    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 630.7k Views 155 Watching
    • javadvklJ Offline
      javadvkl
      @javadvkl said:
      @rich o brien said:
      @javadvkl said:
      How can I purchase the plugin when my country is under U. S. sanctions? 😞
      Not much we can do about sanctions.
      Can you refer to a replacement for JointPushPull plugin? I've tried the classic JointPushPull already.
      I'll be appreciated it if someone shares his spare license with me because I can't transfer money out of my country (stupid political issues).
        TDahl
        Can anyone suggest how to avoid the following Ruby error that occurs when trying to activate Joint Push Pull Interactive 4.4e (with Libfredo6 12.5a, on macOS 10.14.6 with SketchUp Pro 2018)? I get a similar error when trying to invoke other Fredo6 extensions.
        Error: #<LoadError: dlopen(/Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9): no suitable image found. Did find:
        /Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
        /Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
        /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54:in require' /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54:in require'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:156:in load_binary' /users/tom/library/application support/sketchup 2018/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:71:in dynamic_token'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1688:in tem_context' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1656:in tem_launcher'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in launch_action' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in block in declare_command'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1407:in call' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1407:in command_invoke'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1388:in block (2 levels) in build_config_commands' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in call'
        /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command' SketchUp:1:in call'
        In case it matters, I have the sketchuCation Extension Store 4.2.3 extension installed, but it is not fully working. I can bring up the Extension Store UI and do various things, but downloading an extension fails (ZIP error). I have been in communication with TIG about that, but it remains unresolved.
        I did successfully use Joint Push Pull Interactive a couple of weeks ago, I think before March 1 2022 when Fredo's licensing rules were changed. I have a license file for all of Fredo's extensions, but I cannot install any of the licenses due to similar Ruby errors when activating the License functions in Fredo's extensions (and possibly the sketchuCation Extension Store extension problems).
        - Tom
          PedroE
          st-01.skp
          @fredo6 said:
          @PedroE
          Difficult to tell without seeing the model, which may be convoluted for the joint push pull operation.
          Gracias por contestar. Te adjunto modelo.
          su 2021
            PedroE
            @fredo6 said:
            @PedroE
            same error on joint push pull but not on vector push pull
            • fredo6F Offline
              @PedroE,
              The attached skp file does not correspond to the picture.
              So, difficult to know which face(s) you wish to push pull...
              Also, could you update to the latest version of JointPushPull (v4.4e).
                TDahl
                Any thoughts on the load error traceback that I posted a few replies above?
                • fredo6F Offline
                  We are checking if the Licensing system works on Mojave. We'll come back with an update.... Sorry for inconvenience.
                    TDahl
                    I just saw a post on the SketchUp Forms that a new version (4.2.5) of the SketchuCation Extension Store extension has been released, and I see on these forums that the release notes for v4.2.5 mention a fix for macOS Mojave (which I use). So I removed v4.2.3 that I had, restarted SketchUp, installed v4.2.5, and now the License... function works successfully in the various Fredo extensions that I have installed (macOS 10.14.6, SketchUp 2018).
                    Thank you @TIG and @fredo6.
                    • I Offline
                      iaira
                      I just downloaded this extension but it says that license is over and i have to pay? I haven't even used it once and it said that it was free? Is there anything i can do about it?
                        Maybe. What version of SketchUp are you actually using? Your profile indicates a version that does not exist.
                        • fredo6F Offline
                          Did you already use it on the same computer before?
                          • I Offline
                            iaira
                            I'm using Sketchup Pro 2021.
                            • I Offline
                              iaira
                              No it was the first time I've downloaded fredo6 library and joint push pull extension. I've never encountered such a license problem before. what a bummer, it really looks like a great extension to simplify tasks.
                                KevinGil
                                Hey I just downloaded and I cant find the plugin is nowhere and I did exactly what the tutorial said.
                                • H Offline
                                  HerosDigit
                                  I just purchased the license for this.
                                  the receit is in my email
                                  So how do I get my sketchup make 2017 to recognize the license......
                                  After paying for the extention sketucation does not tell me anything. The only receit is in my email.
                                  I tried clicking on one of the join push pull icons and I got a window with a button saying manage license and I clicks and another window pops up saying I should validate license
                                  What exactly am I to validate.
                                  What i have in my email is like a receit of payment.
                                  Is there like a code or something that I have to use?
                                  Where do i get my paid license file??
                                  • TIGT Online
                                    When you buy an extension's license your might get a PayPal receipt by email, but you should also get an email containing a 'license' file for that extension...
                                    Download and save the license file to somewhere safe on your computer [I have a special folder for licenses in My Documents].
                                    Check your spam-folder in case your email set up is overly cautious...
                                    Next you need to manage your license via the menu item that's listed under the extension's menu entry...
                                    The dialog's validate button click opens a navigator, with that you find the license file, in its saved location, ans select it.
                                    It should then be validated for that extension, and the dialog should change to show that the extension is licensed...
                                      mimom
                                      Hello, I'm trying to purchase the join push tool, but when it directs me to the payment checkout I put the card information and click on pay now, the page refresh and nothing more happens, did it twice and still no purchased happen! Plz any help ?
                                        Gábor
                                        We are exchanging PMs with Mimom about the issue.
                                          dharma26
                                          do I have to make a payment to use this?
                                            Yes. Joint Push/Pull requires a paid license. See the pinned thread here:
                                            https://sketchucation.com/forums/viewtopic.php?f=323&t=74668
                                            • 11
                                            • 30
                                            • 31
                                            • 9 / 31
