    Trying to draw an elliptical cone
    27 Posts 7 Posters 488 Views 7 Watching
    • frascatiF Offline
      frascati
      Thank you
        https://i.imgur.com/2qStuJz.png
        1. Draw the primitive divided circle
        2. Scale from centre along an axis
        3. Select the boundary edges and active Smoove. Set a value for your falloff
        4. Position geometry and shade smooth
        I can't give you precise values as I didn't do it to any particular size. So you may have experiment with your falloff values using Smoove.
        • frascatiF Offline
          frascati
          Ok
          • BoxB Offline
            Too many straws.
            • frascatiF Offline
              frascati
              Ok
              • gullfoG Offline
                gullfo
                it's a profile using an elliptical shape with follow me. all native tools.
                if you're trying to duplicate the HF drive on the speaker in your first post - Genelec uses a mathematical model to generate it, not drawing tools. when i model their speakers for recording studio designs, i use the profile and elliptical curve or the scaling method - which ever one looks "close enough" since i'm not actually making the speaker, just need it for size and rendering purposes.
                Glenn
                http://www.runnel.com
                • frascatiF Offline
                  frascati
                  Ok
                  • BoxB Offline
                    Follow me on an ellipse will not produce the shape you want.
                    • frascatiF Offline
                      frascati
                      Ok
                        But I thought I'd try an elliptical horn rather than round. I had no idea I was opening a new can of worms
                        The worm is the native only approach. Since SU is primarily a conceptual design tool and you require some level of accuracy its supported via extensibility.
                        The core can't do it but it can be done.
                        • panixiaP Offline
                          panixia
                          @frascati said:
                          "Rich showed you a native way to do it."
                          "Smoove has a falloff...."
                          I need to go back and change my "intermediate" level of understanding to "beginner"
                          "Smoove" is a member here? And a "falloff" is a what? Do the four images he posted suffice as a "tutorial"?
                          Not sure why you are so rude, nobody is in owe of doing turorials for you.
                          By the way what Rich said is more than enough, those are the only (pretty self explainatory) tools to attempt a similar shape in vanilla Sketchup.
                          As already said, is pointless to try to model this kind of shapes using only native tools.
                          Here's my 15 minutes draft using QFT/VT2/SubD.
                          SubD_Speaker.skp
                          • frascatiF Offline
                            frascati
                            It was actually a very mild RE-action to being confidently assured that I'd been "shown" the way to do it already.
                            You considered my response rude? Really? You need to get out of the house more. I absolutely take offense to being called rude when my conduct does not merit it.
                            You have offered the initial rudeness here. Please refrain from comment in any further topics I submit.
                            • frascatiF Offline
                              frascati
                              ok
                              • HornOxxH Offline
                                HornOxx
                                Besides all the other good solutions above, here is another very quick one:
                                Not native but with the plugin Cruviloft you can also achieve this desired geometry with ease.
                                With the same tool and with the same simple principle you can get even further than just to the speakers.
                                In the middle is the circle - around it is a small number of elypses which you move (up) to your desired positions. Then you let the plugin work which generates the desired shape with the preferred segmentations and smoothing by clicking on the circle and elypses plygons in the correct order - Done!
                                (Above a certain level of complexity it is advisable to consider plugins rather than torturing yourself with the native options - especially if you are dealing with organic shapes)
                                never trust a skinny cook
                                • frascatiF Offline
                                  frascati
                                  Thank you HornOxx. That looks promising. I'll give it a go.
                                  • frascatiF Offline
                                    frascati
                                    This AI is kinda fun
                                    • 2 / 2
