    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
      sridhar
      @Sridhar
      It seems you miss the button palette
      The button comes briefly and then exits out of the plugin with an output shown above,
      Regards
      Sridhar
      • fredo6F
        @sridhar said:
        Regards
        Sridhar
        Could you open the Ruby console and report of the error message you see.
        Your model seems complex and there may be some issues
        Thanks very much
        • C
          chris87
          @sridhar said:
          Regards
          Sridhar
          Thanks very much
          I have the same problem.
          The rod of Topshaper tools also disappears to this level.
          No message of mistake in the Ruby console.
          This problem even occurs with the well stocked examples.
          • fredo6F
            @chris87, @sridhar
            Could check that if you type Return, you go to the next step (preview). You can also check the contextual menu.
            By the way, which OS are you on?
            • C
              chris87
              @fredo6 said:
              @chris87, @sridhar
              OS :
              PC windows 7 - sketchup 8 pro last version-
              No action occurs with the key return
              the contextual menu "toposhaper --- > generate land (square maillage)" makes the previous operation throw back only.
              the toposhaper toolbar doesn't reappear.
              excuse me for the bad english language (french user....)
              best regards and thank you for your superb plugins...
              • B
                bhbarchitects
                Great plugin love it!
                  **Ewie**
                  @tig said:
                  Ewan
                  Open the Ruby Console.
                  Then try running the tool.
                  Report any error messages.
                  Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
                  If not this might stop some log file etc getting written if you have limited rights...
                  Hi TIG, sorry for the tardy reply, I didn't get a notification of the replies on this thread..
                  I checked permissions on the plugin folder; all full control so no issues there.
                  Re-ran the plugin with the ruby script window open.. Same issue as before, this time using one of the sample files
                  Screen shot attached to explain.
                    @Ewan
                    Have you tried reinstalling the whole Topo'toolset AND the latest LibFredo again.
                    That might jolt it into submission...
                    First, if you did a manual install check for misplaced files in the Plugins folder.
                    Then reinstall the Lib, then Topo'toolset - I recommend you get/use the "SketchUcation Plugin Store" and use its 'AutoInstall' feature, this will ensure that everything is always put into the right places...
                    • C
                      chris87
                      @tig said:
                      @Ewan
                      I have exactly the same problem.
                      All is installed correctly with the good rights and with the last libraries.
                      No error in the ruby console !!!!
                        Can you post screenshots for Fredo to check...
                        Of the Plugins folder showing the installed files/subfolder and the contents of the subfolder itself...
                        • fredo6F
                          @chris87, @ewan
                          It may simply be a bug.
                          I'll come back with some instructions in order to figure out what it could be.
                          What would help me is that you tell me what you see in the contextual menu when you are in this screen (a screenshot is OK).
                          • C
                            chris87
                            @fredo6 said:
                            @chris87, @ewan
                            screenshot
                            • fredo6F
                              Chris,
                              I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
                              • C
                                chris87
                                @fredo6 said:
                                Chris,
                                Visible on my screenshot :
                                right click
                                toposhaper ---- > générer terrain (maillage carré)
                                best regards
                                • soloS
                                  I'm getting a warning when starting SU 2013
                                  Error loading File bootstrap_TopoShaper.rb
                                  uninitialized constant bTopoShaper;;T6
                                  I have tried reinstalling and even checked that bootstrap_TopoShaper is present in plugin folder.
                                  Still get the error.
                                    Is this the path?
                                    C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins\TOPOSHAPER_Dir_10
                                    • soloS
                                      @rich o brien said:
                                      Is this the path?
                                      Yes.
                                      • fredo6F
                                        @solo
                                        Strange, because there is nowhere bTopoShaper in my code (I checked).
                                        I hope it does not come from a corruption of the files or the zip archive.
                                        Could you go to the LibFredo6 Trace Log and check if you see an error. If so, it is usually more documented.
                                        • soloS
                                          @fredo6 said:
                                          @solo
                                          That's a typo, there is no b. 😄
                                          How do I do the libFredo6 trace thing?
                                            go to C:\Users#####\AppData\Local\Temp
                                            Look for LibFredoTrace-##-#########.txt
                                            • 22
                                            • 23
                                            • 5 / 23
