    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    481 Posts 92 Posters 356.1k Views 91 Watching
      Rougeee
      Why the "selection arrow" is not on the master toolbar list ?
      This would be very useful for me to customize a side toolbar on a single column rather than the two columns of the "large toolset" bar.
      I know that I can use the spacebar at any time, but it would be more practical for me to have the "selection arrow" icon accessible.
      Thanks.
        You could natively (without LOTT) create a custom toolbar to replace the Large Toolset.
          Rougeee
          Thanks, indeed, I don't know why I never thought of that... πŸ˜†
          • W Offline
            Whitelizard
            Hello, I found a compatibility issue with the Universal Importer.
            https://sketchucation.com/pluginstore?pln=universal_importer
            When I installed this plugin, any interaction with LordOfTheToolbars started creating unnecessary icons on custom panels. It is solved by disabling the Importer, but at first it was not clear what was happening, then I figured it out myself. So I'm just informing you that such a case took place.
              rv1974
              Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just informuser instead of prohibition? It's very uncomfortable to restart multiple files.
              • fredo6F Offline
                What do you mean by 'version is expired'?
                  rv1974
                  A pop-up window saying version is expired and DL link below
                  • fredo6F Offline
                    Version of what? Could you show the screenshot.
                      rv1974
                      this one, it should inform just once and let user continue use LOTT commands without restart.
                        @rv1974 said:
                        this one
                        Why not just update it and be done with it?
                          rv1974
                          that's what I'm asking for. Currently you are not allowed to use all LOTT's features without updating AND restarting.
                          • X Offline
                            xjpes
                            There's a bug in the version 2.1a which is the blocks in the toolbar coustoming view can't be clicked or dragged means this whole function won't work anylonger. Other views just look like the toolbar comstuming view are still work just fine. I've already reinstalled the fredo6library and the LOTT plugins many times and removed all the other plugins and all the files that produced by the LOTT(like everything in that autosave folders), and this situation still doesn;t get good.
                            • fredo6F Offline
                              I am not sure I undertand where is the problem.
                              Could you try version 2.2a and tell me if this solves the issue.
                              • fredo6F Offline
                                NEW RELEASE: LordOfTheToolbars v2.2a - 28 Jun 22
                                Requirements
                                • LibFredo6: v12.9a or above
                                LordOfTheToolbars 2.1a includes
                                • Bug fixing
                                Home Page of LordOfTheToolbars for information and Download.
                                Main post of this LordOfTheToolbars thread.
                                  AISmebel
                                  @aismebel said:
                                  Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
                                  With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
                                  These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
                                  Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
                                  Very inconvenient (Icons constantly fly off from the places where I installed them (
                                  https://youtu.be/EWKnFRXS1NE
                                  Good afternoon Fred. Earlier I wrote to you that I had problems loading icons. And I couldn't click the "Menu" tab to create a new command. You suggested that perhaps because of the Cyrillic alphabet. Managed to solve the problem! You need to remove or disable the "Universal importer" pagin and the problem is gone!
                                    menmsis
                                    Great Tool.
                                    I only have a problem, since I installed the new version the option to create personal commands from the menu commands does not work.
                                    Every fredo plugin is update.
                                    • fredo6F Offline
                                      By saying "the menu commands does not work", do you mean that
                                      1. the functionality is not available (i.e. the row with 'Menu' is missing)
                                      2. or when you click on the Menu label, nothing happens (if so, could you open the Ruby console before clicking and check if there are error messages)
                                      3. or something else...
                                        @menmsis said:
                                        I only have a problem...
                                        What version of SketchUp are you using? That may have an impact. Please complete your profile.
                                          menmsis
                                          1. or when you click on the Menu label, nothing happens (if so, could you open the Ruby console before clicking and check if there are error messages)
                                          2. or something else...
                                          [attachment=0:3qwq1hzc]<!-- ia0 -->LOTT perso commands - Menu.png<!-- ia0 -->[/attachment:3qwq1hzc]
                                          Fredo, what happens is exactly as you mention on option 2. I click the Menu and nothing happens. I got the following erro in the ruby console:
                                          Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5390:in all_menus' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5390:in menu_mapping'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5468:in menu_structured_list' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:1056:in menu_compute_list'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:480:in dialog_format_menu_list' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:411:in dialog_format_properties'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:329:in dialog_prepare_html' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:263:in dialog_load_html'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:175:in dialog_invoke' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:4975:in perso_dialog_invoke'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:4447:in perso_new_command' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2459:in dialog_callback_exec'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2316:in dialog_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2427:in call'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2427:in master_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2205:in j_action'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2164:in j_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2150:in block in j_dispatch'
                                          c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2142:in each' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2142:in j_dispatch'
                                            menmsis
                                            Hi Dave.
                                            I am using 2022.
                                            I already update my profile
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
