    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      I don't know of any other extension that does what FredoScale does.
      A license for it is only $12. For $40 you also get licenses for seven other extensions, too.
        sdfsdfs888
        I'm translating the sentence.I'm sorry if the sentence is strange.
        FredoScale suddenly stopped working.
        I get an error.
        SketchUp
        This version of FredoScale has expired
        Please upgrade to latest version
        Open the Plugin Home page?
        https://sketchucation.com/plugin/1169-fredoscale
        OK Cancel
        my environment is
        FredoScale is the latest version 3.4b
        LibFredo6 is the latest version 12.9a
        I am using sketchup2017.
        I have already purchased a perpetual license.
        how to
        Will FredoScale be available?
          arjunmangaldas
          @fredo6 said:
          NEW RELEASE: FredoScale v3.4b - 11 Mar 22
          Requirement: LibFredo6 12.4a.
          IMPORTANT: FredoScale is no longer supported for Sketchup versions lower than SU2017.
          FredoScale 3.4b includes:
          • Inferences outside current context (see video below)
          • Updated Chinese translation by Arc
          [attachment=0:2nudz2d0]<!-- ia0 -->FredoScale - Inference outside context.gif<!-- ia0 -->[/attachment:2nudz2d0]
          Home Page of FredoScale for information and Download.
          Main post of this FredoScale thread.
          Fredo Scale is not working and says: "this version has expired and release latest version" - even though I have the latest version installed. Please help! (I have purchased perpetual licence and it is showing validated).
          • ArcA
            Arc
            I get an error.
            SketchUp
            OK Cancel
            my environment is
            how to
            Me too, the other fredo6 plugins are working fine expect FredoScale.
            • C
              coolbix
              FredoScale stops working suddenly with the same error message above!!
              • fredo6F
                NEW RELEASE: FredoScale v3.5a - 31 Jul 22
                Requirement: LibFredo6 12.9a.
                FredoScale 3.5a includes:
                • Bug fixing
                • Removal of validity period
                • H
                  hugenota
                  I have perpetual licence of FreedoScale and while in the midle of important project, it stops working because there is an update. Now I have to look for this update, install it (and figure out how to do it, it's not straight forward), hoping that it will let me finish my project. Really?
                  • BoxB
                    If you installed Fredoscale using the sketchucation tool, which you must have if you have a licensed version, then you simply open the Sketchcation tool, it will check for updates and in a few clicks you have installed the update and are back working again.
                    • H
                      hugenota
                      Thank you. Now it will be easier, however I think plugin should not stop working.
                        I have never had one of Fredo6's extensions or any other extensions stop working because an update was released.
                          Meeetch
                          In this case it said that the previous version expired (in spite of paying for a perpetual license). After updating the toolbar is gone with no option to add it back in? I'll just have to crack the previous version I guess.
                            What is hard about updating an extension?
                            • fredo6F
                              You need to upgrade to LibFredo6 v12.9 or above, as indicated in the plugin page and in the notification showed at startup of Sketchup.
                                Meeetch
                                The point is that a paid plugin shouldn't stop working just because there is an update available, when said update doesn't even change any core functionality. Which in turn requires a secondary update to get the first update to work. I'm glad it isn't completely broken, but if this is an intended release strategy, then we should be made aware that occasionally tools from the author will stop working arbitrarily, before they are added to workflow.
                                  JonV13
                                  My Fredo products are not working. I select the object I want to transform, then click on any of the FredoScale buttons and nothing happens. The black and red highlighting box does not appear. Same thing for all of my Fredo plug-ins.
                                  I have a perpetual license for FredoScale and others plus one for SketchUp 2021. I updated all my Fredo products after get the "license expired" error message on 1 Aug. I currently have FredoLib 12.9a and FredoScale 3.5a installed. I have rebooted SketchUp several times and re-installed Fredo several times. Why is this not working?
                                    What version of Sketchucation Tools are you using?
                                    It should be 4.2.9
                                    Sketchucation Tools | SketchUcation
                                    (sketchucation.com)
                                    • BoxB
                                      The whole point of the update was to fix the problem that was causing the plugin to stop working. So it isn't an update it is a bug fix. Why are people getting so 'angry' these days. Sure it's an annoyance, but it takes no time to fix and for most people the sketucation tool updated it for them before they were even aware there was a possible bug in it. And as for making comments about cracking, why would you even say that!
                                        @box said:
                                        ...as for making comments about cracking, why would you even say that!
                                        Maybe they want to not adhere to the TOS here...
                                        TOS | SketchUcation
                                        (sketchucation.com)
                                        But the comment has been noted 👍
                                        • I
                                          ittai1
                                          Good Morning
                                          I have downloaded the Fredo Scale plugin.
                                          I paid for it's license and activated it.
                                          Despite all the above operations, when I run SketchUp, the plug-in appears just in the list of the Extension Manager but not on the screen. I "removed" it and reinstalled it and I still don't see it like the other plug-ins.
                                          What to do ?
                                          with gratitude
                                            Have you installed LibFredo too and https://sketchucation.com/plugin/696-sketchucationtools
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 58
                                            • 59
                                            • 53 / 59
