    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    2.2k Posts 487 Posters 933.4k Views 492 Watching
    • N Offline
      natejesus
      I bought roundcorner. I activated it and used it. Later I run SketchUp, roundcorner isn't activated. I activate again and use it. 5 minutes later, still running the same SketchUp instance, roundcorner isn't activated again. Now I activate it, it says it's activated, but when I click roundcorner to use it, it says not activated. It is stuck in this loop.
      I am disappointed. I was willing to give my money for the roundcorner tool, but the DRM is broken and I can no longer use the tool I bought. Needless to say this does not encourage me to buy any more tools. I understand DRM is needed, but it must not get in the way of paid users and absolutely must not prevent people from using what they have paid for.
      • X Offline
        xyhcwu
        I used the Fredo tool yesterday and was prompted with an expired license, I selected the purchased license radical file to activate it and it still prompted an expired license, I activated it again and again and ohhhh, Seats running out!
        I come to - https://sketchucation.com/webshop/my-licences.php
        and found no option to release them, please help me release them!!!
        •Seat ID: 93950; HW ID: TH1681976919.0A; Date of activation: 20/04/2023
        •Seat ID: 93961; HW ID: ZO1681976919.0D; Date of activation: 20/04/2023
        •Seat ID: 93991; HW ID: ST1681982550.0Z; Date of activation: 20/04/2023
          Do you have the current version of the Sketchucation ExtensionStore installed? And the current version of LibFredo6? Make sure they are up to date and then restart SketchUp.
          What version of SketchUp are you using? Your profile shows 2020 Free/Make which is impossible.
          • fredo6F Offline
            You need to upgrade to the latest version of Sketchucation ExtensionStore (v4.3.1). You probably called the License dialog box without an Internet connection.
            I also freed up the 3 seats for ToolsOnSurface.
            • fredo6F Offline
              Could you upgdare to the latest version of Sketchucation ExtensionStore (v4.3.1) and also make sure that you are connected to Internet when you invoke the License dialog box.
              • X Offline
                xyhcwu
                I have updated to Sketchup Pro 2022.
                LibFredo6_v13.9a
                Now it works fine, thanks!
                I found that when using a VPN connection, the activated license does not release itself! ā“
                  That shouldn't be a surpise. The license is assigned to your computer but you're using the VPN to hide your computer from the outside world so the lcense server can't see your machine.
                  • fredo6F Offline
                    Actually, the server only sees a token, HW ID, which is generated randomly for the computer and not related to the true computername. The server does not 'see' machines, but just receive text messages from the computer, as any web site.
                    Instead, I think that the Sketchup Http API has some problem and may not like VPN, or more exactly, may consider that there is no connection, especially if the VPN is activated after Sketchup is started. The API tends to freeze its status when it opens Sketchup.
                      SketchUp doesn't specifically support virtualized networks though. So it amounts to the same thing.
                      • fredo6F Offline
                        I did not know that. Is this documented?
                        • X Offline
                          xyhcwu
                          Sorry, what I meant was that I first turned on the VPN connection and then activated the Fredo6 license, however there is no release option for this seat and it cannot release itself.
                          This resulted in several failed activations and I couldn't release them myself and had to ask Fredo to do it for me.
                          Here, the network is heavily blocked and in many cases the VPN needs to be turned on when using the computer.
                            AbrahamMtzJ
                            Hi, i'm having the same issue where it says license seats exceeded, i'm only using 2 seats in my PC and laptop, is there a way to release all seats so i can validate again.
                              mandraget
                              hi fredo, I got a problem releasing all the licenses on my office PC, can you please help me release all my licenses?
                                Rajaveluhvf
                                PLEASE HOPE TO LEARN THE CORVILOFT
                                • H Offline
                                  hghayesh
                                  I bought a license that included Fredo corner .. but the license won;t validate , can anyone here help me fix this
                                    There's only one license for FreodCorner. If you purchased the Fredo6 bundle it includes a license for Round Corner, not FredoCorner.
                                    Do you get an error message when you try to validate it? What exactly does the message say?
                                    Your proofile indicates you are using SketchUp 2021 Free/Make. There is no such version. What version are you really using?
                                      aneste93
                                      Hello! is this possible to install the license offline? My SketchUp has has no conection to Internet... šŸ˜ž
                                        No, it needs to phone home to activate it.
                                        Download the free D'oh Book for SketchUp šŸ“–
                                        • N Offline
                                          Noor ul huda
                                          I am trying to buy the fredo6 bundle from Pakistan, but there is no option for that in the debit/credit card section. Can you provide any alternative so that I can use these tools?
                                          Thank you!
                                            dprdesign
                                            Hi - I just purchased licenses for all of your extensions and I keep getting this message that I have exceeded the seats.
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 109
                                            • 110
                                            • 74 / 110
