    [Plugin] ImageTrimmer
    364 Posts 58 Posters 357.7k Views 58 Watching
    • Didier BurD
      Didier Bur
      Many thanks Dave
      OMG if only I could find the culprit ๐Ÿ˜ฎ
      DB
        You're quite welcome.
        I wish I knew what it was that is causing the problem. Seems like somewhere there's something missing.
        BTW, how are you using that hinge? Is a flat representation of it enough? I was doodling and just traced the image, mostly with FredoSpline and got this:
        Still needs the holes and a texture but I think it would be cleaner than a component made from the trimmed image. The images is such low res that it would create a very rough object with a lot of unneeded geometry.
        • Didier BurD
          Didier Bur
          Hi Dave,
          I still wonder what's wrong with Java on my system. Currently the jar file calls the javaw.exe executable. I've tried to associate java.exe as well but no luck. What is yours ?
          These hinges are used on doors of a 14th medieval castle reconstitution. A flat hinge isn't accurate enough because the castle will be visitable in a Twinmotion Presenter, so I need quite a lot of details for every element.
          Some hinges are quite simple but others more complex and can need one hour to draw manually.
          Again, thanks for your help ๐Ÿ‘
          DB
            On my PC JAR files open [run] with Java.exe
            There's no problem... did you try reinstalling Java from Oracle ?
            • T
              Tallkoala
              PLEASE BEWARE !!!
              I tried installng Java again from the link you sent and itโ€™s totally crashed my laptop (blue sceen bitlocker error); Iโ€™ve taken it to a specialist this afternoon and Iโ€™m going to have to make a fresh install of the operating system so will lose all my files.
              This is going to cost me significant time and money.
              Please be aware before recommending anyone else to do this.
              I have a Dell XPS 17 2021 model.
              • Didier BurD
                Didier Bur
                Hi TIG,
                Yes I re-installed Java from this page:
                https://www.java.com/fr/download/manual.jsp
                I downloaded the 'Windows hors ligne' version:
                Regards,
                DB
                  I have the Java EN version, but otherwise it's the exact same www link...
                  • T
                    Tallkoala
                    Would anyone be kind enough to help convert this PNG file into a skp model so I can give it some thickness. I have tried several times to install the plugin and download Java but with no success.
                    I just need this one image converting (The white background should be removed).
                    If you anyone can do it for me I would be much appreciate it.
                      I'll do it but do you have a higher res version?
                      • T
                        Tallkoala
                        Thats great, thanks.
                        This is a link to where the file is stored, its the highest res I have....
                        (app.box.com)
                          We'll see what we get. It's still not a very high res image so I expect it'll be pretty rough. Might make more sense to usea raster to vector converter to generate a .dxf file that you can import into SketchUp. There are a number of those converters online.
                          • T
                            Tallkoala
                            I did try that (with a couple of different converters) but the image I got didn't have clean lines. I tried exploding the resulting model and then making joining lines in shapes I wanted to be solid but I couldn't get it to work.
                            See attached screenshots and close up...
                              With the images you've supplied, Image Trimmer isn't going to be much better. It's tying up my computer for a long time. I may have to kill it so I can get some other stuff done.
                              • T
                                Tallkoala
                                ok no problem, thanks for trying anyway...
                                • Didier BurD
                                  Didier Bur
                                  Hi all,
                                  Again about my problem (Java not working as expected):
                                  Here is the message I get after jar is launched:
                                  Error; #<Errno;;ENOENT; No such file or directory @ rb_sysopen - C;\Users\DBUR\Documents\TrimmedImages\Penture_033[Edges].dat>
                                  C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;277;in `readlines'
                                  C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;277;in `make_edges'
                                  C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;201;in `process_image'
                                  C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;170;in `initialize'
                                  C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;834;in `new'
                                  C;/Users/DBUR/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/SKMtools/ImageTrimmer.rb;834;in `block in <top (required)>'
                                  I have the png image file in the model's folder, but no 'Penture_033[Edges].dat' file ๐Ÿ˜•
                                  All the rights (read/write etc...) are set for this folder.
                                  As it is said in the comments in ImageTrimmer.rb:
                                  There is a temporary 'data' file 'StandingMan1[Edges].dat' which contains
                                  '01' data used to construct the Sketchup Edges - this should be auto-erased
                                  whatever option you choose.
                                  Is this file a template, sort of ?
                                  Regards,
                                  DB
                                  • 15
                                  • 16
                                  • 17
                                  • 18
                                  • 19
                                  • 18 / 19
