    Spaceship time again!
    111 Posts 9 Posters 6.6k Views 9 Watching
    • ntxdaveN Offline
      ntxdave
      Wow, I would have guessed many more plugins. πŸ‘ πŸ‘Ž
      Press F1...thank me later
      • Bryan KB Offline
        A habit from my old computer without enough power. Keep the model size as low as possible. Find the simplest shape and the least amount of faces while still being believable.
        Update: flared the "flares". This was actually very easy. I selected all the end faces of the flares at once and then used the scale tool to enlarge. It dragged all the faces outward and moved the attached geometry with it.
        • Bryan KB Offline
          It looks different from every angle.
          Still figuring out the greeble for under the bow.
            I am loving where this is heading mate πŸ‘ πŸ‘ πŸ‘
            • Bryan KB Offline
                I can only agree, looks great. πŸ‘
                  Have left someting in your inbox Bryan
                  • Bryan KB Offline
                    Thanks L i am.
                    Updates. So I think this is enough for the front under bow greeble. Any more and it starts taking away from the style/shape. The rods are sensors, not weapons.
                    Also started positioning the letters. That's going to take some time. But I'm fairly close now. Did not have exact font used so this will have to do.
                    • Bryan KB Offline
                      Thanks Mike!
                      • Bryan KB Offline
                        Barring any obvious flaws I may see later, this is it!
                        • Bryan KB Offline
                          Two more views.
                          • Bryan KB Offline
                            One more view.
                              A proper masterpiece you have there mate, great to see the process too. πŸ‘ πŸ‘
                              • Bryan KB Offline
                                I already see some minor changes that need to be made. Nothing major, thank god.
                                • Bryan KB Offline
                                  Another test render. I think it's almost finished. Just need to add the engine exhausts.
                                  • ntxdaveN Offline
                                    ntxdave
                                    Looking good to me. πŸ‘ πŸ‘
                                    • Bryan KB Offline
                                        Its bloody marvelous, you should make some dosh out of it, more than good enough. πŸ‘
                                        • Bryan KB Offline
                                          LOL in the 14 years I've been using SU, I've had two commissioned jobs. Both for basically grocery money. That's why I can't afford a paid version.
                                          I've got a couple of problems with this to fix yet. One is the render texture. I went to render it again and the texture settings on the engines did not fix and I cannot recreate it. I'll need to hard model the style.
                                          The other is the scale of a part. No big deal with either one. Just busy right now.
                                          • Bryan KB Offline
                                            This should do it.
                                            • 5 / 6
