    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • fredo6F
      @dgx1 said:
      Hello.
      I've been getting a error message " To continue using the extension fredo corner, please upgrade to the latest version of Sketchucation Extension Store" which I am on per extension manager. also checked the license and Lib 6. all good. any thoughts whats up ?
      Could you show me a screenshot of the License Dialog box?
      or type in the Ruby console: SCFLicense.visual_version
      Which version of LibFredo6 do you have?
        Dgx1
        License Dialog.jpgLibFredo 6.jpgHey Fredo , see attached screenshots as requested please. And Thank you.
          Your SCF Licensing is not the latest. It should be 5.7a - 51
          https://i.imgur.com/RdGTjnd.png
          Not sure why v.4.2.9 of Sketchucation Tools did not update your license binaries but you are not using the latest. Try removing sketchucation.rb and the sketchucation folder from your plugins folder and doing a fresh install.
            Dgx1
            Thanks Rich. That worked. Back to Rounding corners the easy way.
            • K
              kiwi7379
              I have issues using my FredoCorner too...
              I purchased the FredoCorner in December 2021, it worked for a while and it stopped working and I keep getting this message no matter how many times I have re-downloaded the SketchUcation Extension Store. Can someone help?
                Make sure Sketchucation Tools is v4.2.9 and that both LibFredo and FredoCorner are updated.
                Failing that a fresh install of all 3 should resolve it.
                  Armin_Beier
                  Trial Period ended immediatly after using it for the first try. Telling me a date a year ago... I never used SketchUp and/or any extensions for it prior to two weeks.
                  Tried the other Bevel extension, samem result. Wouldnt even let me use it once, but immediatly said that the trial period is over since a couple months.
                  I am using SketchUp only to visualize achitecture in V-Ray and I am amazed that such a simple function like bevels and corners arent included but behind a paywall.
                  *Same Message as for "RoundCorner" because exact same problem.
                  • B
                    Bortoluzzi
                    Hello, i love your Plugins, unfortunately im brazilian and $25,00 its a lot of money in my country. Cant u do it for a little less to help a brother?
                    Dolar is almost 6 times the value of brazil's coin, that means i need to pay R$130,00 for ir.
                      mr_incredible
                      I paid for and have the perpetual license for freoocorne, but it doesnt' recognoze my license.
                        Can you show the error message you get when you try to apply the license?
                        Are you certain you have a license for FredoCorner and not Round Corner?
                          You purchased FredoBundle that doesn't include license for FredoCorner.
                          • B
                            belrog
                            Hello,
                            I've been having a problem lately. After activating the plugin a message appears " To continue using extension FredoCorner, please upgrade to the latest version of Sketchucation ExtensionSore ".
                            Then the command is disabled and FredoCorner cannot be used. I have the latest version installed (2.5a 16.jan 2022). I have also purchased a license.
                            What could be the problem? Please provide a solution.
                            Otherwise the plugin has always been a good helper.
                            Thank you
                            Translated with http://www.DeepL.com/Translator (free version)
                              You need to install the latest version of the Sketchucation ExtensionStore. Assuming you already have a version of it installed, you can search for it and install the current version. After that, quit and restart SketchUp. If you don't already have it installed, you can get it from this link.
                              What version of SketchUp are you using? What operating system? Please complete your profile.
                              • H
                                HansSchat
                                Hello Fredo,
                                I decided to try out Fredocorner for the first time (I'm quite sure) but I got a message that my tryout periode is already done. I have a round corner license and wanted to checkout the differences and features.
                                Just to let you know but a little tryout periode would be nice.
                                Kind regards,
                                Hans Schat
                                • fredo6F
                                  Could you first upgrade to LibFredo6 v13.4a.
                                    manonschuitema
                                    Thank you for FredoCorner, it's a fantastic plugin! One question: i'm presently designing shapes in which it is sometimes necessary to use super rounding, and sometimes the corner would look better without it. Is it possible to apply Super Rounding to selected corners only? The shapes are letters (molds actually), and need to be rounded in one go to get good results, so I can't split up the rounding process into several steps.
                                    If not, it's not big issue, but I thought I'd ask in case I missed something in your tutorial videos.
                                    Raoul
                                    • B
                                      billwright1984
                                      Please help. I love this tool and would like to purchase a license. I've downloaded the SU store extension ... but do not see any place to purchase a license. All of the instructions show screens that I do not see. How do I get to the license purchase screen?
                                      Thanks,
                                      Bill W>
                                        In SketchUp go to Extensions > Fredo Collection > Fredo Corner > License
                                        In the dialog click Obtain License
                                        Or...
                                        SketchUcation | List of Plugin Licences
                                        (sketchucation.com)
                                        Or...
                                        SketchUcation | Cart
                                        (sketchucation.com)
                                          Or Tools > Fredo Collection...
                                            jweaver100
                                            Any chance of a Black Friday sale this year? I missed out on last summers sale and since I only a casual user of Sketchup, I am holding out for a good deal...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
