[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
What is the problem?
If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
Strange. On Mac, it works for SU2021, but not for SU2022
Thanks for signaling the problem.
you are welcome
NEW RELEASE: LordOfTheToolbars v2.1a - 14 May 22
Requirements
- LibFredo6: v12.9a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.1a includes
- Bug fixing
- Future compatibility
Home Page of LordOfTheToolbars for information and Download.
thank you very much
Why the "selection arrow" is not on the master toolbar list ?
This would be very useful for me to customize a side toolbar on a single column rather than the two columns of the "large toolset" bar.
I know that I can use the spacebar at any time, but it would be more practical for me to have the "selection arrow" icon accessible.
Thanks.
You could natively (without LOTT) create a custom toolbar to replace the Large Toolset.
Thanks, indeed, I don't know why I never thought of that...
Hello, I found a compatibility issue with the Universal Importer.
https://sketchucation.com/pluginstore?pln=universal_importerWhen I installed this plugin, any interaction with LordOfTheToolbars started creating unnecessary icons on custom panels. It is solved by disabling the Importer, but at first it was not clear what was happening, then I figured it out myself. So I'm just informing you that such a case took place.
Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just informuser instead of prohibition? It's very uncomfortable to restart multiple files.
What do you mean by 'version is expired'?
A pop-up window saying version is expired and DL link below
Version of what? Could you show the screenshot.
this one, it should inform just once and let user continue use LOTT commands without restart.
that's what I'm asking for. Currently you are not allowed to use all LOTT's features without updating AND restarting.
There's a bug in the version 2.1a which is the blocks in the toolbar coustoming view can't be clicked or dragged means this whole function won't work anylonger. Other views just look like the toolbar comstuming view are still work just fine. I've already reinstalled the fredo6library and the LOTT plugins many times and removed all the other plugins and all the files that produced by the LOTT(like everything in that autosave folders), and this situation still doesn;t get good.
I am not sure I undertand where is the problem.
Could you try version 2.2a and tell me if this solves the issue.
