    More Stairs
    25 Posts 7 Posters 6.9k Views 7 Watching
    • tuna1957T
      tuna1957
      Thanks ntxdave 👍
      faust07 , appreciate the concern about the first step. am well aware of code issues but I’m doing my spin on a somewhat
      famous stairs and that’s how they are in the reference…. 👍
      • tuna1957T
        tuna1957
        A couple of progress shots. Figured someone might be interested in how I set up these odd little renders….. Getting down to the nitty gritty. Adjusting things hear and there. Trying out texture setups… deciding how much stuff to add and messing about with scenes for final rendering. 😎
        • HornOxxH
          HornOxx
          good! 👍
          never trust a skinny cook
            All this is missing is The Joker...
            https://i.imgur.com/Bq2XM4C.png
            • Bryan KB
              Very nice! This should turn out great when rendered! 👍
              • tuna1957T
                tuna1957
                HornOxx, Bryan thanks guys 👍
                Rich what it’s really missing is Father Damien sprawled at the foot of the stairs 😉 😎
                  Little lo-poly Joker for you.... 😆 😆
                  https://i.imgur.com/2Bx5sgN.png
                  joker-stairs.skp
                  • tuna1957T
                    tuna1957
                    Rich, Thanks for posting up the Joker 👍
                    • ntxdaveN
                      ntxdave
                      Once last (stupid) suggestion. Add Rich’s joker to your stairs and render and then use FotoSketche to produce a wild oil painting. Could be kind of neat IMHO.
                      Okay, I get the message. I will quit suggesting this type of stuff. 🤓
                      Press F1...thank me later
                      • tuna1957T
                        tuna1957
                        A little update. Models pretty well finished. Now down to experimenting with texture setups, scenes and lighting for some renders. 👍
                        • ntxdaveN
                          ntxdave
                          Liking where you are headed with this, looking forward to where you go with it. 👍
                          • tuna1957T
                            tuna1957
                            Thanks ntxdave. Dumb me didn’t realize the last pic I posted is pretty much the same as an earlier pic…. Ohh well….
                            Suspect it’ll be awhile on renders, spending a lot of time adjusting material setups in Twilight and deciding on views and lighting. Starting to make myself a bit crazy 😲
                            • ntxdaveN
                              ntxdave
                              Another silly suggestion. This is the type of scene (when completed) that could make a neat oil painting. When you get your render done, I would like to see what you could create using FotoSketcher. Again, only after you have created a neat Twkight Render image. 😆
                              • tuna1957T
                                tuna1957
                                At ntxdave’s request…. Here’s a quick and dirty N.P.R. image of the stairs…..if anyone is interested here’s what I did…..
                                Saved a raw SU image of the scene, shaded with textures, shadows turned off…same size as render, save as .png
                                Ran the raw SU image through “PhotoSketcher” a Mac app, created a B&W pencil sketch, gave the image a cream colored background. Saved as .png
                                Imported the “pencil sketch” and render into Affinity Photo. Pencil sketch on top. Set the “sketch” as an overlay. Also did a minor blend adjustment to the sketch. Ran a light blur on the rendered image and a shadows and highlights adjustment. And there you have it. Quick and dirty….. 😎
                                • tuna1957T
                                  tuna1957
                                  Here’s another N.P.R. image…. Only difference in this one is I added another render image that I ran through Topaz Impression to get a watercolor look. Messed about with the different layers in Affinity and there you have it. 😎
                                  • ntxdaveN
                                    ntxdave
                                    Interesting tuna. 👍
                                    Now would be interesting to see it as an oil painting.
                                    • HornOxxH
                                      HornOxx
                                      👍 👍 a great scene and great result!
                                      • tuna1957T
                                        tuna1957
                                        Thanks ntxdave and HornOxx. I suspect I’ll be fooling around with this for awhile. Going to try different scene views etc. Think I’m going to experiment with some night renders also. 👍 😎
                                        • Bryan KB
                                          That turned out very nice!
                                          • tuna1957T
                                            tuna1957
                                            Thanks Bryan 👍
