    Plugin SJ Add DC Attribut
    28 Posts 9 Posters 8.4k Views 8 Watching
    • simjoubertS
      simjoubert
      Hello
      Publication d'une version corrective
      https://www.sketchup.simjoubert.com/images/Files/plugin/Add_DC_Attribut/Logo SJ ADD DC ATTRIBUTE200px.png
      Dernière version sj Add DC Attribute 0.3.1 MAJ du 12/09/2022
      Lien de téléchargement :https://www.sketchup.simjoubert.com/my-plugins/sj-add-dc-attribute.html
      ou sur le PluginStore https://sketchucation.com/plugin/2537-sjadddcattribute
      **Notes de versions : **
      V.0.3.1 2022/09/12
      • Correction d'affichage des longues listes dans la fenêtre d'import CSV qui obligeaient à scroller la fenêtre modale.
      • Correction d'affichage des longues listes d'options qui masquait les boutons dans certain cas.
      • Correction du remplissage du formulaire après avoir sélectionné un attribut dans les listes.
      • Les unités par défaut pour les longueurs sont définies selon l'unité du modèle.
        JIA6598
        Thanks for the useful program. When I add the attribute, the group rotates 90 degrees
          JIA6598
          Thanks for the useful program. When I add the attribute, the group rotates 90 degrees 😕
            JIA6598
            Addition inverts the group
              JIA6598
              Addition inverts the group 😕
              • simjoubertS
                simjoubert
                Hello,
                If the rotation is abnormal, tell me more!
                To find out if it's a bug and if it can be reproduced!
                Please attach your model as an attachment. And if it's confidential, you can send me a download link, WeTransfer or similar in private message.
                Have a good day
                  JIA6598
                  @simjoubert said:
                  Hello,
                  Have a good day
                  Hey
                  I use Profile Builder 3
                  1. I draw the element in the direction of the red line
                  2. I cut the element with the section tool
                  3. After that, I use Add DC to add an attribute
                  4. The element turns, in the direction of the green line.
                  But
                  ... If I draw the PB3 element in the direction of the green line, the element does not rotate.
                  But ++
                  I normally draw a group or component
                  The program works flawlessly
                  The program is useful and I found many uses for it.
                  I hope there is a solution to this
                  thank you
                  • simjoubertS
                    simjoubert
                    @jia6598 said:
                    @simjoubert said:
                    Hello,
                    Have a good day
                    Hey
                    But
                    But ++
                    thank you
                    Good evening,
                    Thank you for this additional information.
                    I will try to reproduce this bug, and fix it quickly.
                    Glad to read that you find many uses for the plugin.
                    Do not hesitate to like the plugin in the plugin store and on my page.
                    • simjoubertS
                      simjoubert
                      Hello
                      Publication of a corrective version
                      last version SJ Add DC Attribute 0.3.2 MAJ of 25/09/2022
                      Download link:https://www.sketchup.simjoubert.com/my-plugins/sj-add-dc-attribute.html
                      or on the Plugin Store https://sketchucation.com/plugin/2537-sjadddcattribute
                      **Release Notes: **
                      V.0.3.2 2022/09/25
                      Fixed a bug on the transform that rotated instances, if they didn't have a rotation attribute and were rotated around an axis
                      • P
                        pibuz
                        Hi Simon! I recently discovered you plugin and it's brilliant!!! Thanks a lot!
                        Although I'd like to suggest you a couple upgrades, to improve usability even more.
                        1. First thing, the possibility to save a set of favourite attributes to be used in other skp models. This is very convenient when you have a set of fixed attributes you always want to load for any of your components. Could be useful to name the set so the plugin can load the relative attributes
                        2. Second thing: the possibility to add to the selection a set of attributes (the thing we saved at step 1) so that the plugin can import a number of attributes without having to manually select them one by one.
                        Tell me what you think! Thanks again a lot!
                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                        • simjoubertS
                          simjoubert
                          Hello Pibuz
                          I am delighted to read that this plugin is useful to you! 😄
                          Your suggestions join the evolution plan of the plugin for the next major version. With the introduction of group of favorites:
                          • The import-export of its groups.
                          • One-click addition of an attribute group to a selection.
                          We will have to be a little patient, but this is a reasonable objective.
                          In the meantime, I'm counting on you to promote the plugin, and buy me a coffee! 😉
                          Have a nice week end
                          • simjoubertS
                            simjoubert
                            Hello
                            last version SJ Add DC Attribute 0.3.3 MAJ of 24/01/2023
                            **Release Notes: **
                            V.0.3.3 2023/01/24
                            Fixed a bug that left the progress bar in an endless loop in some cases.
                            • simjoubertS
                              simjoubert
                              Hello
                              For those who have downloaded the plugin in version 0.3.3 before 10:15 a.m. on January 24, 2023 (Paris time)
                              Please download the file again and reinstall it.
                              A file was missing!
                              All my excuses ! 😳
                              Simon
                                andreimd87
                                very useful addon. but it does not work for me. or maybe i an missing something. i set an atribute NAME and the value. and after aplying there is still nothing in the component atributes. 😕
                                • simjoubertS
                                  simjoubert
                                  @andreimd87 said:
                                  very useful addon. but it does not work for me. or maybe i an missing something. i set an atribute NAME and the value. and after aplying there is still nothing in the component attributes. 😕
                                  Good evening
                                  To create a new attribute or edit an existing attribute:
                                  Select an existing attribute in one of the lists (Attribute of a component of the selection, or an attribute placed in favorites, or an attribute of the list to create, modify) or create it from scratch.
                                  Once the values have been entered, it must be added to the list of attributes to create/modify. The attribute appears in the list, in case of duplicate an error message appears asking you for confirmation before overwriting the existing one.
                                  At this point, nothing is changed in the components of the selection. It is only after clicking on the button create the attributes of the list that the components will receive the new attribute or its new values in case of modification. You can thus create several attributes at once.
                                  https://www.simjoubert.com/biblio3D/gif/SketchUp_giD89sPb5K.gif
                                    sebelus13
                                    Salut simjoubert,
                                    i think your plughin is very very good, I will use it for shure,
                                    my wish would be that you add a funktionality not only to add new attributes with new values or strings, but also change existing strings or values in existing attributes, that would be really nice for me.
                                    A second thing would be nice: Add the possibility to assign a sequential number additionaly to the text, perhaps like String&seyuentialnumber---> perhaps EL_1 ...EL_2...EL_3 and so on
                                    Si vous le souhaitez, je peux vous aider à traduire en allemand...
                                    Cordialement
                                    sebelus13
                                      mea10 Newcomers
                                      Re: Plugin SJ Add DC Attribut
                                      Hallo,
                                      it's possible that this plug in doesn't work at Mac OS (M1) ?
                                      We can install it but the massage window ist empty.
                                      Alrich
                                      B 1 Reply Last reply
                                      • B
                                        bruorlando @mea10
                                        Hallo,
                                        We can install it, but the message window is empty.
                                        Alrich
                                        Same problem here… I would love to use this plugin… It's exactly what I've been searching for!
                                        Bruno!
