    Spaceship time again!
    111 Posts 9 Posters 6.6k Views 9 Watching
    • Bryan KB Offline
      A different view. Also setting up the scene. More detail to come.
      Note: this is a very sloppy model. I have things poking into other things and not bothered to intersect and trim. Too many weird angles.
        Looking very promising indeed Bryan, starting to look well tranlated πŸ‘ πŸ‘
        • Bryan KB Offline
          • Bryan KB Offline
            I'm getting there.
              hey bryan I think that is comming out great, and think that materials will be critical to do justice to the model. Am thinking of learning quixel mixer myself, Grunge around the exhausts with heated titanium materials and paint chips would look awsome.
              https://www.youtube.com/watch?v=1cFmXK5T3Hs
              • Bryan KB Offline
                Good suggestion.
                • Bryan KB Offline
                  First test render. Still need to add more detail to the model and I can see I need to adjust the colors just little.
                    πŸ‘ πŸ‘ πŸ‘
                    • Bryan KB Offline
                      @mike amos said:
                      :thumb: πŸ‘ πŸ‘
                      • Bryan KB Offline
                        Cleaning up the model. The rear engine pods were a mess.
                        Tweaking some proportions. Preparing the lettering. Fiddling with the forward under-hull details.
                        • Bryan KB Offline
                          Got the rear pods cleaned up. Had some reversed faces as well. All fixed now.
                          • ntxdaveN Offline
                            ntxdave
                            I am impressed with the level of detail you come up with. πŸ‘
                            Press F1...thank me later
                            • Bryan KB Offline
                              Thanks! Just simple shapes, really. Circles, rectangles and then some angles to make it interesting. Offset and Push/Pull here and there. Joint Push/Pull for more complex shapes.
                              Oh, I forgot Tools on Surface. I used to do shape intersects, but Tools on Surface is much faster.
                              But mostly, just simple shapes.
                              • ntxdaveN Offline
                                ntxdave
                                Wow, I would have guessed many more plugins. πŸ‘ πŸ‘Ž
                                • Bryan KB Offline
                                  A habit from my old computer without enough power. Keep the model size as low as possible. Find the simplest shape and the least amount of faces while still being believable.
                                  Update: flared the "flares". This was actually very easy. I selected all the end faces of the flares at once and then used the scale tool to enlarge. It dragged all the faces outward and moved the attached geometry with it.
                                  • Bryan KB Offline
                                    It looks different from every angle.
                                    Still figuring out the greeble for under the bow.
                                      I am loving where this is heading mate πŸ‘ πŸ‘ πŸ‘
                                      • Bryan KB Offline
                                          I can only agree, looks great. πŸ‘
                                            Have left someting in your inbox Bryan
                                            • 4 / 6
