    2.2k Posts 482 Posters 849.0k Views 487 Watching
      @millerjx said:
      I have SketchUcation 4.1.3
      You need to update the Sketchucation Extension Store. The current version is 4.2.5. Use the existing version to install the update. Then close SketchUp and restart.
        millerjx
        Thanks, Dave
        That worked
          diablohk1972
          The license file is not working at all.
            The license version [5.3] reported in that dialog [top-left] is not the current one [5.4].
            Install the latest version of the SketchUcation toolset from the PluginStore/ExtensionStore³ [>= v4.2.5].
            Restart SketchUp to sync everything...
              cubiya
              Please provide an other payment method asap other than PayPal since we cant use it in our country.
              Thank you
                @simplesketch said:
                I'm using the latest available Sketchucation Manager 4.2.5
                What version of SketchUp? What operating system? Please complete your profile.
                  simplesketch
                  Hello, I just purchased the Freedo6 perpetual license bundle. But when I try to install the license for RoundCorner, I get the same error message
                  msg_validation_error
                  Request to Sketchucation = ERROR_F07
                  I read this entire forum and followed the steps to delete the
                  SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
                  file in the AppData/ Local / SCF Licenses folder and then repeated the validate license procedure. Still same error.
                  If this cannot be resolved I would have to request a refund.
                  I am using Sketchup Make 2017
                  Windows 11 64 bit
                  I was able to run RoundCorner (latest version) during the free trial period if that helps.
                    As well as having the latest version of the SketchUcation Toolset, you also need to have the latest version of Lib Fredo installed, and of course the newest version of each relevant Fredo's extension installed...
                    Can you checked this...
                    Also, have you restarted SketchUp after the installation[s], to ensure everything syncs ?
                      simplesketch
                      I updated my profile, I am using
                      Sketchup Make 2017
                      Windows 11 64-bit operating system
                      I have Freedo6 library version 12.5a (21 Feb 22) installed
                      I have RoundCorner installed
                      latest version of Sketchucation
                        See
                        https://sketchucation.com/pluginstore?pln=LibFredo6
                        The latest version is 12.8a 17-03-2022 - yours is out of date...
                        Try installing that etc...
                          simplesketch
                          @tig said:
                          See
                          The latest version is 12.8a 17-03-2022...
                          I now uninstalled all Freedo6 plugins and LibFredo6. I deleted the SCF file. Then I restarted sketchup, reinstalled the LibFredo6 (latest version 12.8) and RoundCorner using the Sketchucation plugin. Restarted sketchup again. Tried to validate license, same error.
                          • Rich O BrienR Online
                            Error A02 is related to your signature file. Please send your scflicense file and signature file to support[at]sketchucation.com so we can examine them. Thanks
                              Jenkus
                              We purchased the bundle for Fredo and followed the descriptions.
                              When trying to validate the license it says
                              'msg_validation_error ..... ERROR_07'
                              Sketchucation is up to date.
                              The licenses don't show up in 'Global status of plugins under SCF License'.
                              What to do?
                                What to do?
                                Screenshot the error message. We have no ERROR_07 message But we do have A07, B07 etc....
                                • V Offline
                                  vizz1999
                                  With some problem on validation error. How can i fix it? I had try delete license file, but it doesn't work.
                                    Make sure you are using Sketchucation Tools v4.2.5 and the latest LibFredo.
                                      As you might see from similar posts...
                                      You need to have the following installed...
                                      Latest SketchUcation toolset [>= v4.2.5]
                                      Latest Lib Fredo [>= 12.5a]
                                      Latest versions of the [to be] licensed Fredo-extensions.
                                      After the installations you need to restart SketchUp to ensure everything is synced.
                                      If this doesn't resolve an issue there are recommendations to delete a file and let it be recreated, or failing that, to email your scflicense file and signature file to support[at]sketchucation.com...
                                      On a side note... when you installed SketchUp did you do it correctly ?
                                      Do in wrongly can result in all finds of unpredictable permission issues down the line...
                                      To fix it...
                                      Close SketchUp.
                                      While logged into Windows with your normal user-account...
                                      Find the relevant SketchUp installer's exe file [usually in your Downloads folder].
                                      Select its icon, right-click > context-menu > "Run as administrator"
                                      When prompted choose "Repair"
                                      Let it complete...
                                      Restart SketchUp...
                                      Running a installer's exe file in any other way - e.g. by double-clicking it to 'Run' - is not equivalent - even if your normal user-account has admin powers...
                                        Jenkus
                                        What to do?
                                          carus
                                          Hi!
                                          I just purchased the plug in bundle but the validation of the licence file gives me some troubles.
                                          Somebody there that can help with this issue..?
                                            @carus said:
                                            ...but the validation of the licence file gives me some troubles.
                                            As has been indicated repeatedly in this thread, update the Sketchucation Extension Store and then restart SketchUp.
                                            Please complete your profile with SketchUp version and operating system.
                                            • 100
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 109
                                            • 110
                                            • 102 / 110
