    Overhead Line Shaft Detail
    44 Posts 12 Posters 8.5k Views 12 Watching
      I'm not exactly sure what this is used for but I made a model of it anyway. The handle drives the ratchet wheel which drive the pointy bit on top upward. There's a tapered squre hole on the bottom of the handle which would appear to allow the handle to sit on something. I presume the pointing bit is used to split something.
      https://live.staticflickr.com/65535/52404988741_b98d69b420_c.jpg
      And a cut-away view showing the threads and the rachet wheel and pawl.
      https://live.staticflickr.com/65535/52405494888_f96b82d3eb_c.jpg
      • Bryan KB Offline
        Another excellent machine model!
          Mill3rLuke
          @dave r said:
          Here's a detail showing some of the screw threads. Added some color in the render.
          https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
          Do you do this for a living?
            Do what? Make 3D models in SketchUp? Yes. This model is an assembly of a bunch of separate parts I modeled mostly for my own entertainment and to practice using SketchUp.
              Mill3rLuke
              No i mean are you a designer by profession? do you make you income from designing etc?
                I do some design work, mostly furniture design.
                  https://live.staticflickr.com/65535/52432984724_50577dc3c7_k.jpg
                  • Bryan KB Offline
                    Small pipe cutter!
                    Another excellent model. πŸ‘
                    • ntxdaveN Offline
                      ntxdave
                      @bryan k said:
                      Small pipe cutter!
                      Ditto πŸ‘ πŸ‘
                      Press F1...thank me later
                      • boofredlayB Offline
                        boofredlay
                        πŸ‘
                        • marked001M Offline
                          marked001
                          Great stuff.
                          http://www.revision21vis.com
                          instagram: revi21on
                            Very sharp. πŸ‘
                              This might be a little overkill for a steam powered woodworking shop but...
                              Still some work to do on it.
                              Larger version here: https://flic.kr/p/2nWvdDm
                              • 3 / 3
