    1.3k Posts 300 Posters 3.1m Views 298 Watching
      ktea
      <? <? while ($[]
      • Z Offline
        Zampano1
        Hi Fredo6!
        I am working with an old windows machine on win7 and su 2015.
        Is there any download link for an older Curviloft version to work with (works with SU 2015)?
        Thanks a lot 😎
        Alex
        • I Offline
          IainM
          Can you please tell me how I can buy the Fredo6Bundle2022 license, and what plugins it includes?
          Is this the same for a lifetime licence of 3 seats?
          thanks
          Iain
            SketchUcation | Cart
            (sketchucation.com)
            This I don't fully understand...
            But the Bundle has 8 extensions listed in the link above. Each extension has a license for 3 seats.
            • I Offline
              IainM
              many thanks. all gone through ok.
                py1998
                I was trying to use this plugin, but after installing it in the warehouse manager, it says that the plugin is expired. But this is the first time I have installed it
                  Andru Chena
                  This actually works... Thank you goys!
                    Miho Mihov
                    Hi Fredo,
                    I recently purchased the whole bundle of the tools and they are amazing. I have experienced a problem with one of the tools - Curviloft - Skinning. It does not seem to produce consistent results for a simple system of edges which create a triangulated 3D surface. There are always a number of triangles which become distorted - not planar.
                    I wonder what I am doing wrong. Would appreciate if you can assist.
                    Attached is the sample file containing the edges as well as the result after the command is executed.
                    Looking forward from hearing from you.
                    Regards
                    Miho Mihov
                    Sample - skinning
                      Mrkay
                      Hi, could someone help me. my licensed curviloft (loft by spline) seems does not working today. I created a simple curve and offset it. when I tried to apply the loft by spline, it doesn't do anything except like in the image attached. Please advise
                        Upload the SketchUp model file so we can see exactly what you've got.
                          phoebemaylim
                          First time downloading Curviloft and RoundCorner and it says license is expired. Never used the extension before. We suppose to get the trial for 30 days right? Rather no need to mention free trial if there's no intention to give free trial.
                            Did you download and install the required Sketchucation Extension Store tool before downloading Curviloft and RoundCorner and then use it to install the extensions?
                              DCDP
                              Helo Fredo
                              Thanks for your amazing tool. It helps me a lot to create special surfaces.
                              Sometimes when I use skinning tool, Curviloft seems blocked and does not create the surface. the control panel appears and stays at 0%.
                              Do you know why ?
                              Thanks for your help.
                              • fredo6F Offline
                                Do you know why ?
                                Difficult to know without the model.
                                Also, could you open the Ruby Console before launching Curviloft. There may be some errors displayed.
                                  DCDP
                                  @fredo6 said:
                                  Do you know why ?
                                  "Points are not planar"
                                  The same kind of surface was created on the opposite side of my model.
                                  Here is the Ruby message :
                                  Error: #<ArgumentError: Points are not planar>
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:123:in add_face' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:123:in geometry_link_flat'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:148:in geometry_link_bz' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:263:in step_geometry'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:37:in block in execute_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:381:in block in launch_execution'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:369:in step_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:418:in start_execution'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6operation.rbe:381:in launch_execution' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftgeometry.rbe:37:in execute_geometry'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:736:in execute_geometry' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:281:in execute_validate'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:269:in execute_from_palette' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:217:in notify_from_palette'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in call' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:529:in block in init_palette'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4076:in execute_button' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3830:in onLButtonUp'
                                  /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp' /users/dominiqueconvard/library/application support/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:503:in onLButtonUp' "
                                  • E Offline
                                    Einstein
                                    Hello,
                                    I feel like I need some clarification here.
                                    Am I thinking right that Curviloft 1.8a is the last version that can be used for free without any time limit?
                                      TIG's ExtrudeTools extensions are similar to CurviLoft if you want a free alternative.
                                      SketchUp Plugins | PluginStore | SketchUcation
                                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                      (sketchucation.com)
                                        Astrid Findreng
                                        I would like to purchase curviloft after free trial expired.
                                        But how do I do it.
                                        Cannot find any buy option. should the donate button be used instead?
                                        Help!
                                        Astrid
                                          SketchUcation | List of Plugin Licences
                                          (sketchucation.com)
                                            Pat58
                                            Hi Fredo6,
                                            I have a problem with the currently release of Curviloft and associated products, the tool palette has disappeared I only get part of the toolbar.
                                            Please see attached image.
                                            I using Sketchup Pro 2022 on a MAC
                                            Fredo6 Libfredo6 version 13.6a 29 Nov
                                            Curviloft 1.9a
                                            I look forward to hearing from you
                                            regards
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 63 / 66
