    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • AibonewtA Offline
      Aibonewt
      @dave r said:
      @aibonewt said:
      Yeah, that took like under a minute to fix.
      Happy to know it got you sorted out.
      Because I'm nosy, what are you modeling?
      Hi Dave,
      I'm making resin pendants from 3D printed moulds, and the lofts are part of the bails that contain the cord. I've done hexagonal and circular previously, now I need to create one to fit the square (rotated 45Β°).
      Hexagonal
      Circular
      Square (Prototype)
      Thanks for you interest,
      Thomas (T/A @lightandmagik)
        Mattc25
        Hoping for some help with a project. I'm trying to make a scale aircraft nosecone. To try to match the contours precisely I've divided the nosecone into two front/back sections with four quadrants each. Overall view with quadrants skinned.  Crack is on the top left-right junction. I can easily skin each quadrant and this worked pretty well for the forward section. The problem is at some of the skin junctions between quadrants on the back section. With default skinning parameters I get a sharp corner transition between quadrants. Sharp corner at top-bottom junction When I "Swap rails and Profiles" the sharp transition goes away.Rail swap removes sharp corner but... However, I now get a weird "buttcrack effect" between the left and right quadrants. ![The "crack". Hard to capture but very noticeable when panning along the junction line.](/uploads/imported_attachments/1jFS_Crack.png "The "crack". Hard to capture but very noticeable when panning along the junction line.") It's faint and does not exist across the entire length of the junction but it is there and noticeable in the model. I've made sure that the cross section contours are flat horizontal or vertical across the junctions but I still get these effects. I'm using vertex-to-vertex matching but I've tried the other options as well with minimal effect on result. Any idea on what's causing the "crack" and how to resolve it?
        The model, skins mostly removed to fit under the 5Mb limit.
        • fredo6F Offline
          NEW RELEASE: Curviloft v1.9a - 13 Feb 22
          Curviloft 1.9a is a maintenance release for compatibility with 3D mouse devices.
          See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
          Main post of this thread
            Kaataa
            Has anyone had the problem in Sketchup where it ask for a licenses to use Curviloft?
            • Rich O BrienR Online
              Many of Fredo's tools have become paid extensions which now require a license to use them.
              • N Offline
                naija architect
                i downloaded a curviloft plugin a month ago and i wanted to use it today but i wasnt able to do that because it said trial expired,i havnt event gotten to use it once
                  The trial period is 30 days starting the day you install it. Not sure if there's anything Fredo6 can do about the passage of time.
                  • N Offline
                    naija architect
                    woah,thank you
                      @ktea said:
                      Yes you baited us, what can I say, these tactics really suck.
                      You need to re-evaluate what you said. You're misinformed
                      I think at this point I will take it as a sign of the times and move to Blender.
                      Blender has a very strong commercial ecosystem too.
                        ktea
                        <? <? while ($[]
                        • Z Offline
                          Zampano1
                          Hi Fredo6!
                          I am working with an old windows machine on win7 and su 2015.
                          Is there any download link for an older Curviloft version to work with (works with SU 2015)?
                          Thanks a lot 😎
                          Alex
                          • I Offline
                            IainM
                            Can you please tell me how I can buy the Fredo6Bundle2022 license, and what plugins it includes?
                            Is this the same for a lifetime licence of 3 seats?
                            thanks
                            Iain
                              SketchUcation | Cart
                              (sketchucation.com)
                              This I don't fully understand...
                              But the Bundle has 8 extensions listed in the link above. Each extension has a license for 3 seats.
                              • I Offline
                                IainM
                                many thanks. all gone through ok.
                                  py1998
                                  I was trying to use this plugin, but after installing it in the warehouse manager, it says that the plugin is expired. But this is the first time I have installed it
                                    Andru Chena
                                    This actually works... Thank you goys!
                                      Miho Mihov
                                      Hi Fredo,
                                      I recently purchased the whole bundle of the tools and they are amazing. I have experienced a problem with one of the tools - Curviloft - Skinning. It does not seem to produce consistent results for a simple system of edges which create a triangulated 3D surface. There are always a number of triangles which become distorted - not planar.
                                      I wonder what I am doing wrong. Would appreciate if you can assist.
                                      Attached is the sample file containing the edges as well as the result after the command is executed.
                                      Looking forward from hearing from you.
                                      Regards
                                      Miho Mihov
                                      Sample - skinning
                                        Mrkay
                                        Hi, could someone help me. my licensed curviloft (loft by spline) seems does not working today. I created a simple curve and offset it. when I tried to apply the loft by spline, it doesn't do anything except like in the image attached. Please advise
                                          Upload the SketchUp model file so we can see exactly what you've got.
                                            phoebemaylim
                                            First time downloading Curviloft and RoundCorner and it says license is expired. Never used the extension before. We suppose to get the trial for 30 days right? Rather no need to mention free trial if there's no intention to give free trial.
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 65
                                            • 66
                                            • 57 / 66
