    [Plugin] ImageTrimmer
    364 Posts 58 Posters 337.7k Views 58 Watching
    • T
      Tallkoala
      I did try that (with a couple of different converters) but the image I got didn't have clean lines. I tried exploding the resulting model and then making joining lines in shapes I wanted to be solid but I couldn't get it to work.
      See attached screenshots and close up...
        With the images you've supplied, Image Trimmer isn't going to be much better. It's tying up my computer for a long time. I may have to kill it so I can get some other stuff done.
        • T
          Tallkoala
          ok no problem, thanks for trying anyway...
          • Didier BurD
            Didier Bur
            Hi all,
            Again about my problem (Java not working as expected):
            Here is the message I get after jar is launched:
            Error; #<Errno;;ENOENT; No such file or directory @ rb_sysopen - C;\Users\DBUR\Documents\TrimmedImages\Penture_033[Edges].dat>
            C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;277;in `readlines'
            C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;277;in `make_edges'
            C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;201;in `process_image'
            C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;170;in `initialize'
            C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;834;in `new'
            C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;834;in `block in <top (required)>'
            I have the png image file in the model's folder, but no 'Penture_033[Edges].dat' file πŸ˜•
            All the rights (read/write etc...) are set for this folder.
            As it is said in the comments in ImageTrimmer.rb:
            There is a temporary 'data' file 'StandingMan1[Edges].dat' which contains
            '01' data used to construct the Sketchup Edges - this should be auto-erased
            whatever option you choose.
            Is this file a template, sort of ?
            Regards,
            DB
            • 15
            • 16
            • 17
            • 18
            • 19
            • 19 / 19
