    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      @kpbarbee said:
      The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
      Could you do the following, assuming you have Sketchup 2021 or 2022.
      1. Open the Ruby Console (menu Extension > Developer)
      2. Close Sketchup
      3. Open Sketchup - The Ruby console should open automatically and potentially display error messages.
      4. Keep the Ruby console opened when launching my plugins.
      • I Offline
        igorassis
        Still having the same issues with this version,i cant use most of your plugins, im having this problem
        path=C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/1001bit_freeware
        no language file.
        tb_mode,single
        tb_Settingout,true
        tb_Draw,true
        tb_Edit,true
        tb_Array,true
        tb_Wall,true
        tb_Staircase,true
        tb_Win,true
        tb_Roof,true
        point_on_face,true
        divide,true
        align,true
        perpendicular_line,true
        fonplane,true
        bestface,true
        extrude1,true
        extrude2,true
        move_vertex,true
        fillet,true
        chamfer,true
        extend,true
        offset_edge,true
        hline_faces,true
        slopeedges,true
        linear_array,true
        rect_array,true
        polar_array,true
        vx_wall,true
        opening,true
        hgroove,true
        staircase1,true
        staircase2,true
        staircase3,true
        staircase4,true
        spiralstair,true
        escalator,true
        wframe,true
        dframe,true
        paneldivide,true
        screen1,true
        hlouvres,true
        vlouvres,true
        rafter1,true
        roof1,true
        hiproof,true
        revsurf,true
        rgrille,true
        cgrille,true
        loading 1001bitmenu >> true
        "English"
        I, [2022-11-11T09;26;56.049506 #6024]  INFO -- datasmith; Loading 'C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/plugin_main.rb'...
        I, [2022-11-11T09;26;56.053087 #6024]  INFO -- datasmith; Loading plugin binary module from C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/DatasmithSketchUp.so
        I, [2022-11-11T09;26;56.063538 #6024]  INFO -- datasmith; Engine Path; 'C;\ProgramData\Epic\Exporter\SketchUpEngine\', Enable UI; true
        I, [2022-11-11T09;26;56.436781 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
        License expiration; 2022-09-15 15;21;59 UTC, Left; -57 days
        INFO; container(features) created... [Plugin.Application]
        INFO; app created... [Plugin.Application]
        IsLoaded; false
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;17; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;18; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;19; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;20; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;21; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;22; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;23; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;24; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;25; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;26; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;27; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;28; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;29; warning; encountered \r in middle of line, treated as a mere space
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;30; warning; encountered \r in middle of line, treated as a mere space
        true
        E;/2022/Tools/RubyStdLib/SecureRandom.rb;309; warning; already initialized constant Random;;Formatter;;ALPHANUMERIC
        E;/2022/Tools/RubyStdLib/securerandom.rb;309; warning; previous definition of ALPHANUMERIC was here
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/f3d_flextools/main.rbe;4362; warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
        [D5 Converter] light data restored from attribute.
        I, [2022-11-11T09;27;02.901161 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_rotate/utils.rbe;358; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe;374; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
        Error; #<ArgumentError; wrong number of arguments (given 1, expected 0)>
        C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/rhino_inside_su.rb;148;in `load'
        eval;1;in `block in use_libraries'
        eval;1;in `each'
        eval;1;in `use_libraries'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `general_init'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `use_libraries'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe;73;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `initialize__'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;160;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `show'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;66;in `time_for_check?'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;453;in `block in after_startup'
        Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;445;in `invoke_quick_launcher'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;291;in `block in configure'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
        LAUNCHER TEM 9196708826.464672
        "Add help menu!"
        "create new"
        "created"
        #<Sketchup;;Menu;0x00000234debaa670>
        (eval);23; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
        "Add help menu!"
        "created"
        Error; #<NoMethodError; undefined method `add_item' for nil;NilClass>
        (eval);40;in `block in <module;Help>'
        "created"
        (eval);199;in `block in <module;Notification>'
        LAUNCHER TEM 9196708866.898788
        Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfe10cd0>>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;876;in `param_load'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;366;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;240;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `launch'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;176;in `action__mapping'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;103;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;119;in `block in startup'
        Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bdc51a90>>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;246;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `launch'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;120;in `block in startup'
        Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfbc7b40>>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;132;in `invoke_quick_launcher'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;103;in `block in startup'
        LAUNCHER TEM 9196708988.201132
        Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234c007c820>
        Did you mean?  validate_current_selection>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;553;in `notify_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;584;in `terminate_current_selection'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;745;in `notify_from_vbox'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `call'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `onLButtonUp'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;2486;in `onLButtonUp'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;1152;in `onLButtonUp'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;508;in `onLButtonUp'
        LAUNCHER TEM 9196709028.635246
        Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234bf204068>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;279;in `execute_validate'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;450;in `onReturn'
        LAUNCHER TEM 9196710848.170437
        Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
        c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
          Do you have the newest versions of LibFredo and the SketchUcation toolset installed and SketchUp restarted ?
          Other extensions loading seem to be having issues, so they could be causing problems with Fredo's files loading subsequently...
          Have you tried disabling the other extensions named, and restarting SketchUp to see if that helps ?
          • I Offline
            igorassis
            it worked, thanks
            • Stephane_14S Offline
              Stephane_14
              Bonjour,
              Les plugins de Fredo6 n’affiches plus les icĂŽnes puis j'ai remarquĂ© que ExtensionStore V.429 n’ Ă©tĂ© plus branchĂ© Ă  internet avec mes identifiants, Cela est rĂ©solu mais c'est Ă©tonnant.
              Autre soucis depuis la mise à jour de FredoLib V3.5a l'utilisation de Curviloft provoque un Plantage systématique de Sketchup.
              Avez vous des explications ?
              Cordialement
              Hello,
              The Fredo6 plugins no longer display the icons then I noticed that ExtensionStore V.429 was no longer connected to the internet with my credentials, This is resolved but it's surprising.
              Another concern since the update of FredoLib V3.5a the use of Curviloft causes a systematic crash of Sketchup.
              Do you have any explanations?
              Cordially
              Stéphane HENRY
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v13.6a - 29 Nov 22
                LibFredo6 13.6a includes:
                • bug fixing for potential problems at startup
                • Bug fixing about selection contextual menu (for LOTT and FredoSpline)
                • support for future compatibility
                It is strongly advised to upgrade to this version
                  Bilinmez
                  Hello,
                  PayPal is forbidden in our country, Turkey. How can I buy these plugins with another payment method?
                  Thank you.
                    See https://sketchucation.com/forums/viewtopic.php?f=323&t=75165
                      rhelton
                      If we now have to PAY for the extensions could we at least get Automatic Updates to the Extensions so I Do Not have to keep logging in and updating Lib Fredo manually every time I turn around !!!!!
                        https://i.imgur.com/ZXGP3tn.png
                        You turn around once every ~2 weeks?
                          tibooobit
                          Thanks for the update of LibFredo6- v13.6a, but I got a problem with the update, or maybe because of my new laptop -> macbook 16" M1 2021.
                          I use a Sketchup Pro 2019 licence.
                          Sketchup 2019 + Uptodate Libfredo plugins are installed on my old macbook pro 2010 Intel i7 and my new macbook 2021 M1 both.
                          Only my old macbook is able to launch Libfredo plugins 😕
                          In my new macbook : Libfredo window is not showing, and plugin button are not clickable.
                          [attachment=0:1g7i275x]<!-- ia0 -->Capture d’écran 2023-01-09 Ă  10.57.25.png<!-- ia0 -->[/attachment:1g7i275x]
                          I really like LibFredo Plugin (animator, round corner, push pull...). Do you think that a futur update will resolve the problem ?
                          Ruby console (when I launch Libfredo window) on M1 macbook :
                          Error: #<NameError: uninitialized constant G6::G6B>
                          /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4952:in mouse_init' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4995:in option_down?'
                          /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5016:in ctrl_down?' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe:2117:in animation_navigate_allowed?'
                          /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe:2121:in animation_navigate_or_play' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatorpalette.rbe:227:in block in palette_button_play'
                          /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4076:in execute_button' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3830:in onLButtonUp'
                          /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe:1283:in onLButtonUp'
                          Error: #<NoMethodError: undefined method `wdlg_from_key' for Traductor::Wdlg:Class>
                          Thanks for your answer !
                          Tibo
                          Ruby console - Libfredo
                            Do you have the current version of the Sketchucation Tool installed?
                            Keep in mind that SketchUp 2019 will never be updated to support the newer Mac OS or M1. It seems like many users of older versions of SketchUp are reporting problems.
                            BTW, your profile indicates you are still using SketchUp 2013 Make. Please update your profile.
                            • fredo6F Offline
                              LibFredo6 normally supports Mac M1.
                              The problem you have is that the binary part of LibFredo6 does not load correctly.
                              What I would suggest is that you delete the LibFredo6 folder from the Plugins directory, reboot your Mac, reinstall LibFredo6 v13.6a (a restart of Sketchup afterward).
                                tibooobit
                                Thanks for your answer.
                                Sketchucation tool : nice, I didn't know the plugin.
                                I installed it, but no better result 😞
                                I installed last sketchup pro trying version on the M1 mac : Lifredo plugins work.
                                But I would like to keep my perpetual licence of sketchup pro 2019 (= the last perpetual licence version !). I am not interested in paying every year the same price of my SKP 2019 perpetual licence...
                                I will delete Libfredo6 folder and reinstall the plugin as suggest.
                                Other, I update my profil, thanks.
                                  tibooobit
                                  I delete all my plugin in the plugin folder.
                                  I reinstall Lifredo6, restart computer, relaunch SKP...
                                  But the bug is still here (images in attachment): when I click on "Libfredo6 - configuration" -> look for update, nothing appened (error ruby).
                                    It is a requirement for many of Fredo's extensions. You should be using it to install extensions from Sketchucation.
                                    Understood. You just have to accept that the Mac OS and hardware are evolving out from under SketchUp 2019. The kinds of reports that we're seeing regarding older versions of SketchUp with newer Mac operating systems and hardware makes it evident that at some point you can expect older applications to at least become very unreliable. Eventually web-based features like the 3D Warehouse and Geo-Location services will stop supporting SketchUp 2019, as well.
                                    You can continue to use SU 2019 but if it's part of your business, you should be aware of the implications so you aren't caught short later on.
                                    Thank you. With that information being correct and complete it makes it easier for us to help you. BTW, could you add the Mac OS version number?
                                    • fredo6F Offline
                                      I looked at my code and the explanation is actually very simple
                                      Mac M1 is only supported for extensions for SU2021 and above, for which Trimble has published a binary library of Ruby for Mac M1 (Ruby 2.7).
                                      Therefore my plugins (and probably others using binary code) do NOT work on SU2019.
                                        This is good information to know. Thank you.
                                        @tibooobit, this is further confirmation of what I had already described wherein the Mac hardware and OS have evolved beyond what SU2019 supports.
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v13.7a - 18 Jan 23
                                          LibFredo6 13.7a includes:
                                          • Support for FredoSketch v1.1a
                                          • Bug fixing
                                          • Support for future compatibility
                                          • H Offline
                                            Hairman
                                            Hi Fredo6,
                                            I updated Libfredo6 yesterday because of your new FredoSketch extension. First tried with window-Libfredo settings-check for fredo6 plugin updates and was surprised that it said that everything was up to date. Libfredo6 version was 13.6..
                                            When checking with the sketchucation tool it said there was an update for Libfredo6.
                                            Just wanted to give you a heads up..
                                            Thanks for all your work and fantastic extensions!
                                            Herman.
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 109
                                            • 110
                                            • 49 / 110
