    Animator Play Button
    20 Posts 4 Posters 5.6k Views 4 Watching
    • ntxdaveN Offline
      ntxdave
      It would be neat if there as a way to play an Animator animation without opening the Animator tool. There has been an ongoing discussion on the SketchUp forum Using SketchUp as a substitute for PowerPoint which has made me wonder if it would be possible to add the ability to play an Animator animation in one or all of the following situations:
      • When you load a scene in either SketchUp or Layout. In particular if you load a scene it would automatically play the animation. Since LayOut has a presentation mode and you can tie a “slide” to a SU scene, this would allow you to set up the scene to automatically play when the slide/scene is displayed.
      • Provide the ability to add a “hot spot” that when clicked would play an animation. This could be an alternative or addition to the above suggestion. However, if this facility could be added in addition to the above suggestion, it would add the ability to play the animation more than once. It could also provide tha ability to play more than one animation in a given scene or situation.
      • It would also be neat if you the button/control would also allow the user/viewer to pause and back up the animation.
      Once again remember that the motivation here is viewing a model in the presentation mode of LayOut as a substitution for PowerPoint.
      • ntxdaveN Offline
        ntxdave
        A little surprised there have been no responses.
        • BoxB Offline
          You posted this in the Premium members only General Discussion forum. Not that many people will see it.
          • ntxdaveN Offline
            ntxdave
            How the heck do I move it to a “general” forum?
            • BoxB Offline
              You need someone with moderator powers. Not me I'm afraid.
                You need the proper clearance and to pass the 'test'
                • ntxdaveN Offline
                  ntxdave
                  Guess I will fail the test. I went into edit mode but did not see an option to change the forum. Need some education/help.
                  • BoxB Offline
                    Rich moved it for you.
                    • ntxdaveN Offline
                      ntxdave
                      👍 Thanks very much. Is there a way I could have moved it myself?
                        @ntxdave said:
                        :thumb: Thanks very much. Is there a way I could have moved it myself?
                        No, mods/admins have extra functions...
                        https://i.imgur.com/eUDzodL.png
                        ...to help with this.
                        • ntxdaveN Offline
                          ntxdave
                          Thanks Rich. Can you clean up the thread for me?
                          • fredo6F Offline
                            For the time being, there is a Player, which just controls the animation.
                            I had also the plan to develop the Visit Controller, allowing to develop individual animations. This is the 3rd button, not yet implemented.
                            • ntxdaveN Offline
                              ntxdave
                              Thanks for the reply Fredo. Since the idea here was for the ability to play an animation during a presentation, it needs to be a simple button. The idea here is something similar to the convince of a dynamic component.
                              My laptop died so I can not go test things but I thought each clip you develop with Animator could be named. If that is true, then t was thinking of the ability for a “button”/hot spot that would trigger the clip(‘s). On the same theory as dynamic components, it would be neat if the first click played the clip and the second click reversed the clip.
                              Bottom line, I think we need the ability to use Animatot to build something that works like dynamic components. Again, the goal here is to use the capability to take advantage of the great abilities of Animator to develop animations that can be used when giving presentations instead of creating videos. Hope this makes sense.
                              • BoxB Offline
                                Perhaps there could be a method to link an animation to a scene so that it runs when the scene is activated.
                                • ntxdaveN Offline
                                  ntxdave
                                  Yes, I forgot to mention that in my long dialog but I also know from giving many presentations over many years that you also need the ability to repeat things from time to time. I also forgot to mention that is the animation is long or complicated you will also need the abilities to pause and/or control the speed sometimes.
                                  Is this getting out of control?
                                  • ntxdaveN Offline
                                    ntxdave
                                    [attachment=0:1apwxonf]<!-- ia0 -->Animator_icon_Player.png<!-- ia0 -->[/attachment:1apwxonf]
                                    [attachment=1:1apwxonf]<!-- ia1 -->Animator - Player.png<!-- ia1 -->[/attachment:1apwxonf]
                                    [attachment=2:1apwxonf]<!-- ia2 -->Animator_icon_Controller.png<!-- ia2 -->[/attachment:1apwxonf]
                                    OK, after some feedback from SU, I am wondering if there is anyway you could have access to this in the LayOut viewer?
                                    Sorry for the delay in responding. I like where you are headed with this. Now for some questions:
                                    1. Is it possible to control the visibility/availability at the scene level (like control it with a tag)?
                                    2. Could you have multiple animations available? Let’s say that the box with the animation name could be a drop dow or scrollable list of available animations. Again perhaps a way to control the list via tags or some other method.
                                    Again, after looking at your controls, I think you have this headed in the right direction. I wish their was a way you could activate this in an environment where you are making a presentation of a model. I would love to be able to help you/test it but since I do not currently have access to SU I will have to just see where it goes. 😄
                                    • ntxdaveN Offline
                                      ntxdave
                                      Just curious - any update feedback on this topic?
                                      • fredo6F Offline
                                        Currently there is no interactive API in Layout that would allow to run anything by script.
                                        I am not sure I understand. For animator, Scenes are simply the source for cameras. So you can control the visibility like for any other camera.
                                        In a given model (skp file) you can create several animations (called films) and even insert a film in other films, or create a film by aggregating films. These films are independent, but may refer to the same objects and share clips and sequences.
                                        • ntxdaveN Offline
                                          ntxdave
                                          Thanks Fredo, that is what I thought on all aspects.
                                          In my car wash animations in the past they often were at multi layers. I also remember showing someone before Ho to animated a person walking along a path. Again, this involved multinational levels so that you could show all of the leg and arm movements as the character walked the path.
                                          Wish there was a way to provide animations during a presentation other that via a movie or switching between the presentation software and SU itself. That can be very distracting for the audience. For now your, Play icon/button will be the best solution. 👍
                                          • ntxdaveN Offline
                                            ntxdave
                                            OK guys, here is a perfect example of what I would like to see when presenting a SU model. Interactive Watch Presentation
                                            I was not able to determine what software was used but it is what I was trying to encourage. Imagine being able to enable this type of interactivity in LayOut presentation mode, PowerPoint, or some other presentation tool. It would even be beat to achieve this interactivity on a web site (which this guy has already figured out).
                                            Yes, I am a senior citizen without a computer to work on this stuff but I am currently obsessed with finding out how to achieve this and sharing it with/making it available to the SketchUcation community. Fredo, with your talent and expertise you should be able to come up with something. 😄
