    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      sdfsdfs888
      I'm translating the sentence.I'm sorry if the sentence is strange.
      FredoScale suddenly stopped working.
      I get an error.
      SketchUp
      This version of FredoScale has expired
      Please upgrade to latest version
      Open the Plugin Home page?
      https://sketchucation.com/plugin/1169-fredoscale
      OK Cancel
      my environment is
      FredoScale is the latest version 3.4b
      LibFredo6 is the latest version 12.9a
      I am using sketchup2017.
      I have already purchased a perpetual license.
      how to
      Will FredoScale be available?
        arjunmangaldas
        @fredo6 said:
        NEW RELEASE: FredoScale v3.4b - 11 Mar 22
        Requirement: LibFredo6 12.4a.
        IMPORTANT: FredoScale is no longer supported for Sketchup versions lower than SU2017.
        FredoScale 3.4b includes:
        • Inferences outside current context (see video below)
        • Updated Chinese translation by Arc
        [attachment=0:2nudz2d0]<!-- ia0 -->FredoScale - Inference outside context.gif<!-- ia0 -->[/attachment:2nudz2d0]
        Home Page of FredoScale for information and Download.
        Main post of this FredoScale thread.
        Fredo Scale is not working and says: "this version has expired and release latest version" - even though I have the latest version installed. Please help! (I have purchased perpetual licence and it is showing validated).
        • ArcA
          Arc
          I get an error.
          SketchUp
          OK Cancel
          my environment is
          how to
          Me too, the other fredo6 plugins are working fine expect FredoScale.
          • C
            coolbix
            FredoScale stops working suddenly with the same error message above!!
            • fredo6F
              NEW RELEASE: FredoScale v3.5a - 31 Jul 22
              Requirement: LibFredo6 12.9a.
              FredoScale 3.5a includes:
              • Bug fixing
              • Removal of validity period
              • H
                hugenota
                I have perpetual licence of FreedoScale and while in the midle of important project, it stops working because there is an update. Now I have to look for this update, install it (and figure out how to do it, it's not straight forward), hoping that it will let me finish my project. Really?
                • BoxB
                  If you installed Fredoscale using the sketchucation tool, which you must have if you have a licensed version, then you simply open the Sketchcation tool, it will check for updates and in a few clicks you have installed the update and are back working again.
                  • H
                    hugenota
                    Thank you. Now it will be easier, however I think plugin should not stop working.
                      I have never had one of Fredo6's extensions or any other extensions stop working because an update was released.
                        Meeetch
                        In this case it said that the previous version expired (in spite of paying for a perpetual license). After updating the toolbar is gone with no option to add it back in? I'll just have to crack the previous version I guess.
                          What is hard about updating an extension?
                          • fredo6F
                            You need to upgrade to LibFredo6 v12.9 or above, as indicated in the plugin page and in the notification showed at startup of Sketchup.
                              Meeetch
                              The point is that a paid plugin shouldn't stop working just because there is an update available, when said update doesn't even change any core functionality. Which in turn requires a secondary update to get the first update to work. I'm glad it isn't completely broken, but if this is an intended release strategy, then we should be made aware that occasionally tools from the author will stop working arbitrarily, before they are added to workflow.
                                JonV13
                                My Fredo products are not working. I select the object I want to transform, then click on any of the FredoScale buttons and nothing happens. The black and red highlighting box does not appear. Same thing for all of my Fredo plug-ins.
                                I have a perpetual license for FredoScale and others plus one for SketchUp 2021. I updated all my Fredo products after get the "license expired" error message on 1 Aug. I currently have FredoLib 12.9a and FredoScale 3.5a installed. I have rebooted SketchUp several times and re-installed Fredo several times. Why is this not working?
                                  What version of Sketchucation Tools are you using?
                                  It should be 4.2.9
                                  Sketchucation Tools | SketchUcation
                                  (sketchucation.com)
                                  • BoxB
                                    The whole point of the update was to fix the problem that was causing the plugin to stop working. So it isn't an update it is a bug fix. Why are people getting so 'angry' these days. Sure it's an annoyance, but it takes no time to fix and for most people the sketucation tool updated it for them before they were even aware there was a possible bug in it. And as for making comments about cracking, why would you even say that!
                                      @box said:
                                      ...as for making comments about cracking, why would you even say that!
                                      Maybe they want to not adhere to the TOS here...
                                      TOS | SketchUcation
                                      (sketchucation.com)
                                      But the comment has been noted 👍
                                      • I
                                        ittai1
                                        Good Morning
                                        I have downloaded the Fredo Scale plugin.
                                        I paid for it's license and activated it.
                                        Despite all the above operations, when I run SketchUp, the plug-in appears just in the list of the Extension Manager but not on the screen. I "removed" it and reinstalled it and I still don't see it like the other plug-ins.
                                        What to do ?
                                        with gratitude
                                          Have you installed LibFredo too and https://sketchucation.com/plugin/696-sketchucationtools
                                            JonV13
                                            It should be 4.2.9
                                            (sketchucation.com)
                                            Thanks Rich, that fixed the issue!.... 😄
                                            Jon
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 58
                                            • 59
                                            • 53 / 59
