    Adding thickness to organic shape
    12 Posts 7 Posters 572 Views 7 Watching
      Try Thomthoms Shell
        rv1974
        Or, even better choose more appropriate program
        • BoxB Offline
          From your description I can replicate your issue. This is basically caused by sandbox making a rather messy mesh.
          A better option would be follow me, I'm assuming that all your arcs are the same, that's how they look in your screenshot.
          Here you can see I rotate the circle by half a segment so that when cut to a semicircle the end segments are perpendicular to the shape you want to create. This allows you to use offset to create a profile for your path.
          https://i.imgur.com/MhsrugX.gif
          • ntxdaveN Offline
            ntxdave
            Very nice Box πŸ‘ πŸ‘
            Press F1...thank me later
              I did not know where you were headed for 90% of that .gif.
              That's next level vanilla use!
                Never think and drive
                • BoxB Offline
                  I never know where I'm headed, just make it up as I go.
                  • HornOxxH Offline
                    HornOxx
                    @rich o brien said:
                    ...That's next level vanilla use!
                    πŸ˜† along with chocolate sauce on top!
                    never trust a skinny cook
                      Remember the Kito Raup tricks! 😎
                      • BoxB Offline
                        I thought I would just throw this in here to dispel any witchcraft rumors. What I showed above was just a method for making a semicircle follow me where the segments finish perpendicular to the face, as is needed for follow me to complete the faces horizontally.
                        But it is just half a full circle follow me, albeit half a segment rotated. You can see the difference in this image, the one on the right has vertical faces because of the rotated circle , the one in the middle has sloped last faces either side because it is a split of a full follow me (the gif below) and the one on the left shows what happens if you use a semi circle for follow me. It rotates the beginning and end faces to be perpendicular to the first and last segments.
                        The two things happening offscreen are, Orient faces, and Soften/smooth.
