    The Nadesico A
    194 Posts 10 Posters 78.5k Views 10 Watching
    • Bryan KB Offline
      Thanks L i am! πŸ‘
        Thanks for passing that along. Nicely done mate.
        • Bryan KB Offline
          Antennas created.
          I learned... something incredible when making the base of the antennas. You can Push/Pull+Ctl (new extension) then scale, then... ROTATE JUST THE SELECTED FACE ON ANY EDGE! Even if it's oval!
          But you have to hold the Down Arrow key when it's a weird shape and an even weird angle.
          I would have never been able to construct this line by line. I literally stumbled across this.
          Still had to twiddle the lines points to get it flat on the surface, but this easily saved hours!
          • Bryan KB Offline
            You're welcome and thanks!
            • Bryan KB Offline
              Underneath upper deck detail update. I may have overdone it, but there is still one more key element to add.
              I can't even begin to describe the teasing and twisting I did on this detail.
              • tuna1957T Offline
                tuna1957
                When do you start putting in the rivets? πŸ˜† πŸ˜‰ Looks like your around third heading for home ! πŸ‘
                • Bryan KB Offline
                  Front, under hanger landing blocks roughed in. Second main element under upper deck completed (the vertical cylinder thing). Forward indented the underside of the upper deck and scaled the pods things forward. All major module blocks are completed.
                  FINALLY! πŸ˜†
                  Now on to the detailing after I take a few days to look it over before committing.
                  • ntxdaveN Offline
                    ntxdave
                    The details in your model just keep getting interesting. Sure will be neat to see the final model and a rendering. πŸ‘
                    Press F1...thank me later
                    • Bryan KB Offline
                      Thank ntxdave!
                      There is a lot of detail on this design yet to come. I've just got the big stuff completed. However, it's mostly greeble after I finalize the landing pods and neck shapes.
                      • Bryan KB Offline
                        Still pushing around the shape of the under-pods.
                        • Bryan KB Offline
                          Fiddled around with the bridge. Shrank the lower half height and made the windows just slightly larger. Also cleaned up the neck.
                          The face and line joins of the neck to the bridge is not exact yet.
                          • Bryan KB Offline
                            Almost there.
                            All main modules completed. Started details. Barring future discoveries of badly shaped modules, it's just detailing from here onward.
                            As tuna said, I'm now rounding third and headed for home. Finally.
                            • majidM Offline
                              majid
                              These are so brilliant works done using SketchUp. I may never imagine being able and patient to model such a thing using SketchUp. πŸ‘ πŸ‘ πŸ‘
                                Epic mate πŸ‘
                                • Bryan KB Offline
                                  Thanks majid. I did not think it would take 5 months to model this or I might not have started. Granted, I only worked on it a few hours at a time, but still, it has not taken me 5 months to model anything in years.
                                  Thanks L i am. πŸ‘ I'm ready to finish this and start other projects.
                                  I've learned a lot from this model. Things I wish I had learned years ago. When I get a new PC, there will be more epic models. πŸ‘
                                  • HornOxxH Offline
                                    HornOxx
                                    πŸ‘ what a great example of both - the cool model itself and that, besides skills, patience and persistence pays off πŸ‘
                                    never trust a skinny cook
                                    • tuna1957T Offline
                                      tuna1957
                                      @hornoxx said:
                                      :thumb: what a great example of both - the cool model itself and that, besides skills, patience and persistence pays off πŸ‘
                                      I’ll second this πŸ‘ πŸ‘
                                        I'll third that. Epic indeed.
                                        • Bryan KB Offline
                                          So close. So, so close to being finished.
                                          The details are really making it pop.
                                          • Bryan KB Offline
                                            Thanks HornOxx!
                                            Thanks Tuna!
                                            Thanks Mike!
                                            Thanks Majid!
                                            Maybe another week or two and it should be finished.
                                            • 9 / 10
