    Animator not rendering the sky with Vray after crash
    30 Posts 6 Posters 2.4k Views 6 Watching
      DarkParadise Newcomers
      Hi Dave,
      profile updated ! πŸ˜‰
      Sketchup 22
      Vray for sketchup 6.00.01
      PC, Dell 7820 tower with Intel xeon bronze 3204 cpu @1.9 ghz, 48 GB Ram, 2 Nvidia Quadro P1000 graphic cards (4 GB GDDR5. Memory Interface. each)
      Let me know if you need other infos.
      Best regards,
      Olivier
      • fredo6F
        Animator does not interact with the rendering settings of VRay. So, the problem might be in the VRay API. As you had a crash, it might be that some hidden processes are alive.
        So, I will suggest that you reboot the computer and try again.
          Dear Fredo,
          thanks for your reply.
          Actually, I did restart my machine, but the issue persist this morning.
          Any other idea ?
          All the best,
          Olivier
          • fredo6F
            What happens if you create a new animation from scratch and render it?
              The problem remain... πŸ˜•
                Hi Fredo,
                I still haven't found a fix to the problem... I'm getting πŸ˜• πŸ˜• πŸ˜•
                Is the setting of the sky in vray correct ? Should I try to re-install vray ? Could I send you the files so that you could do a test on your machine ?
                Any help greatly appreciated,
                Thanks in advance,
                Olivier
                Vray sky settings
                • fredo6F
                  If you do a Natural render, do you get the sky displayed?
                    Thanks again for your help Fredo...
                    Yes I do... so strange...
                    here is a comparison of natural vs vray render through animator...
                    but within vray alone, everything works...
                      Hi Fredo,
                      I'm desperate... Do you think that a reinstall of Vray would change something ? Any other idea ?
                      Best,
                      Olivier
                      • fredo6F
                        This may be an idea. On my side, I am short of clues to understand how Animator could prevent things to happen (or not) in VRay....
                          Thanks...
                          That's why I'm desperate, πŸ˜‰ What other renderer would you use ?
                          I'll keep you posted for the re-install.
                          • ntxdaveN
                            ntxdave
                            You might try Twilight Render. I have used it with Animator and never had any problems. πŸ˜„
                            Press F1...thank me later
                              Hi Dave,
                              thanks for the tip ! I'll give it a try with the hobby version... Are you aware of any limitation with this one ?
                              All the best,
                              Olivier
                                Dear Fredo,
                                I also tried with a prior version to the crash and the problem persits. So it's not due to some file corruption of some sort.
                                I uninstalled Vray and re-installed it, and the problems remains as it is:
                                Vray only on the left, animator and Vray on the right
                                It is so strange. Should I also try to uninstall/install Animator ?
                                thanks again for your support.
                                Olivier
                                • ntxdaveN
                                  ntxdave
                                  @darkparadise said:
                                  Hi Dave,
                                  All the best,
                                  Olivier
                                  Not really. I have used it many times with Animator. They also have several tutorials and a good support team.
                                  Let’em know I recommended them. πŸ˜„
                                    Dave, hi again !
                                    I've installed Twilight 2 in Sketchup. Rendering seems fine with the render engine from the software itself, but I can't see it in the Generation of Video in Animator.
                                    Any way to fix this ?
                                    Thanks again,
                                    Olivier
                                    • ntxdaveN
                                      ntxdave
                                      I am having problems with my laptop so I cannot currently explore this for you, but Twilight Render should show up in the Generate Video toolbar. It has always been there for me. It has been quite a while so I cannot remember how to add it.
                                      I would suggest you post in the Animator thread. Fredo is always pretty good at responding. You might also post the question in the Twilight Render forum.
                                      Sorry I cannot run it to help you.
                                      • ntxdaveN
                                        ntxdave
                                        Any resolution to your issue?
                                        • fredo6F
                                          [attachment=0:3b2vx4d8]<!-- ia0 -->Vray vs vray and animator 20020113.JPG<!-- ia0 -->[/attachment:3b2vx4d8]
                                          I don't think you need to uninstall Animator (the video management is in LibFredo6 anyway).
                                          Likewise, if this happens with any model, I don't think this is useful to send me the model.
                                          There must be a setting left in VRay which is used by the VRay API. So, I would recommend you post to the VRay forum, asking whether the API has a separate configuration versus the direct rendering within VRay.
                                          • ntxdaveN
                                            ntxdave
                                            Why isn’t Twilight Render showing up for him in Animator?
