    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 451.4k Views 80 Watching
      maximumselfish
      Добрый день.
      Ожидается поддержка SU 2023?
        joerg
        Hi Anton,
        thanks once again for your very helpfull extension!
        I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
        Same problem on WIN10 and WIN11 Pro with SU2021Pro.
        Thanks for your help!
        Joerg
          Apollo Tuan
          After I installed it, I found it was not complete and only showed some of the features
          • shake1S Offline
            shake1
            Anton, please adapt for 2023. This is the head of all plugins.
              sarkarshomit
              So the plugin is still awaiting update for Sketchup 2023?
              I use this plugin a lot in Skup2021, but completely migrating to SU23, is not getting possible due to incompatible FS plugin
                Anton_S
                Hello everyone! This should work with SU2023. The incomplete UI is because SU2023 has undergone a major internal framework change and I no longer have the capability to manipulate some of the elements. Things like full-screen, should still work though. Let me know if otherwise.
                S 1 Reply Last reply Reply Quote 0
                • kimgaK Offline
                  kimga
                  HI Anton,
                  I just installed the plugin. I have never used it, so not sure how it meant to work. I was looking for a way to fullscreen the working window to see the V-ray safe screen, unfortunately, I didn't manage this with your extension used with SketchUp 2023 running on Windows 11.
                  Good day!
                    sarkarshomit @Anton_S
                    @Anton_S No sir, its still not working with Su2023 on win10.
                    I so wish if u could give the plugin its much required overhaul.
                    When i press the fullscreen button check box, it does go in fullscreen, but it does not hide floating and docked toolbars, which i really use a lot for taking screenshots of my works.
                      laughoutloud99
                      This plugin cannot load correctly in the su2024.
                      We used it to keep clean UI for years.
                      Please request a fix for it.
                      Thank you to anyone who can help.
                      • shake1S Offline
                        shake1
                        The greatest value for me is to show/hide the toolbar or tray in one click.
                        The last time this worked was in SU 2022. This functionality is really missing.
                          Anton_S
                          Hi all, the plugin is now updated to work with the latest version of SU2023 and SU2024. Please note that the features in SU2023 and later are limited because SketchUp changed to a new, Qt-based framework, and I have not found a way to hack it.
                          D 1 Reply Last reply Reply Quote 0
                            Design_Dong @Anton_S
                            @Anton_S
                            @Anton_S said in [Plugin] FullScreen v5.1.3 (25 April 2024):
                            hope you can fix all functions in 2024
                              joydeep70
                              Fix it as early as possible. Study hard. God bless you.
                              • 11
                              • 12
                              • 13
                              • 14
                              • 15
                              • 15 / 15
