    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    549 Posts 101 Posters 609.6k Views 99 Watching
      rv1974
      Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just informuser instead of prohibition? It's very uncomfortable to restart multiple files.
      • fredo6F
        What do you mean by 'version is expired'?
          rv1974
          A pop-up window saying version is expired and DL link below
          • fredo6F
            Version of what? Could you show the screenshot.
              rv1974
              this one, it should inform just once and let user continue use LOTT commands without restart.
                @rv1974 said:
                this one
                Why not just update it and be done with it?
                  rv1974
                  that's what I'm asking for. Currently you are not allowed to use all LOTT's features without updating AND restarting.
                  • X
                    xjpes
                    There's a bug in the version 2.1a which is the blocks in the toolbar coustoming view can't be clicked or dragged means this whole function won't work anylonger. Other views just look like the toolbar comstuming view are still work just fine. I've already reinstalled the fredo6library and the LOTT plugins many times and removed all the other plugins and all the files that produced by the LOTT(like everything in that autosave folders), and this situation still doesn;t get good.
                    • fredo6F
                      I am not sure I undertand where is the problem.
                      Could you try version 2.2a and tell me if this solves the issue.
                      • fredo6F
                        NEW RELEASE: LordOfTheToolbars v2.2a - 28 Jun 22
                        Requirements
                        • LibFredo6: v12.9a or above
                        LordOfTheToolbars 2.1a includes
                        • Bug fixing
                        Home Page of LordOfTheToolbars for information and Download.
                        Main post of this LordOfTheToolbars thread.
                          AISmebel
                          @aismebel said:
                          Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
                          With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
                          These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
                          Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
                          Very inconvenient (Icons constantly fly off from the places where I installed them (
                          https://youtu.be/EWKnFRXS1NE
                          Good afternoon Fred. Earlier I wrote to you that I had problems loading icons. And I couldn't click the "Menu" tab to create a new command. You suggested that perhaps because of the Cyrillic alphabet. Managed to solve the problem! You need to remove or disable the "Universal importer" pagin and the problem is gone!
                            menmsis
                            Great Tool.
                            I only have a problem, since I installed the new version the option to create personal commands from the menu commands does not work.
                            Every fredo plugin is update.
                            • fredo6F
                              By saying "the menu commands does not work", do you mean that
                              1. the functionality is not available (i.e. the row with 'Menu' is missing)
                              2. or when you click on the Menu label, nothing happens (if so, could you open the Ruby console before clicking and check if there are error messages)
                              3. or something else...
                                @menmsis said:
                                I only have a problem...
                                What version of SketchUp are you using? That may have an impact. Please complete your profile.
                                  menmsis
                                  1. or when you click on the Menu label, nothing happens (if so, could you open the Ruby console before clicking and check if there are error messages)
                                  2. or something else...
                                  [attachment=0:3qwq1hzc]<!-- ia0 -->LOTT perso commands - Menu.png<!-- ia0 -->[/attachment:3qwq1hzc]
                                  Fredo, what happens is exactly as you mention on option 2. I click the Menu and nothing happens. I got the following erro in the ruby console:
                                  Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5390:in all_menus' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5390:in menu_mapping'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5468:in menu_structured_list' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:1056:in menu_compute_list'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:480:in dialog_format_menu_list' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:411:in dialog_format_properties'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:329:in dialog_prepare_html' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:263:in dialog_load_html'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:175:in dialog_invoke' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:4975:in perso_dialog_invoke'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:4447:in perso_new_command' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2459:in dialog_callback_exec'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2316:in dialog_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2427:in call'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2427:in master_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2205:in j_action'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2164:in j_callback' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2150:in block in j_dispatch'
                                  c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2142:in each' c:/users/mario navarro/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2142:in j_dispatch'
                                    menmsis
                                    Hi Dave.
                                    I am using 2022.
                                    I already update my profile
                                    • fredo6F
                                      I think this is an issue with one extension which uses diacritic characters in the menu item label.
                                      Maybe Universal Importer by samuel_t, or one of his other plugins.
                                      Best is to check in the submenu of the Extensions menu.
                                        menmsis
                                        Fredo, thank you for your help and all your wonderful plugins.
                                        I unistall the universal importer and all worked fine.
                                        Best Regards.
                                        • alexpacio2013A
                                          alexpacio2013
                                          Hi I have updated the LortdOfTheToolbars Plugins and from that moment every time I open Sketchup and my menu bars do not go out. To do this I have to launch Master toolbar Manager and they automatically open What can I do?
                                            @alexpacio2013 said:
                                            Hi I have updated the LortdOfTheToolbars Plugins...
                                            What version of SketchUp are you using? Your profile says "pre-2013". Is that correct?
                                            • 11
                                            • 12
                                            • 13
                                            • 27
                                            • 28
                                            • 11 / 28
