    2.2k Posts 482 Posters 855.1k Views 487 Watching
      Install the latest version of the SketchUcation Toolset.
      It includes a much newer version of the Licensing system.
      Also ensure you have the latest LibFredo6 and any extensions installed.
      Restart SketchUp after the installation[s].
      Then try validating a license...
        jfussa19
        Hi.
        My user name is jfussa19.
        I got my full fredo 6 license, however I Have not been able to validate it on my sketchup. I got this screen and then in the explorer I don't find the SCF License. It happens with the whole plugins I got purchased.
        Can you help me with this?
        • fredo6F Offline
          Could you do what is suggested in the message box and advise if this fixes the issue.
            tenrev
            Good morning
            can you tell me if there is a way to reset your licenses
            I no longer have access to two of my old PCs which are out of order, so I have 4 Fredo6 licenses where the 3 seats are used, I would like to reset everything and be able to reactivate the seats on other PCs
            I saw the question asked by others but no answer?
            thank you for your reply
            biblio3d forum sketchup - artlantis - piranesi
            http://www.biblio3d.com
              Please check https://sketchucation.com/webshop/my-licences.php
              All cureent and future devices will need Sketchucation Tools 4.3.1 installed. This will allow you to manage seat releasing yourself going forward
                tenrev
                great thank you, I had just installed version 4.3.1 and I'm not going to restart sketchup sorry, the main thing now it works, thank you again for the quick response
                  ramonbastos
                  but I cant find the option to do that on https://sketchucation.com/webshop/my-licences.php like you mentioned
                  If the device was activated using Sketchucation Tools < 4.3 then you won't see checkboxes at https://sketchucation.com/webshop/my-licences.php
                  Go to the device and upgrade Sketchucation Tools
                    jaroslavz
                    Can you reset my 3 stucked seats, please? Thank you very much:
                    fredo scale
                    Seat ID: 99818; HW ID: ZB1653811604.0U; Date of activation: 21/05/2023
                    Curviloft:
                    Seat ID: 117152; HW ID: QW1685472429.0E; Date of activation: 28/08/2023
                    Seat ID: 140165; HW ID: UH1651220680.0W; Date of activation: 10/01/2024
                    • fredo6F Offline
                      fredo scale
                      Curviloft:
                      This is done now.
                        sorin3dstudio
                        Hello ,
                        I have the same problem as many other users, I changed the computers name and now I cant use Fredo tools, I dont remember my former computer name and also I cant rename it because I have other programs installed...
                        I need to understand if I have any option to fix this problem.
                        Sorin
                          Sorin
                          Follow the advice in the alert.
                          Close SketchUp
                          Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file at C:\Users\SomeName\AppData\Local\SCF Licenses
                          Open SketchUp
                          Try activating
                          If that fails use the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu to open the console and copy/paste the text into your reply here
                            marypacheco08
                            Hi how are you I have a question:
                            To use all the fredo tools, also to use round corner and curviloft what are the license that I need to get, this one SCFLicense??? or how many others?
                              SketchUcation | Cart
                              (sketchucation.com)
                              https://i.imgur.com/LcadleC.png
                                juliamaxdylan
                                I cannot activate my licence for Fredo Corner and Round corner, get an error message A0B.
                                Can anyone help please?
                                  @juliamaxdylan said:
                                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                    pklenk702
                                    [size=100:k6vvzzqz]I will start with saying I am an architect, not a computer person, so please forgive my naivete. I am currently struggling with licensing FredoScale. I have downloaded LibFredo6 and FredoScale, both current versions, as well as SketchUcation, the ****current version. I believe I have installed all three via the extension manage, which shows them installed. I have purchased the appropriate license via SketchUcation, received the email, downloaded the .rbz file and the .scflicense files, put in “a safe place”. The Fredo6_Lib and Fredo6_Scale folders and the LibFredo6.rb and FredoScale.rb files are in the Plugins root directory. The Fredo6 collection is showing under Tool and the Fredo6 Preferences under Window. I installed LibFredo first and then FredoScale.
                                    The problem is nothing happens. Under FredoScale under the Tools, I go to License…” nothing happens. I try to use the extension, but nothing happens. No pop-ups about the license, no activation, no validation, just a big nothing.
                                    I can only assume I am doing something wrong. What else do I need to do? I’ve read and re-read license instructions, listened to Fredo6’s instructions. It is like the plugins are not installed.
                                    Thank you in advance.[/size]
                                      If everything is installed correctly you can run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply here.
                                      https://i.imgur.com/NNL6A6w.png
                                      It will give us a baseline to build upon.
                                        pklenk702
                                        Here is the report -
                                        Fredo6 Plugins Information on 2024-02-23 13:18:53 -0800
                                        • Platform: x64-mswin64_140 - Ruby: 2.7.7
                                        • Sketchup: 23.0.419
                                        • LibFredo6: v14.2a
                                        • LibFredo6 Binary NOT loaded
                                        • Sketchucation ExtensionStore: 4.3.1
                                          Error: #<LoadError: 5: Access is denied. - C:/Users/pklenk/AppData/Local/Temp/SCFLicense - SU2023/SUEX_SCFLibrary.so>
                                          C:/Program Files/SketchUp/SketchUp 2023/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:83:in require' C:/Program Files/SketchUp/SketchUp 2023/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:83:in require'
                                          c:/users/pklenk/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:156:in load_binary' c:/users/pklenk/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:80:in dynamic_token'
                                          c:/users/pklenk/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:774:in info' c:/users/pklenk/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:368:in block in populate_support_menu'
                                          c:/users/pklenk/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1387:in `block in add_command'
                                          I'm sure Fredo / Rich will give a more detailed reply but to me it seems from the report
                                          That SketchUp [or SketchUcation or you-yourself] is being prevented from loading a file from a folder in
                                          Navigate to that folder [it is hidden by default but access with the right settings] and select its icon, right-click > Properties > Security > Edit
                                          There will be several Group or user-names listed.
                                          Select each one of them in turn and ensure that the Permissions > Full control is ticked.
                                          When they are all set properly press OK.
                                          See if that has now helped your issue...
                                            pklenk702
                                            Could an Ad Blocker, or some other program/adjustment/device that the IT people have installed in their attempt to keep us kids in line be preventing access to the appropriate files? It is always a delay and a chore to get them involved, but if I must I must. BTW "kid" is way, way in the rear view mirror.
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 109
                                            • 110
                                            • 90 / 110
