    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 457.4k Views 109 Watching
    • samuel_tS Offline
      samuel_t
      1.2.1 version handles the case when you import a model from a non-system disk partition such as "D:".
      Download latest Universal Importer plugin from SketchUcation PluginStore.
        Still getting errors even on simple cube mesh. No materials, no modifiers and no external files linked or appended to .blend
        https://i.imgur.com/aKHxGA6.png
        • samuel_tS Offline
          samuel_t
          Hi Rich,
          Thanks for your quick bug reports.
          Does Universal Importer v1.21 allow you to import other formats than .blend?
          Can you please attach this very simple .blend file that refuses to be imported?
            Here's a simple cube saved in Blender 3.5 that fails to import...
            cube.zip
              rv1974
              U r Da Beast πŸ˜„
                @rv1974 said:
                U r Da Beast πŸ˜„
                Beware.....because I do bite
                • samuel_tS Offline
                  samuel_t
                  [attachment=0:hhrjer15]<!-- ia0 -->cube.zip<!-- ia0 -->[/attachment:hhrjer15]
                  Indeed Rich, Universal Importer passes Blender 3.4.1 cube test but not Blender 3.5.0 one.
                  Thanks for your report πŸ˜‰
                  • samuel_tS Offline
                    samuel_t
                    1.2.2 version deletes temporary hard links and temporary files possibly left after an import fail or a polygon reduction fail.
                      ankitdarda
                      Could you also include Revit .RVT import with textures as well????? Thanks in advance
                      thank you !!!
                      feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                      :sunglasses:
                      ankitdarda
                      • samuel_tS Offline
                        samuel_t
                        There is little chance that the RVT (Revit) format will ever be supported by the Universal Importer plugin.
                        However, there is a paid add-in for Revit that allows you to export a Revit model and its textures to SketchUp.
                          M_Schulze Newcomers
                          Universal Importer V1.2.2 does not import any stl file. Universal Import Error: No such file or directory @ rb_sysopen - C:/3D/bottle-opener/uir-inter.mtl
                          C:Users/ABC/. . ./SketchUp/Plugins/universal_importer/import.rb:170:in'read'
                          Please help (Sketchup Make 2017, Windows 10)
                          M_S
                          • samuel_tS Offline
                            samuel_t
                            M_S
                            Could you please send me this STL file via Dropbox, for example?
                              Poltava Newcomers
                              Can't download plugin on Sketchucation page...
                                Poltava Newcomers
                                  Yes, we are working on restoring the amazon server bucket that hold the downloads.
                                  Shouldn't take long.
                                    Poltava Newcomers
                                    Does not want to export FBX and other files. Reinstalling doesn't help
                                    Screenshot
                                    • samuel_tS Offline
                                      samuel_t
                                      Try importing a 3D model stored in a folder to which you have write access.
                                        rizkymfadh19 Newcomers
                                        this amazed me, really thank you for the plugin πŸ‘ πŸ‘
                                        • samuel_tS Offline
                                          samuel_t
                                          I'm glad to hear that! πŸ˜„
                                            Sondre_S
                                            Hi, I've used Universal Importer for about a month now and I'm suddenly getting an error saying it doesn't have write access to my documents folder (or any other folder for that matter). The only place it would import from was the root of my C drive! I checked and all folders are marked as "Read Only", but all other programs work correctly.
                                            I opened import.rb and commented out this:
                                            # Source dir must be writable to host hard links we'll create later.
                                                  #raise "Source dir of model to import is not writable; #{@source_dir}"\
                                                   # unless File.writable?(@source_dir)
                                            and I can now import from my documents folder again.
                                            I found this in an article from Microsoft:
                                            "The Read-only and System attributes is only used by Windows Explorer to determine whether the folder is a special folder, such as a system folder that has its view customized by Windows (for example, My Documents, Favorites, Fonts, Downloaded Program Files), or a folder that you customized by using the Customize tab of the folder's Properties dialog box. As a result, Windows Explorer does not allow you to view or change the Read-only or System attributes of folders."
                                            What does it mean if Windows isn't supported? - Microsoft Support
                                            Learn what it means if you have an older version of Windows that's no longer supported.
                                            (support.microsoft.com)
                                            • 22
                                            • 23
                                            • 8 / 23
