    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.8k Views 99 Watching
    • fredo6F
      @scozzarella said:
      If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
      Strange. On Mac, it works for SU2021, but not for SU2022
      Thanks for signaling the problem.
        Scozzarella
        you are welcome
        • fredo6F
          NEW RELEASE: LordOfTheToolbars v2.1a - 14 May 22
          Requirements
          • LibFredo6: v12.9a or above
          LordOfTheToolbars 2.1a includes
          • Bug fixing
          • Future compatibility
          Home Page of LordOfTheToolbars for information and Download.
          Main post of this LordOfTheToolbars thread.
            Scozzarella
            thank you very much
              Rougeee
              Why the "selection arrow" is not on the master toolbar list ?
              This would be very useful for me to customize a side toolbar on a single column rather than the two columns of the "large toolset" bar.
              I know that I can use the spacebar at any time, but it would be more practical for me to have the "selection arrow" icon accessible.
              Thanks.
                You could natively (without LOTT) create a custom toolbar to replace the Large Toolset.
                  Rougeee
                  Thanks, indeed, I don't know why I never thought of that... πŸ˜†
                  • W
                    Whitelizard
                    Hello, I found a compatibility issue with the Universal Importer.
                    https://sketchucation.com/pluginstore?pln=universal_importer
                    When I installed this plugin, any interaction with LordOfTheToolbars started creating unnecessary icons on custom panels. It is solved by disabling the Importer, but at first it was not clear what was happening, then I figured it out myself. So I'm just informing you that such a case took place.
                      rv1974
                      Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just informuser instead of prohibition? It's very uncomfortable to restart multiple files.
                      • fredo6F
                        What do you mean by 'version is expired'?
                          rv1974
                          A pop-up window saying version is expired and DL link below
                          • fredo6F
                            Version of what? Could you show the screenshot.
                              rv1974
                              this one, it should inform just once and let user continue use LOTT commands without restart.
                                @rv1974 said:
                                this one
                                Why not just update it and be done with it?
                                  rv1974
                                  that's what I'm asking for. Currently you are not allowed to use all LOTT's features without updating AND restarting.
                                  • X
                                    xjpes
                                    There's a bug in the version 2.1a which is the blocks in the toolbar coustoming view can't be clicked or dragged means this whole function won't work anylonger. Other views just look like the toolbar comstuming view are still work just fine. I've already reinstalled the fredo6library and the LOTT plugins many times and removed all the other plugins and all the files that produced by the LOTT(like everything in that autosave folders), and this situation still doesn;t get good.
                                    • fredo6F
                                      I am not sure I undertand where is the problem.
                                      Could you try version 2.2a and tell me if this solves the issue.
                                      • fredo6F
                                        NEW RELEASE: LordOfTheToolbars v2.2a - 28 Jun 22
                                        Requirements
                                        • Bug fixing
                                          AISmebel
                                          @aismebel said:
                                          Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
                                          With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
                                          These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
                                          Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
                                          Very inconvenient (Icons constantly fly off from the places where I installed them (
                                          https://youtu.be/EWKnFRXS1NE
                                          Good afternoon Fred. Earlier I wrote to you that I had problems loading icons. And I couldn't click the "Menu" tab to create a new command. You suggested that perhaps because of the Cyrillic alphabet. Managed to solve the problem! You need to remove or disable the "Universal importer" pagin and the problem is gone!
                                            menmsis
                                            Great Tool.
                                            I only have a problem, since I installed the new version the option to create personal commands from the menu commands does not work.
                                            Every fredo plugin is update.
                                            • 11
                                            • 12
                                            • 13
                                            • 27
                                            • 28
                                            • 11 / 28
