    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 626.8k Views 151 Watching
      Your SCF Licensing is not the latest. It should be 5.7a - 51
      https://i.imgur.com/RdGTjnd.png
      Not sure why v.4.2.9 of Sketchucation Tools did not update your license binaries but you are not using the latest. Try removing sketchucation.rb and the sketchucation folder from your plugins folder and doing a fresh install.
        Dgx1
        Thanks Rich. That worked. Back to Rounding corners the easy way.
          kiwi7379
          I have issues using my FredoCorner too...
          I purchased the FredoCorner in December 2021, it worked for a while and it stopped working and I keep getting this message no matter how many times I have re-downloaded the SketchUcation Extension Store. Can someone help?
            Make sure Sketchucation Tools is v4.2.9 and that both LibFredo and FredoCorner are updated.
            Failing that a fresh install of all 3 should resolve it.
              Armin_Beier
              Trial Period ended immediatly after using it for the first try. Telling me a date a year ago... I never used SketchUp and/or any extensions for it prior to two weeks.
              Tried the other Bevel extension, samem result. Wouldnt even let me use it once, but immediatly said that the trial period is over since a couple months.
              I am using SketchUp only to visualize achitecture in V-Ray and I am amazed that such a simple function like bevels and corners arent included but behind a paywall.
              *Same Message as for "RoundCorner" because exact same problem.
                Bortoluzzi
                Hello, i love your Plugins, unfortunately im brazilian and $25,00 its a lot of money in my country. Cant u do it for a little less to help a brother?
                Dolar is almost 6 times the value of brazil's coin, that means i need to pay R$130,00 for ir.
                  mr_incredible
                  I paid for and have the perpetual license for freoocorne, but it doesnt' recognoze my license.
                    Can you show the error message you get when you try to apply the license?
                    Are you certain you have a license for FredoCorner and not Round Corner?
                      You purchased FredoBundle that doesn't include license for FredoCorner.
                        belrog
                        Hello,
                        I've been having a problem lately. After activating the plugin a message appears " To continue using extension FredoCorner, please upgrade to the latest version of Sketchucation ExtensionSore ".
                        Then the command is disabled and FredoCorner cannot be used. I have the latest version installed (2.5a 16.jan 2022). I have also purchased a license.
                        What could be the problem? Please provide a solution.
                        Otherwise the plugin has always been a good helper.
                        Thank you
                        Translated with http://www.DeepL.com/Translator (free version)
                          You need to install the latest version of the Sketchucation ExtensionStore. Assuming you already have a version of it installed, you can search for it and install the current version. After that, quit and restart SketchUp. If you don't already have it installed, you can get it from this link.
                          What version of SketchUp are you using? What operating system? Please complete your profile.
                          • H Offline
                            HansSchat
                            Hello Fredo,
                            I decided to try out Fredocorner for the first time (I'm quite sure) but I got a message that my tryout periode is already done. I have a round corner license and wanted to checkout the differences and features.
                            Just to let you know but a little tryout periode would be nice.
                            Kind regards,
                            Hans Schat
                            • fredo6F Offline
                              Could you first upgrade to LibFredo6 v13.4a.
                                manonschuitema
                                Thank you for FredoCorner, it's a fantastic plugin! One question: i'm presently designing shapes in which it is sometimes necessary to use super rounding, and sometimes the corner would look better without it. Is it possible to apply Super Rounding to selected corners only? The shapes are letters (molds actually), and need to be rounded in one go to get good results, so I can't split up the rounding process into several steps.
                                If not, it's not big issue, but I thought I'd ask in case I missed something in your tutorial videos.
                                Raoul
                                  billwright1984
                                  Please help. I love this tool and would like to purchase a license. I've downloaded the SU store extension ... but do not see any place to purchase a license. All of the instructions show screens that I do not see. How do I get to the license purchase screen?
                                  Thanks,
                                  Bill W>
                                    In SketchUp go to Extensions > Fredo Collection > Fredo Corner > License
                                    In the dialog click Obtain License
                                    Or...
                                    SketchUcation | List of Plugin Licences
                                    (sketchucation.com)
                                    Or...
                                    SketchUcation | Cart
                                    (sketchucation.com)
                                      Or Tools > Fredo Collection...
                                        jweaver100
                                        Any chance of a Black Friday sale this year? I missed out on last summers sale and since I only a casual user of Sketchup, I am holding out for a good deal...
                                          Rafał Płatek
                                          I'm joining the question:
                                          Is there any chance of a discount with the Black Friday sale? 😉
                                            svideo
                                            I'm not sure what I did that preceded this, but sometime this morning FredoCorner stopped working for me. When I click on the icons in the toolbar (any of them), nothing at all seems to happen.
                                            Details:
                                            • Paid user for the Fredo6 collection
                                            • SU2022 Pro, Windows 11
                                            • LibFredo6 13.2a installed
                                            • Other Fredo tools seem to work as expected
                                            Process:
                                            • Uninstalled Fredo6 FredoCorner
                                            • Downloaded latest copy from sketchUcation
                                            • Installed via Extension Manager
                                            • Restart SketchUp
                                            • Find new FredoCorner toolbar as expected
                                            • Create rectangle, push/pull to extrude, select top face
                                            • Select FredoCorner icon, nothing happens
                                            • Select Tools > Fredo6Collection > FredoCorner > Round, nothing happens. Same result with any other FredoCorner operations.
                                            • Select Tools > Fredo6Collection > FredoScale > Box Scaling (as an example), I get the selection tool and can use the extension as expected.
                                            • Select Tools > Fredo6Collection > FredoCorner > License, I get the license window with a green "OK", license type "NORMAL", validity "Infinite"
                                            Other observations:
                                            • Select Tools > Fredo6Collection > FredoCorner > About Fredo Corner 2.5a does nothing. Selecting About for another Fredo tool (eg, Curviloft) also does nothing. No way to get an "about" message I guess.
                                            Any suggestions would be great, I'm stuck at an impasse here and not sure how to proceed.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
