    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 2.9.4 - 08.05.2022
      • Enabled CUSTOM door casings for rectangular doors.
      • Added a thumbnail preview into the edit and draw door menus showing the custom casing profiles.
      • Added a thumbnail preview into the Door tab of the Global Settings and added the custom profile parameter.
      http://design.medeek.com/resources/wallplugin/images4/wall_su648_800.jpg
      http://design.medeek.com/resources/wallplugin/images4/wall_su649_800.jpg
      Additional profiles can be added into the "casings" sub-folder of the "library" folder within the plugin folder. Placement of the profile is important, so best practice is to open one of the two examples within this sub-folder and duplicate its positioning and grouping.
      I will still need to enable this feature for arched doors and all window types, so much more work is yet to be done in this regard. It seems there is never a lack of work when it comes to this plugin.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.9.5 - 08.06.2022
        • Enabled CUSTOM door casings for arched doors.
        • Added CUSTOM D and CUSTOM F door casing options for rectangular doors.
        http://design.medeek.com/resources/wallplugin/images4/wall_su650_800.jpg
        http://design.medeek.com/resources/wallplugin/images4/wall_su651_800.jpg
        design.medeek.com
        • medeekM
          medeek
          Version 2.9.6 - 08.07.2022
          • Added STYLE G and CUSTOM G casing options for rectangular doors.
          http://design.medeek.com/resources/wallplugin/images4/wall_su653_800.jpg
          I had to add in these two styles since they are used in our own home. I think I have finally beaten this horse to death but if there are any other styles you feel should be added please feel free to contact me or post them here.
          The profile for the upper molding is found in the "system" sub-folder of the "library" folder. It can be edited and customized by the user. The file name is: CM_HEADER.skp
          design.medeek.com
          • medeekM
            medeek
            First look at Style G applied to a window:
            https://aws1.discourse-cdn.com/sketchup/original/3X/a/e/ae75519ca5908b72904a3969fcbd1c67ea1bdeca.jpeg
            design.medeek.com
            • medeekM
              medeek
              Version 2.9.7 - 08.09.2022
              • Enabled the following CUSTOM casings for rectangular windows: CUSTOM, CUSTOM D, CUSTOM F, CUSTOM G.
              • Added a thumbnail preview into the edit and draw window menus showing the custom casing profiles.
              • Added a thumbnail preview into the Window tab of the Global Settings and added the custom profile parameter.
              • Added a STYLE G casing option for rectangular windows.
              • Fixed a compatibility bug with CUSTOM door casings.
              http://design.medeek.com/resources/wallplugin/images4/wall_su655_800.jpg
              design.medeek.com
              • medeekM
                medeek
                Version 2.9.8 - 08.13.2022
                • Added a "Label Rotation" parameter for all wall types (0 or 180 degrees).
                • Added a default "Label Rotation" parameter into the General tab of the Global Settings.
                http://design.medeek.com/resources/wallplugin/images4/wall_su658_800.jpg
                http://design.medeek.com/resources/wallplugin/images4/wall_su657_800.jpg
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 31 - Custom Window and Door Casings (15:42 min.)
                  It's crazy to think that about seven years ago I started these plugins (Oct. 2015) and really had no idea where this might go. With the SketchUp API I've managed to turn SketchUp into a program or environment where you can automatically generate architectural geometry that would normally take a program like Revit or Chief Architect. The API along with the full Ruby language essentially makes it possible to customize SketchUp in just about any way possible, which is what makes it so powerful and fun to tinker with.
                  Thank-you SketchUp and all the people along the way who created this amazing 3D drawing environment and for me a programmer's paradise.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.9.9 - 08.21.2022
                    • Enabled an option to specify the location of beam pocket king studs for in-wall columns: LEFT, RIGHT, BOTH.
                    • Fixed a number of minor bugs related to in-wall columns.
                    http://design.medeek.com/resources/wallplugin/images4/wall_su660_800.jpg
                    design.medeek.com
                    • gullfoG
                      gullfo
                      one thought - setting o.c. for column space - e.g. columns on 8' o.c. for a 24' wall could accommodate 4 columns (each end + spaced 8'). as an example, my personal DC wall assemblies, i would make 3 separate sections.
                      Glenn
                      http://www.runnel.com
                      • medeekM
                        medeek
                        Version 3.0.1 - 09.03.2022
                        • Added a "Label Location" parameter for windows: AUTO, INT, EXT.
                        • Added a "Label Location" parameter for doors: AUTO, INT, EXT.
                        http://design.medeek.com/resources/wallplugin/images4/wall_su662_800.jpg
                        http://design.medeek.com/resources/wallplugin/images4/wall_su661_800.jpg
                        You can now manually configure the window and door labels to be on the interior or exterior of the wall on a per opening basis. The feature added per customer request.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.0.2 - 09.05.2022
                          • Enabled custom materials for wall framing within the global settngs.
                          • Enabled custom materials within the "Wall Framing Material" parameter for all wall types.
                          http://design.medeek.com/resources/wallplugin/images4/wall_su663_800.jpg
                          http://design.medeek.com/resources/wallplugin/images4/wall_su664_800.jpg
                          With this update you are no longer constrained to set number of material/texture options for the wall framing. You can now use your own custom material for wall framing. The update was also per customer request.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.0.2b - 09.06.2022
                            • Fixed a bug with wall presets introduced with the addition of the Label Rotation parameter from Version 2.9.8.
                            !!!! CRITICAL BUG FIX !!!!
                            This bug affects wall presets within the "Draw" menu only. The issue was already correct in the "Edit" menu. I strongly encourage everyone to upgrade to this version of the plugin if you have Version 1.9.8 or later currently installed.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.0.3 - 09.12.2022
                              • Reorganized the door draw and edit menus to include an annotations section.
                              • Added a "door swing angle" parameter for single and double doors.
                              • Added the door swing angle parameter to the Door tab of the global settings.
                              http://design.medeek.com/resources/wallplugin/images4/wall_su666_800.jpg
                              http://design.medeek.com/resources/wallplugin/images4/wall_su667_800.jpg
                              The preset angles are: 30, 45, 60, 90, 120, 135. The door swing angle for the door symbol can be set on a per door basis and can also be set to a default value within the global settings. This update per customer request.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.0.4 - 09.15.2022
                                • Added XPS foam insulation as a built-in cavity insulation option.
                                • Added XPS foam insulation as a built-in sheathing option.
                                http://design.medeek.com/resources/wallplugin/images4/wall_su668_800.jpg
                                http://design.medeek.com/resources/wallplugin/images4/wall_su669_800.jpg
                                http://design.medeek.com/resources/wallplugin/images4/wall_su670_800.jpg
                                In the material folder I've also included a zero-border version that can be utilized as a custom material.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I will be running a thanksgiving promotion beginning Nov. 23rd until Dec. 1st. with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS22.
                                  This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately or for the electrical plugin. The offer ends on Dec. 1 and no rain checks will issued thereafter.
                                  design.medeek.com
                                  https://design.medeek.com/ads/BLACKFRIDAY22_BANNER_800.jpg
                                  I will also be running a separate renewal promotion for existing customers, the details will be sent out in a bulk email.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Due to popular demand I have decided to extend the renewal and mdkBIM promotion until Dec. 5, 2022.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.0.5 - 12.15.2022
                                      • Enabled auto-dimensioning for plan views of all wall panels.
                                      • Added the "Dimension Offset 2" and "Plan Dimensions" parameters to the General tab of the global settings.
                                      • Updated the Add Material and Edit Material HTML menus so that commas cannot be used in Custom Material names.
                                      http://design.medeek.com/resources/wallplugin/images4/wall_su671_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images4/wall_su672_800.jpg
                                      Note that framing dimensions (elevations) and plan dimensions (plan view) can be turned on and off independent of each other in the global settings. Also the additional offset parameters allows one to adjust both offsets independently as well. However both dimensions are placed on the same layer (at least for now).
                                      Currently the plan view dimension option will assign an overall dimension for the wall length and then separate dimensions for windows, doors and garage doors. I do not have it inserting dimensions for more custom features like Simpson Strong Walls or in-wall columns.
                                      This new feature is per customer request.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.0.6 - 12.28.2022
                                        • Added a "Jamb Interior" parameter into the Draw and Edit menus for doors.
                                        • Enabled this parameter for both rectangular and arched doors.
                                        • Added this parameter to the Doors tab of the Global Settings.
                                        http://design.medeek.com/resources/wallplugin/images4/wall_su675_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images4/wall_su676_800.jpg
                                        This update was per my previous notes and per customer request.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Just cleaning up some loose ends before the start of the New Year.
                                          One issue that is sometimes encountered is when a custom material is defined in the Material Library and then after using it in a Wall Preset it is subsequently deleted.
                                          When this happens and that particular Wall Preset is loaded the plugin tries to assign that custom material in the Draw or Edit wall menu. If you try this you will quickly notice the drop down box for the material is blank and no valid material is selected. This inevitably leads to an error either being thrown within the plugin code itself or within the javascript of the HTML menu pages (not sure which at this point).
                                          I need to devise some error checking in the HTML/Javascript to detect this problem if it pops up and gracefully resolve it rather than locking up the plugin. If I can fix this it will not only save the end user from annoying headaches but also eliminate unnecessary support calls and emails for myself.
                                          design.medeek.com
                                          • gullfoG
                                            gullfo
                                            some thoughts -- unless the custom material is saved as an SKM, it has the potential to be purged from the memory space and thus not readily available again (unless some other means of caching it - e.g. a persisted JSON of custom materials containing the RGB values - presumably if images are involved, then saving it as an SKM would seem the better option + may be more compatible in terms of management compared to the built-in materials).
                                            (as a note -- i stopped using materials in my own DC because of the purging etc -- so i just got better at organizing the SKM content. some DC have basic color "materials" applied and then i replace them later, most are default material so i can paint them all quickly)
                                            Glenn
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 80
                                            • 81
                                            • 63 / 81
