    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v12.8a - 17 Mar 22
      LibFredo6 12.8a tentatively corrects problems related to the creation of menus for my plugins. Some users experience an error preventing the plugins to load correctly. Since I am not able to reproduce, I made some changes 'blindly', hoping this would improve the situation.
      • qwertyasQ Offline
        qwertyas
        all fredo6 plugins stopped to work after last fredo6 lib update. Sketchup 2020.
        To test if the problem is related to other plugins, I removed all my plugins from the plugin folder, and installed only sketchucation. From sketchucation plugin I installed fredo cuviloft and fredo6 lib (newest = 12.8a) and restarted Sketchup. Curviloft does not work. You can click on any of the icons but the tool does not initialize (standard cursor and prompt still visible)
        https://ibb.co/QN3Dyb0
          What operating system? I'm not seeing any problems with amy of Fredo6's extensions after the latest update.
          • fredo6F Offline
            Could you open the Ruby Console before lunching Curviloft
            • qwertyasQ Offline
              qwertyas
              is there a place where I can download previous versions of the plugins (and not the very old ones - for 2017 and earlier)? Thanks
              • qwertyasQ Offline
                qwertyas
                Windows 10 Home 21H1
                • qwertyasQ Offline
                  qwertyas
                  yes, here you are:
                  Error: #<NoMethodError: undefined method visual_version' for SCFLicense:Module> c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1733:in tem_context'
                  c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action'
                  c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action'
                  c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                  c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command'
                  fredo6-console hosted at ImgBB
                  Image fredo6-console hosted on ImgBB
                  ImgBB (ibb.co)
                  • fredo6F Offline
                    @qwertyas
                    You need to upgrade to the latest version of Sketchucation ExtensionStore v4.2.4.
                    Apparently, you have an old version.
                      @qwertyas said:
                      Windows 10 Home
                      Please complete your profile with that and the SketchUp version after you update the Sketchucation Extension Store as Fredo6 directed.
                      • qwertyasQ Offline
                        qwertyas
                        @dave r said:
                        @qwertyas said:
                        Windows 10 Home
                        done.
                        Curviloft plugin is working now. Thanks!
                        • qwertyasQ Offline
                          qwertyas
                          @fredo6 said:
                          @qwertyas
                          I updated the plugin and reinstalled both Fredo6 Lib and Curviloft. It is working now. Thank you!
                            @qwertyas said:
                            It is working now.
                            Excellent! And thank you for completing your profile.
                              jose_w650
                              NO ES UN PLUGIN GRATUITO, SOLO FUNCIONA UNA TEMPORADA.
                              PERO PARECE UTIL, GRACIAS
                                Translated by Google:
                                @jose_w650 said:
                                IT IS NOT A FREE PLUGIN, IT ONLY WORKS FOR ONE SEASON.
                                BUT IT SEEMS USEFUL, THANK YOU
                                LibFredo6 is available at no charge. A few of Fredo6's extensions are no longer free after their trial periods expire.
                                What version of SketchUp are you using? Your profile says 2021 Free/Make but there is no such version.
                                  Scozzarella
                                  New LibFredo6?
                                  when it will be available?
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v12.9a - 13 May 22
                                    LibFredo6 12.9a includes:
                                    • Various fixes for my plugins
                                    • Support for LOTT v2.1a
                                      Scozzarella
                                      Thank you It works perfectly!
                                        thortoist
                                        Hi I Have been a fun of your works and using it for a few years. time has past that I am in need to try a new version of plugins and sketchup.
                                        From that day of reinstalling everything I have been spending days figuring out how to make your plugins work.
                                        I have tried installing and reinstalling versions of libFredo from 7 to 12, but still I am getting the error of [please install LibFredo 6.9 or above].
                                        I have tried degrading my sketchup version. trying installing different libFredo version. but nothing works.
                                        Hope to get an answer soon to this problem. I am really in need of using curviloft.
                                        Thank you in advanced. Have a great day.
                                        • fredo6F Offline
                                          It looks like a problem of installation.
                                          First can you confirm which version of Sketchup you run (SU2018?)?
                                          Second, go to the Plugin folder of Sketchup and erase Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 subfolder. Same for Fredo6_Curviloft.rb and Fredo6_Curviloft subfolder.
                                          Then, download and install fresh copy from the Sketchucation web site, or better, Use the Sketchucation ExtensionStore to install the plugins in one click.
                                            adrianavitor
                                            Is this plugin not free anymore? Can't use anything and keeps asking for a licence.
                                            • 108
                                            • 109
                                            • 7 / 109
