    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.4k Views 112 Watching
    • Didier BurD Offline
      Didier Bur
      Hello Samuel,
      I've sent you the OBJ file via PM.
      Regards,
      DB
        bartektrebacz
        Dear Samuel,
        Thank You for making this plugin available to the public, I would really like to try to use it, unfortunately sketchup crashes on import. I tried with multiple formats of the same model with no success:/ I’m using sketchup 17 make version.
        Best regards!
        This is the file name
        • samuel_tS Offline
          samuel_t
          @satemorej said:
          Here is the link to the obj file that causes my error.
          https://www.artec3d.com/fr/3d-models/bearded-guy-hd
          https://sketchucation.com/forums/download/file.php?id=168290&mode=view/rokbox.jpg
          Hello Jérôme,
          Upcoming plugin version fixes this error! 😉
          • samuel_tS Offline
            samuel_t
            @didier bur said:
            I use Universal Importer to import an OBJ file that is exported from MeshMolder.
            the 435488 triangles from MM are converted to a 86702 triangles mesh in SU. But when importing, UI does say "The file has 435488 faces. Do you want to reduce the number of faces ?". The triangles decimation occurs even if I answer "No" to this message.
            Hello Didier,
            Thanks for providing this OBJ file. With upcoming version of Universal Importer, I ended up with 379808 faces in SU. Not perfect but better 😄
            • samuel_tS Offline
              samuel_t
              @bartektrebacz said:
              Dear Samuel,
              Thank you for making this plugin available to the public
              Dear bartektrebacz,
              It seemed natural and more "ethical" to release this plugin for free because it relies heavily on free public resources (such as Assimp and MeshLab) that are developed by other developers than me.
              SketchUp crashes on import. I tried with multiple formats of the same model with no success 😕 I’m using SketchUp 17 Make version.
              SketchUp 17 Make, OK. Can you please send me the file "uploads-files-955134-F22+ANUK.3ds" via Dropbox (or another file host) so I can inspect it?
              • samuel_tS Offline
                samuel_t
                @rich o brien said:
                https://i.imgur.com/bHVy9Nk.png
                This is on Blender 3.2.1 files. Even a simple cube fails
                Hello Rich,
                This error is fixed in upcoming Universal Importer version! In fact, even current Blender version (3.4.1) will be somewhat supported. More news on this topic very soon 😄
                • samuel_tS Offline
                  samuel_t
                  Hello, I am pleased to announce the availability of Universal Importer 1.2.0! 😄 Here are the changes brought by this new version:
                  Improvements
                  Imports are faster due to the fact that the plugin now uses (as much as possible) temporary hard links instead of classic temporary files. This also allows to monopolize less disk space during the import process.
                  I refactored some of the plugin code to make it cleaner, I hope so 😛
                  Bugfixes
                  Polygon reduction from the toolbar was not working anymore (or not for all models). The number of faces before and after reduction was about equal, very far from the target... It's fixed!
                  Thanks to the great work of the Assimp contributors, you should no longer get the error:
                  • "End of file or read limit was reached", when importing a .ter file (Terragen).
                  • "Constructing BlenderDNA Structure encountered an error", when importing a .blend file. By the way, the files created with Blender 3 are now importable provided you:
                    1. Extract the textures embedded in the .blend file to the disk with Blender.
                    2. Check the option "Claim Missing Textures" in Universal Importer.
                  The bug of imported materials with zero opacity is fixed. Thanks to JDD for reporting this bug.
                  It is now possible to load an .obj file that references an empty material library ("mtllib"). Thanks to Jérôme Tas for reporting this case.
                  A heavy model (e.g. more than 400 000 triangles) can lose triangles once imported into SketchUp with Universal Importer. This problem has not disappeared yet but seems less present... Thanks to Didier Bur for reporting this problem.
                  Translations
                  I took the liberty of including a Japanese translation of Universal Importer, found on the PC-Trace blog. If you are the administrator of this blog, I invite you to contact me to become the official Japanese translator of the plugin.
                  If Universal Importer is not available in your native language, feel free to contact me to become its official translator 😉
                  Download latest Universal Importer plugin from SketchUcation PluginStore.
                    Brilliant update!
                      Blend files seem to still be an issue. Will test more though....
                      https://i.imgur.com/4clWQXe.png
                      • samuel_tS Offline
                        samuel_t
                        1.2.1 version handles the case when you import a model from a non-system disk partition such as "D:".
                          Still getting errors even on simple cube mesh. No materials, no modifiers and no external files linked or appended to .blend
                          https://i.imgur.com/aKHxGA6.png
                          • samuel_tS Offline
                            samuel_t
                            Hi Rich,
                            Thanks for your quick bug reports.
                            Does Universal Importer v1.21 allow you to import other formats than .blend?
                            Can you please attach this very simple .blend file that refuses to be imported?
                              Here's a simple cube saved in Blender 3.5 that fails to import...
                              cube.zip
                                rv1974
                                U r Da Beast 😄
                                  @rv1974 said:
                                  U r Da Beast 😄
                                  Beware.....because I do bite
                                  • samuel_tS Offline
                                    samuel_t
                                    [attachment=0:hhrjer15]<!-- ia0 -->cube.zip<!-- ia0 -->[/attachment:hhrjer15]
                                    Indeed Rich, Universal Importer passes Blender 3.4.1 cube test but not Blender 3.5.0 one.
                                    Thanks for your report 😉
                                    • samuel_tS Offline
                                      samuel_t
                                      1.2.2 version deletes temporary hard links and temporary files possibly left after an import fail or a polygon reduction fail.
                                        ankitdarda
                                        Could you also include Revit .RVT import with textures as well????? Thanks in advance
                                        thank you !!!
                                        feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                                        :sunglasses:
                                        ankitdarda
                                        • samuel_tS Offline
                                          samuel_t
                                          There is little chance that the RVT (Revit) format will ever be supported by the Universal Importer plugin.
                                          However, there is a paid add-in for Revit that allows you to export a Revit model and its textures to SketchUp.
                                            M_Schulze Newcomers
                                            Universal Importer V1.2.2 does not import any stl file. Universal Import Error: No such file or directory @ rb_sysopen - C:/3D/bottle-opener/uir-inter.mtl
                                            C:Users/ABC/. . ./SketchUp/Plugins/universal_importer/import.rb:170:in'read'
                                            Please help (Sketchup Make 2017, Windows 10)
                                            M_S
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
