    Animator not rendering the sky with Vray after crash
    30 Posts 6 Posters 2.4k Views 6 Watching
      What version of SketchUp are you using? Your profile indicates a version that doesn't and never has existed. What version of Vray?
        DarkParadise Newcomers
        Hi Dave,
        profile updated ! πŸ˜‰
        Sketchup 22
        Vray for sketchup 6.00.01
        PC, Dell 7820 tower with Intel xeon bronze 3204 cpu @1.9 ghz, 48 GB Ram, 2 Nvidia Quadro P1000 graphic cards (4 GB GDDR5. Memory Interface. each)
        Let me know if you need other infos.
        Best regards,
        Olivier
        • fredo6F
          Animator does not interact with the rendering settings of VRay. So, the problem might be in the VRay API. As you had a crash, it might be that some hidden processes are alive.
          So, I will suggest that you reboot the computer and try again.
            Dear Fredo,
            thanks for your reply.
            Actually, I did restart my machine, but the issue persist this morning.
            Any other idea ?
            All the best,
            Olivier
            • fredo6F
              What happens if you create a new animation from scratch and render it?
                The problem remain... πŸ˜•
                  Hi Fredo,
                  I still haven't found a fix to the problem... I'm getting πŸ˜• πŸ˜• πŸ˜•
                  Is the setting of the sky in vray correct ? Should I try to re-install vray ? Could I send you the files so that you could do a test on your machine ?
                  Any help greatly appreciated,
                  Thanks in advance,
                  Olivier
                  Vray sky settings
                  • fredo6F
                    If you do a Natural render, do you get the sky displayed?
                      Thanks again for your help Fredo...
                      Yes I do... so strange...
                      here is a comparison of natural vs vray render through animator...
                      but within vray alone, everything works...
                        Hi Fredo,
                        I'm desperate... Do you think that a reinstall of Vray would change something ? Any other idea ?
                        Best,
                        Olivier
                        • fredo6F
                          This may be an idea. On my side, I am short of clues to understand how Animator could prevent things to happen (or not) in VRay....
                            Thanks...
                            That's why I'm desperate, πŸ˜‰ What other renderer would you use ?
                            I'll keep you posted for the re-install.
                            • ntxdaveN
                              ntxdave
                              You might try Twilight Render. I have used it with Animator and never had any problems. πŸ˜„
                              Press F1...thank me later
                                Hi Dave,
                                thanks for the tip ! I'll give it a try with the hobby version... Are you aware of any limitation with this one ?
                                All the best,
                                Olivier
                                  Dear Fredo,
                                  I also tried with a prior version to the crash and the problem persits. So it's not due to some file corruption of some sort.
                                  I uninstalled Vray and re-installed it, and the problems remains as it is:
                                  Vray only on the left, animator and Vray on the right
                                  It is so strange. Should I also try to uninstall/install Animator ?
                                  thanks again for your support.
                                  Olivier
                                  • ntxdaveN
                                    ntxdave
                                    @darkparadise said:
                                    Hi Dave,
                                    All the best,
                                    Olivier
                                    Not really. I have used it many times with Animator. They also have several tutorials and a good support team.
                                    Let’em know I recommended them. πŸ˜„
                                      Dave, hi again !
                                      I've installed Twilight 2 in Sketchup. Rendering seems fine with the render engine from the software itself, but I can't see it in the Generation of Video in Animator.
                                      Any way to fix this ?
                                      Thanks again,
                                      Olivier
                                      • ntxdaveN
                                        ntxdave
                                        I am having problems with my laptop so I cannot currently explore this for you, but Twilight Render should show up in the Generate Video toolbar. It has always been there for me. It has been quite a while so I cannot remember how to add it.
                                        I would suggest you post in the Animator thread. Fredo is always pretty good at responding. You might also post the question in the Twilight Render forum.
                                        Sorry I cannot run it to help you.
                                        • ntxdaveN
                                          ntxdave
                                          Any resolution to your issue?
                                          • fredo6F
                                            [attachment=0:3b2vx4d8]<!-- ia0 -->Vray vs vray and animator 20020113.JPG<!-- ia0 -->[/attachment:3b2vx4d8]
                                            I don't think you need to uninstall Animator (the video management is in LibFredo6 anyway).
                                            Likewise, if this happens with any model, I don't think this is useful to send me the model.
                                            There must be a setting left in VRay which is used by the VRay API. So, I would recommend you post to the VRay forum, asking whether the API has a separate configuration versus the direct rendering within VRay.
