    Spaceship time again!
    111 Posts 9 Posters 12.4k Views 9 Watching
    • Bryan KB
      @mike amos said:
      :thumb: πŸ‘ πŸ‘
      • Bryan KB
        Cleaning up the model. The rear engine pods were a mess.
        Tweaking some proportions. Preparing the lettering. Fiddling with the forward under-hull details.
        • Bryan KB
          Got the rear pods cleaned up. Had some reversed faces as well. All fixed now.
          • ntxdaveN
            ntxdave
            I am impressed with the level of detail you come up with. πŸ‘
            Press F1...thank me later
            • Bryan KB
              Thanks! Just simple shapes, really. Circles, rectangles and then some angles to make it interesting. Offset and Push/Pull here and there. Joint Push/Pull for more complex shapes.
              Oh, I forgot Tools on Surface. I used to do shape intersects, but Tools on Surface is much faster.
              But mostly, just simple shapes.
              • ntxdaveN
                ntxdave
                Wow, I would have guessed many more plugins. πŸ‘ πŸ‘Ž
                • Bryan KB
                  A habit from my old computer without enough power. Keep the model size as low as possible. Find the simplest shape and the least amount of faces while still being believable.
                  Update: flared the "flares". This was actually very easy. I selected all the end faces of the flares at once and then used the scale tool to enlarge. It dragged all the faces outward and moved the attached geometry with it.
                  • Bryan KB
                    It looks different from every angle.
                    Still figuring out the greeble for under the bow.
                    • L
                      I am loving where this is heading mate πŸ‘ πŸ‘ πŸ‘
                      • Bryan KB
                          I can only agree, looks great. πŸ‘
                          • L
                            Have left someting in your inbox Bryan
                            • Bryan KB
                              Thanks L i am.
                              Updates. So I think this is enough for the front under bow greeble. Any more and it starts taking away from the style/shape. The rods are sensors, not weapons.
                              Also started positioning the letters. That's going to take some time. But I'm fairly close now. Did not have exact font used so this will have to do.
                              • Bryan KB
                                Thanks Mike!
                                • Bryan KB
                                  Barring any obvious flaws I may see later, this is it!
                                  • Bryan KB
                                    Two more views.
                                    • Bryan KB
                                      One more view.
                                        A proper masterpiece you have there mate, great to see the process too. πŸ‘ πŸ‘
                                        • Bryan KB
                                          I already see some minor changes that need to be made. Nothing major, thank god.
                                          • Bryan KB
                                            Another test render. I think it's almost finished. Just need to add the engine exhausts.
                                            • 5 / 6
