    3D into 2D?
    11 Posts 5 Posters 0 Views 5 Watching
      djh
      May I easily convert a 3D object into a 2D object?
      Once I have the desired perspective and angle of the 3D object, it would be easier for me to work with it as a 2D object in SU.
        Your question sounds ambiguous, would you care to elaborate?
          https://sketchucation.com/pluginstore?pln=CADup
          Until we know more...
            djh
            Exported object as a dwg and imported it as a flat, 2D object. I would like only the profile, the outer boundaries of the flat image and the ability to color it with a material fill.
            3D to 2D.skp
              It's possible to do it without any extensions. You just need to clean up the edges where there are overruns and gaps so a face can be formed.
              Your model would be easier to work with if you'd turn off Length Snapping.
                djh
                [attachment=0:3sy8c9gg]<!-- ia0 -->Screenshot - 1_31_2023 , 9_09_27 AM.png<!-- ia0 -->[/attachment:3sy8c9gg]
                Dave R, thank you, but I was hoping for a solution that was a little less tedious.
                Good advice. It is much easier to work with Length Snapping turned off.
                  Understood. Many of the forks in the perimeter edges require decisions that a Ruby script can't make. Which leg of the fork gets deleted and which is kept.
                  • BoxB Offline
                    I haven't tried it, but Tig's Shadow Projector may be the trick for this.
                    Position the object perpendicular to the sun and project the shadow to become geometry.
                      Good thought. I just tried it. After about 5 minutes of processing I got a Bug Splat. Manually fixing the outline might have taken as much as a minute. Didn't time it when I did it.
                      • BoxB Offline
                        Nothing like a good thought though. πŸ’š
                          Indeed! If the 3D object was simpler it would work.
