    Trying to draw an elliptical cone
    27 Posts 7 Posters 475 Views 7 Watching
    • frascatiF Offline
      frascati
        @frascati said:
        Is there an elegant workaround without using a plugin?
        It depends on what version of SketchUp are you using. Please complete your forum profile with that information.
        • Rich O BrienR Online
          Smoove has a falloff that could achieve such a result...
          https://i.imgur.com/6YPAfkb.png
          Here's a very basic example.
          • frascatiF Offline
            frascati
            Ok
              @frascati said:
              Really no way to do this natively in Sketchup?
              Rich showed you a native way to do it.
              Another non-extension way to do it would be to stitch the vertices together with the 2-point Arc and Line tools.
              The method I showed in that thread of using Follow Me and then scaling the large end to make an ellipse doesn't require any extensions.
              • frascatiF Offline
                frascati
                Ok
                  Smoove is a tool under Sandbox
                  Falloff is a linear decline in influence over distance
                  Potatoes are not vegetables.
                  • frascatiF Offline
                    frascati
                    ...but crabs sometimes repurpose shells
                    • frascatiF Offline
                      frascati
                      @frascati said:
                      ...but crabs sometimes swap shells
                      • frascatiF Offline
                        frascati
                        Ok
                        • frascatiF Offline
                          frascati
                          I see
                          • frascatiF Offline
                            frascati
                            Thank you
                              https://i.imgur.com/2qStuJz.png
                              1. Draw the primitive divided circle
                              2. Scale from centre along an axis
                              3. Select the boundary edges and active Smoove. Set a value for your falloff
                              4. Position geometry and shade smooth
                              I can't give you precise values as I didn't do it to any particular size. So you may have experiment with your falloff values using Smoove.
                              • frascatiF Offline
                                frascati
                                Ok
                                • BoxB Offline
                                  Too many straws.
                                  • frascatiF Offline
                                    frascati
                                    Ok
                                    • gullfoG Offline
                                      gullfo
                                      it's a profile using an elliptical shape with follow me. all native tools.
                                      if you're trying to duplicate the HF drive on the speaker in your first post - Genelec uses a mathematical model to generate it, not drawing tools. when i model their speakers for recording studio designs, i use the profile and elliptical curve or the scaling method - which ever one looks "close enough" since i'm not actually making the speaker, just need it for size and rendering purposes.
                                      Glenn
                                      http://www.runnel.com
                                      • frascatiF Offline
                                        frascati
                                        Ok
                                        • BoxB Offline
                                          Follow me on an ellipse will not produce the shape you want.
                                          • frascatiF Offline
                                            frascati
                                            Ok
