello
                                    For those who have downloaded the plugin in version 0.3.3 before 10:15 a.m. on January 24, 2023 (Paris time)
                                    Please download the file again and reinstall it.
                                    A file was missing!
                                    All my excuses ! 😳
                                    Simon
                                      andreimd87
                                      very useful addon. but it does not work for me. or maybe i an missing something. i set an atribute NAME and the value. and after aplying there is still nothing in the component atributes. 😕
                                      • simjoubertS
                                        simjoubert
                                        @andreimd87 said:
                                        very useful addon. but it does not work for me. or maybe i an missing something. i set an atribute NAME and the value. and after aplying there is still nothing in the component attributes. 😕
                                        Good evening
                                        To create a new attribute or edit an existing attribute:
                                        Select an existing attribute in one of the lists (Attribute of a component of the selection, or an attribute placed in favorites, or an attribute of the list to create, modify) or create it from scratch.
                                        Once the values have been entered, it must be added to the list of attributes to create/modify. The attribute appears in the list, in case of duplicate an error message appears asking you for confirmation before overwriting the existing one.
                                        At this point, nothing is changed in the components of the selection. It is only after clicking on the button create the attributes of the list that the components will receive the new attribute or its new values in case of modification. You can thus create several attributes at once.
                                        https://www.simjoubert.com/biblio3D/gif/SketchUp_giD89sPb5K.gif
                                          sebelus13
                                          Salut simjoubert,
                                          i think your plughin is very very good, I will use it for shure,
                                          my wish would be that you add a funktionality not only to add new attributes with new values or strings, but also change existing strings or values in existing attributes, that would be really nice for me.
                                          A second thing would be nice: Add the possibility to assign a sequential number additionaly to the text, perhaps like String&seyuentialnumber---> perhaps EL_1 ...EL_2...EL_3 and so on
                                          Si vous le souhaitez, je peux vous aider à traduire en allemand...
                                          Cordialement
                                          sebelus13
                                            mea10 Newcomers
                                            Re: Plugin SJ Add DC Attribut
                                            Hallo,
                                            it's possible that this plug in doesn't work at Mac OS (M1) ?
                                            We can install it but the massage window ist empty.
                                            Alrich
                                            B 1 Reply Last reply
