    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.8k Views 99 Watching
      digitect
      @digitect said:
      No vignette stripe for me...
      UPDATE: I position my Windows taskbar at screen top, and found LOTT beneath it. So that default needs to be adjusted. Once I found, and adjusted, several LOTT positioning options from their defaults (sticky to Sketchup window, position in Popup mode, position when cycling), it behaved as expected.
      • fredo6F
        @scozzarella said:
        Sketchup 2022 MAC
        the Pie Tool doesn't work if I press the button on Palette of LordofTheToolbars.
        Is it a bug?
        As far as I now the Pie tool (from Rich O Brien) is not supported on Mac.
          @scozzarella said:
          Sketchup 2022 MAC...
          Is it a bug?
          No. As Fredo indicated, Pie is Windows only.
            Scozzarella
            /Users/angeloscozzarella/Desktop/Schermata 2022-05-12 alle 04.42.13.png
              Scozzarella
              • fredo6F
                @Scozzarella
                What is the problem?
                  Scozzarella
                  @fredo6 said:
                  @Scozzarella
                  If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
                  • fredo6F
                    Strange. On Mac, it works for SU2021, but not for SU2022
                    Thanks for signaling the problem.
                      Scozzarella
                      you are welcome
                      • fredo6F
                        NEW RELEASE: LordOfTheToolbars v2.1a - 14 May 22
                        Requirements
                        • LibFredo6: v12.9a or above
                        LordOfTheToolbars 2.1a includes
                        • Bug fixing
                        • Future compatibility
                        Home Page of LordOfTheToolbars for information and Download.
                        Main post of this LordOfTheToolbars thread.
                          Scozzarella
                          thank you very much
                            Rougeee
                            Why the "selection arrow" is not on the master toolbar list ?
                            This would be very useful for me to customize a side toolbar on a single column rather than the two columns of the "large toolset" bar.
                            I know that I can use the spacebar at any time, but it would be more practical for me to have the "selection arrow" icon accessible.
                            Thanks.
                              You could natively (without LOTT) create a custom toolbar to replace the Large Toolset.
                                Rougeee
                                Thanks, indeed, I don't know why I never thought of that... πŸ˜†
                                • W
                                  Whitelizard
                                  Hello, I found a compatibility issue with the Universal Importer.
                                  https://sketchucation.com/pluginstore?pln=universal_importer
                                  When I installed this plugin, any interaction with LordOfTheToolbars started creating unnecessary icons on custom panels. It is solved by disabling the Importer, but at first it was not clear what was happening, then I figured it out myself. So I'm just informing you that such a case took place.
                                    rv1974
                                    Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just informuser instead of prohibition? It's very uncomfortable to restart multiple files.
                                    • fredo6F
                                      What do you mean by 'version is expired'?
                                        rv1974
                                        A pop-up window saying version is expired and DL link below
                                        • fredo6F
                                          Version of what? Could you show the screenshot.
                                            rv1974
                                            this one, it should inform just once and let user continue use LOTT commands without restart.
                                            • 11
                                            • 12
                                            • 27
                                            • 28
                                            • 10 / 28
