    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
      ankitdarda
      Could you also include Revit .RVT import with textures as well????? Thanks in advance
      thank you !!!
      feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
      :sunglasses:
      ankitdarda
      • samuel_tS
        samuel_t
        There is little chance that the RVT (Revit) format will ever be supported by the Universal Importer plugin.
        However, there is a paid add-in for Revit that allows you to export a Revit model and its textures to SketchUp.
          M_Schulze Newcomers
          Universal Importer V1.2.2 does not import any stl file. Universal Import Error: No such file or directory @ rb_sysopen - C:/3D/bottle-opener/uir-inter.mtl
          C:Users/ABC/. . ./SketchUp/Plugins/universal_importer/import.rb:170:in'read'
          Please help (Sketchup Make 2017, Windows 10)
          M_S
          • samuel_tS
            samuel_t
            M_S
            Could you please send me this STL file via Dropbox, for example?
            • P
              Poltava Newcomers
              Can't download plugin on Sketchucation page...
              • P
                Poltava Newcomers
                  Yes, we are working on restoring the amazon server bucket that hold the downloads.
                  Shouldn't take long.
                  • P
                    Poltava Newcomers
                    Does not want to export FBX and other files. Reinstalling doesn't help
                    Screenshot
                    • samuel_tS
                      samuel_t
                      Try importing a 3D model stored in a folder to which you have write access.
                        rizkymfadh19 Newcomers
                        this amazed me, really thank you for the plugin 👍 👍
                        • samuel_tS
                          samuel_t
                          I'm glad to hear that! 😄
                            Sondre_S
                            Hi, I've used Universal Importer for about a month now and I'm suddenly getting an error saying it doesn't have write access to my documents folder (or any other folder for that matter). The only place it would import from was the root of my C drive! I checked and all folders are marked as "Read Only", but all other programs work correctly.
                            I opened import.rb and commented out this:
                            # Source dir must be writable to host hard links we'll create later.
                                  #raise "Source dir of model to import is not writable; #{@source_dir}"\
                                   # unless File.writable?(@source_dir)
                            and I can now import from my documents folder again.
                            I found this in an article from Microsoft:
                            "The Read-only and System attributes is only used by Windows Explorer to determine whether the folder is a special folder, such as a system folder that has its view customized by Windows (for example, My Documents, Favorites, Fonts, Downloaded Program Files), or a folder that you customized by using the Customize tab of the folder's Properties dialog box. As a result, Windows Explorer does not allow you to view or change the Read-only or System attributes of folders."
                            https://support.microsoft.com/en-us/topic/you-cannot-view-or-change-the-read-only-or-the-system-attributes-of-folders-in-windows-server-2003-in-windows-xp-in-windows-vista-or-in-windows-7-55bd5ec5-d19e-6173-0df1-8f5b49247165
                            • samuel_tS
                              samuel_t
                              @Sondre_S
                              Thanks for the technical details. I will solve this problem as soon as possible.
                              • samuel_tS
                                samuel_t
                                1.2.3 version doesn't display anymore the "Source dir of model to import is not writable" error message.
                                Download latest Universal Importer plugin from SketchUcation PluginStore.
                                  romanencom Newcomers
                                  Dear samuel_t, I just installed your plugin, but I can't import the step file, I get this message. At the same time, a duplicate of it with a different name is created in the folder with this file. You can help me?
                                  U 1 Reply Last reply
                                  • O
                                    Ottown
                                    Hi Samuel,
                                    Have downloadeed the latest version along with sketchup pro 2023 for mac, but every time i try to import a model fbx or obj im getting the errow shown.
                                    Any advise
                                    Universal Importer Error: Command failed: cd "/Users/davidott/Downloads/Test" && "/Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/Applications/Assimp/Mac/assimp" export "uir-source.3ds" "uir-inter.obj" -tri
                                    /Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
                                    Universal Importer Version: 1.2.3
                                    • samuel_tS
                                      samuel_t
                                      Dear Roman,
                                      Unfortunately, compatibility with the STEP format is low.
                                      • samuel_tS
                                        samuel_t
                                        @ottown said:
                                        Hi Samuel,
                                        Any advise
                                        Hi David,
                                        In this situation, the error message does not provide enough details. Maybe your macOS is not allowed to run Assimp executable?
                                        • W
                                          Waltersch
                                          Hi Samuel
                                          First of all thank you very much for this great and super useful extension!
                                          But I do habe a problem on importing from Model Converter X.
                                          Here my workflow.
                                          Construction on Sketchup 17. Export as collada file.
                                          Import to 3DCoat for texturing. Export as obj file.
                                          Import to Model Converter X for checking and file conversion. Export as obj file.
                                          I do check the polygons in every step and they are the same in every step. Pic1 shows the correct wireframe so far.
                                          Import to Sketchup with "Universal Importer Plugin". Now the wireframe is not as it was in all the steps ahead. Some of the edges are missing. I´m not using any polygon reduction. Pic2 shows the result after the import.
                                          My question to you is only, why the imported wireframe is not the same as it was in all the other steps ahead. Because the wireframe is broken in some area, the texture does´nt fit any more.
                                          For an additional explanation. The workfrlow may seam strange and all can be done with different software solutions much easier. You are all right, but this is my workflow I´m used to it.
                                            jamesdavies0211
                                            Hi!
                                            Really love the look of this extension, however, having some issues with importing blend and obj files.
                                            Any help would be greatly appreciated!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
