    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      After some further thought to window and door casings (interior trim) I realized it would be useful to enable a system whereby the user could essentially create their own profiles and add them into the plugin (library folder) themselves.
      I will probably include some pre-added profiles like the 365 and a few other common ones, but this way it will be much more flexible for the user and customizable.
      https://aws1.discourse-cdn.com/sketchup/original/3X/4/0/4012ef82410fc508df0062d1591dc52dae72a55c.jpeg
      I will start with the door casings first and then add this feature to the window module after.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        First look at custom casings:
        https://aws1.discourse-cdn.com/sketchup/original/3X/2/2/22874a82fbeb911bdc48033e05bfefec73819d3b.jpeg
        https://aws1.discourse-cdn.com/sketchup/original/3X/6/3/6374f37c55c6383eb8a021f9ca1f3966e00df91b.jpeg
        Notice that when CUSTOM casing is specified for the Casing Style, the edit or draw menu will provide a preview of the profile as shown.
        Now I need to work on enabling this for arched doors and also updating the global settings with this new option.
        design.medeek.com
        • medeekM
          medeek
          Version 2.9.4 - 08.05.2022
          • Enabled CUSTOM door casings for rectangular doors.
          • Added a thumbnail preview into the edit and draw door menus showing the custom casing profiles.
          • Added a thumbnail preview into the Door tab of the Global Settings and added the custom profile parameter.
          http://design.medeek.com/resources/wallplugin/images4/wall_su648_800.jpg
          http://design.medeek.com/resources/wallplugin/images4/wall_su649_800.jpg
          Additional profiles can be added into the "casings" sub-folder of the "library" folder within the plugin folder. Placement of the profile is important, so best practice is to open one of the two examples within this sub-folder and duplicate its positioning and grouping.
          I will still need to enable this feature for arched doors and all window types, so much more work is yet to be done in this regard. It seems there is never a lack of work when it comes to this plugin.
          design.medeek.com
          • medeekM
            medeek
            Version 2.9.5 - 08.06.2022
            • Enabled CUSTOM door casings for arched doors.
            • Added CUSTOM D and CUSTOM F door casing options for rectangular doors.
            http://design.medeek.com/resources/wallplugin/images4/wall_su650_800.jpg
            http://design.medeek.com/resources/wallplugin/images4/wall_su651_800.jpg
            design.medeek.com
            • medeekM
              medeek
              Version 2.9.6 - 08.07.2022
              • Added STYLE G and CUSTOM G casing options for rectangular doors.
              http://design.medeek.com/resources/wallplugin/images4/wall_su653_800.jpg
              I had to add in these two styles since they are used in our own home. I think I have finally beaten this horse to death but if there are any other styles you feel should be added please feel free to contact me or post them here.
              The profile for the upper molding is found in the "system" sub-folder of the "library" folder. It can be edited and customized by the user. The file name is: CM_HEADER.skp
              design.medeek.com
              • medeekM
                medeek
                First look at Style G applied to a window:
                https://aws1.discourse-cdn.com/sketchup/original/3X/a/e/ae75519ca5908b72904a3969fcbd1c67ea1bdeca.jpeg
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.9.7 - 08.09.2022
                  • Enabled the following CUSTOM casings for rectangular windows: CUSTOM, CUSTOM D, CUSTOM F, CUSTOM G.
                  • Added a thumbnail preview into the edit and draw window menus showing the custom casing profiles.
                  • Added a thumbnail preview into the Window tab of the Global Settings and added the custom profile parameter.
                  • Added a STYLE G casing option for rectangular windows.
                  • Fixed a compatibility bug with CUSTOM door casings.
                  http://design.medeek.com/resources/wallplugin/images4/wall_su655_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.9.8 - 08.13.2022
                    • Added a "Label Rotation" parameter for all wall types (0 or 180 degrees).
                    • Added a default "Label Rotation" parameter into the General tab of the Global Settings.
                    http://design.medeek.com/resources/wallplugin/images4/wall_su658_800.jpg
                    http://design.medeek.com/resources/wallplugin/images4/wall_su657_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Tutorial 31 - Custom Window and Door Casings (15:42 min.)
                      It's crazy to think that about seven years ago I started these plugins (Oct. 2015) and really had no idea where this might go. With the SketchUp API I've managed to turn SketchUp into a program or environment where you can automatically generate architectural geometry that would normally take a program like Revit or Chief Architect. The API along with the full Ruby language essentially makes it possible to customize SketchUp in just about any way possible, which is what makes it so powerful and fun to tinker with.
                      Thank-you SketchUp and all the people along the way who created this amazing 3D drawing environment and for me a programmer's paradise.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.9.9 - 08.21.2022
                        • Enabled an option to specify the location of beam pocket king studs for in-wall columns: LEFT, RIGHT, BOTH.
                        • Fixed a number of minor bugs related to in-wall columns.
                        http://design.medeek.com/resources/wallplugin/images4/wall_su660_800.jpg
                        design.medeek.com
                        • gullfoG
                          gullfo
                          one thought - setting o.c. for column space - e.g. columns on 8' o.c. for a 24' wall could accommodate 4 columns (each end + spaced 8'). as an example, my personal DC wall assemblies, i would make 3 separate sections.
                          Glenn
                          http://www.runnel.com
                          • medeekM
                            medeek
                            Version 3.0.1 - 09.03.2022
                            • Added a "Label Location" parameter for windows: AUTO, INT, EXT.
                            • Added a "Label Location" parameter for doors: AUTO, INT, EXT.
                            http://design.medeek.com/resources/wallplugin/images4/wall_su662_800.jpg
                            http://design.medeek.com/resources/wallplugin/images4/wall_su661_800.jpg
                            You can now manually configure the window and door labels to be on the interior or exterior of the wall on a per opening basis. The feature added per customer request.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.0.2 - 09.05.2022
                              • Enabled custom materials for wall framing within the global settngs.
                              • Enabled custom materials within the "Wall Framing Material" parameter for all wall types.
                              http://design.medeek.com/resources/wallplugin/images4/wall_su663_800.jpg
                              http://design.medeek.com/resources/wallplugin/images4/wall_su664_800.jpg
                              With this update you are no longer constrained to set number of material/texture options for the wall framing. You can now use your own custom material for wall framing. The update was also per customer request.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.0.2b - 09.06.2022
                                • Fixed a bug with wall presets introduced with the addition of the Label Rotation parameter from Version 2.9.8.
                                !!!! CRITICAL BUG FIX !!!!
                                This bug affects wall presets within the "Draw" menu only. The issue was already correct in the "Edit" menu. I strongly encourage everyone to upgrade to this version of the plugin if you have Version 1.9.8 or later currently installed.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.0.3 - 09.12.2022
                                  • Reorganized the door draw and edit menus to include an annotations section.
                                  • Added a "door swing angle" parameter for single and double doors.
                                  • Added the door swing angle parameter to the Door tab of the global settings.
                                  http://design.medeek.com/resources/wallplugin/images4/wall_su666_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images4/wall_su667_800.jpg
                                  The preset angles are: 30, 45, 60, 90, 120, 135. The door swing angle for the door symbol can be set on a per door basis and can also be set to a default value within the global settings. This update per customer request.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.0.4 - 09.15.2022
                                    • Added XPS foam insulation as a built-in cavity insulation option.
                                    • Added XPS foam insulation as a built-in sheathing option.
                                    http://design.medeek.com/resources/wallplugin/images4/wall_su668_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images4/wall_su669_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images4/wall_su670_800.jpg
                                    In the material folder I've also included a zero-border version that can be utilized as a custom material.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I will be running a thanksgiving promotion beginning Nov. 23rd until Dec. 1st. with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS22.
                                      This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately or for the electrical plugin. The offer ends on Dec. 1 and no rain checks will issued thereafter.
                                      design.medeek.com
                                      https://design.medeek.com/ads/BLACKFRIDAY22_BANNER_800.jpg
                                      I will also be running a separate renewal promotion for existing customers, the details will be sent out in a bulk email.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Due to popular demand I have decided to extend the renewal and mdkBIM promotion until Dec. 5, 2022.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.0.5 - 12.15.2022
                                          • Enabled auto-dimensioning for plan views of all wall panels.
                                          • Added the "Dimension Offset 2" and "Plan Dimensions" parameters to the General tab of the global settings.
                                          • Updated the Add Material and Edit Material HTML menus so that commas cannot be used in Custom Material names.
                                          http://design.medeek.com/resources/wallplugin/images4/wall_su671_800.jpg
                                          http://design.medeek.com/resources/wallplugin/images4/wall_su672_800.jpg
                                          Note that framing dimensions (elevations) and plan dimensions (plan view) can be turned on and off independent of each other in the global settings. Also the additional offset parameters allows one to adjust both offsets independently as well. However both dimensions are placed on the same layer (at least for now).
                                          Currently the plan view dimension option will assign an overall dimension for the wall length and then separate dimensions for windows, doors and garage doors. I do not have it inserting dimensions for more custom features like Simpson Strong Walls or in-wall columns.
                                          This new feature is per customer request.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.0.6 - 12.28.2022
                                            • Added a "Jamb Interior" parameter into the Draw and Edit menus for doors.
                                            • Enabled this parameter for both rectangular and arched doors.
                                            • Added this parameter to the Doors tab of the Global Settings.
                                            http://design.medeek.com/resources/wallplugin/images4/wall_su675_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images4/wall_su676_800.jpg
                                            This update was per my previous notes and per customer request.
                                            design.medeek.com
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 80
                                            • 81
                                            • 63 / 81
