    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    455 Posts 144 Posters 695.0k Views 143 Watching
    • * Offline
      **Ewie**
      @tig said:
      Ewan
      Open the Ruby Console.
      Then try running the tool.
      Report any error messages.
      Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
      If not this might stop some log file etc getting written if you have limited rights...
      Hi TIG, sorry for the tardy reply, I didn't get a notification of the replies on this thread..
      I checked permissions on the plugin folder; all full control so no issues there.
      Re-ran the plugin with the ruby script window open.. Same issue as before, this time using one of the sample files
      Screen shot attached to explain.
        @Ewan
        Have you tried reinstalling the whole Topo'toolset AND the latest LibFredo again.
        That might jolt it into submission...
        First, if you did a manual install check for misplaced files in the Plugins folder.
        Then reinstall the Lib, then Topo'toolset - I recommend you get/use the "SketchUcation Plugin Store" and use its 'AutoInstall' feature, this will ensure that everything is always put into the right places...
          chris87
          @tig said:
          @Ewan
          I have exactly the same problem.
          All is installed correctly with the good rights and with the last libraries.
          No error in the ruby console !!!!
            Can you post screenshots for Fredo to check...
            Of the Plugins folder showing the installed files/subfolder and the contents of the subfolder itself...
            • fredo6F Offline
              @chris87, @ewan
              It may simply be a bug.
              I'll come back with some instructions in order to figure out what it could be.
              What would help me is that you tell me what you see in the contextual menu when you are in this screen (a screenshot is OK).
                chris87
                @fredo6 said:
                @chris87, @ewan
                screenshot
                • fredo6F Offline
                  Chris,
                  I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
                    chris87
                    @fredo6 said:
                    Chris,
                    Visible on my screenshot :
                    right click
                    toposhaper ---- > générer terrain (maillage carré)
                    best regards
                    • soloS Offline
                      I'm getting a warning when starting SU 2013
                      Error loading File bootstrap_TopoShaper.rb
                      uninitialized constant bTopoShaper;;T6
                      I have tried reinstalling and even checked that bootstrap_TopoShaper is present in plugin folder.
                      Still get the error.
                        Is this the path?
                        C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins\TOPOSHAPER_Dir_10
                        • soloS Offline
                          @rich o brien said:
                          Is this the path?
                          Yes.
                          • fredo6F Offline
                            @solo
                            Strange, because there is nowhere bTopoShaper in my code (I checked).
                            I hope it does not come from a corruption of the files or the zip archive.
                            Could you go to the LibFredo6 Trace Log and check if you see an error. If so, it is usually more documented.
                            • soloS Offline
                              @fredo6 said:
                              @solo
                              That's a typo, there is no b. 😄
                              How do I do the libFredo6 trace thing?
                                go to C:\Users#####\AppData\Local\Temp
                                Look for LibFredoTrace-##-#########.txt
                                • soloS Offline
                                  >>>> 1369346329.538;LibFredo6.rb;62; in `log'
                                  DATE / TIME; Thu May 23 16;58;49 -0500 2013
                                  SKETCHUP VERSION; 13.0.3759
                                  RUBY_PLATFORM; i386-mswin32
                                  LOG FILE; LibFredo6Trace_13_1369346329538.txt
                                  >>>> 1369346329.538;LibFredo6.rb;103; in `startup'
                                  LibFredo6; Starting up LibFredo6.rb
                                  >>>> 1369346329.538;LibFredo6.rb;118; in `startup'
                                  LibFredo6; Beginning of loading Cycle***+
                                  >>>> 1369346329.548;LibFredo6.rb;129; in `startup'
                                  LibFredo6 Core; LIBFREDO6_Dir_49/Lib6Core_49.rb successfully loaded
                                  >>>> 1369346329.771;Lib6Core_49.rb;642; in `load_full_rubies'
                                  LibFredo6 4.9c; Ruby files loaded         [213 ms]
                                  >>>> 1369346329.871;Lib6Core_49.rb;642; in `load_full_rubies'
                                  ToolsOnSurface 1.6c; Ruby files loaded         [80 ms]
                                  >>>> 1369346329.921;Lib6Core_49.rb;613; in `load_bootstrap_rubies'
                                  TopoShaper 1.0b; Bootstrap Ruby files loaded         [0 ms]
                                  >>>> 1369346329.931;LibFredo6.rb;139; in `startup'
                                  LibFredo6; End of loading Cycle***-
                                  >>>> 1369347588.651;Lib6Core_49.rb;642; in `load_full_rubies'
                                  TopoShaper 1.0b; Ruby files loaded         [30 ms]
                                  • fredo6F Offline
                                    Go to menu Windows > LibFredo6 Settings... > Trace Log files.
                                    You'll get a dialog box. Select the current or most recent trace file.
                                    Do an expand and check if there are statements in Red.
                                    You can then export the file from there and post it.
                                    • soloS Offline
                                      Nothing in red.
                                      • fredo6F Offline
                                        But then, do you get the message box at startup of SU?
                                        • soloS Offline
                                          Yup, see image.
                                          • fredo6F Offline
                                            Very weird. It looks like you have a probleme with installation of LibFredo6, which the trace does not show.
                                            I have to check and come back
                                            • 22
                                            • 23
                                            • 5 / 23
