    2.2k Posts 487 Posters 931.4k Views 492 Watching
    • fredo6F Offline
      @xyhcwu said:
      I used the Fredo tool yesterday and was prompted with an expired license, I selected the purchased license radical file to activate it and it still prompted an expired license, I activated it again and again and ohhhh, Seats running out!
      I come to - https://sketchucation.com/webshop/my-licences.php
      and found no option to release them, please help me release them!!!
      •Seat ID: 93950; HW ID: TH1681976919.0A; Date of activation: 20/04/2023
      •Seat ID: 93961; HW ID: ZO1681976919.0D; Date of activation: 20/04/2023
      •Seat ID: 93991; HW ID: ST1681982550.0Z; Date of activation: 20/04/2023
      You need to upgrade to the latest version of Sketchucation ExtensionStore (v4.3.1). You probably called the License dialog box without an Internet connection.
      I also freed up the 3 seats for ToolsOnSurface.
      • fredo6F Offline
        @natejesus said:
        I bought roundcorner. I activated it and used it. Later I run SketchUp, roundcorner isn't activated. I activate again and use it. 5 minutes later, still running the same SketchUp instance, roundcorner isn't activated again. Now I activate it, it says it's activated, but when I click roundcorner to use it, it says not activated. It is stuck in this loop.
        Could you upgdare to the latest version of Sketchucation ExtensionStore (v4.3.1) and also make sure that you are connected to Internet when you invoke the License dialog box.
        • X Offline
          xyhcwu
          I have updated to Sketchup Pro 2022.
          LibFredo6_v13.9a
          Now it works fine, thanks!
          I found that when using a VPN connection, the activated license does not release itself! ❓
            That shouldn't be a surpise. The license is assigned to your computer but you're using the VPN to hide your computer from the outside world so the lcense server can't see your machine.
            • fredo6F Offline
              Actually, the server only sees a token, HW ID, which is generated randomly for the computer and not related to the true computername. The server does not 'see' machines, but just receive text messages from the computer, as any web site.
              Instead, I think that the Sketchup Http API has some problem and may not like VPN, or more exactly, may consider that there is no connection, especially if the VPN is activated after Sketchup is started. The API tends to freeze its status when it opens Sketchup.
                SketchUp doesn't specifically support virtualized networks though. So it amounts to the same thing.
                • fredo6F Offline
                  I did not know that. Is this documented?
                  • X Offline
                    xyhcwu
                    Sorry, what I meant was that I first turned on the VPN connection and then activated the Fredo6 license, however there is no release option for this seat and it cannot release itself.
                    This resulted in several failed activations and I couldn't release them myself and had to ask Fredo to do it for me.
                    Here, the network is heavily blocked and in many cases the VPN needs to be turned on when using the computer.
                      AbrahamMtzJ
                      Hi, i'm having the same issue where it says license seats exceeded, i'm only using 2 seats in my PC and laptop, is there a way to release all seats so i can validate again.
                        mandraget
                        hi fredo, I got a problem releasing all the licenses on my office PC, can you please help me release all my licenses?
                          Rajaveluhvf
                          PLEASE HOPE TO LEARN THE CORVILOFT
                          • H Offline
                            hghayesh
                            I bought a license that included Fredo corner .. but the license won;t validate , can anyone here help me fix this
                              There's only one license for FreodCorner. If you purchased the Fredo6 bundle it includes a license for Round Corner, not FredoCorner.
                              Do you get an error message when you try to validate it? What exactly does the message say?
                              Your proofile indicates you are using SketchUp 2021 Free/Make. There is no such version. What version are you really using?
                                aneste93
                                Hello! is this possible to install the license offline? My SketchUp has has no conection to Internet... 😞
                                  No, it needs to phone home to activate it.
                                  • N Offline
                                    Noor ul huda
                                    I am trying to buy the fredo6 bundle from Pakistan, but there is no option for that in the debit/credit card section. Can you provide any alternative so that I can use these tools?
                                    Thank you!
                                      dprdesign
                                      Hi - I just purchased licenses for all of your extensions and I keep getting this message that I have exceeded the seats.
                                        If you visit https://sketchucation.com/webshop/my-licences.php you can see the seats you have validated on.
                                        Free up seats as needed
                                          junphuc17945
                                          How can I remove a license from another pc ??
                                            junphuc17945
                                            @fredo6 said:
                                            @Snuk
                                            I released the 3 seats for Curviloft and the seat for FredoScale.
                                            So you now need to revalidate the licenses on your remaining computers.
                                            hi fredo
                                            can you help me release 3 stucked seat of my fredo corner ?
                                            thank you so much !!
                                            Seat ID: 18516; HW ID: BR1622557468.0S; Date of activation: 01/06/2021
                                            Seat ID: 18526; HW ID: TZ1622599474.0M; Date of activation: 02/06/2021
                                            Seat ID: 27979; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 109
                                            • 110
                                            • 81 / 110
