Libfredo, Fredoscale, Roundcorner and Curviloft NOT WORKING
Hi guys... Since no news about this issue, I guess there's no solution for my problem... Anyway I would like to thank you again for the time spent trying to give me some clues about the origin of the failure. I'm sure it should be something easy to rearrange, but i don't know what to erase/uninstall and to reintall/setup it again... Should I try to erase by hand the LIBFREDO folders and subfolders in AppData root?
Any more clues will be really welcome!!!
Thanks again and have a good day. -
Thanks again and have a good day.Maybe try to clean up the Fredo6 related files and directory under the APPDATA directory and try again. These files only contains default parameters and settings that you can anyway reconstruct when you use the plugins.
Hi Fredo, and thanks for your reply.
I don't understand what should I do. When you say "clean up" you mean deleting the LIBFREDO6 folder and its subfolders?
And then, what should I do? download LIBFREDO again?
Thanks for your help... -
No.
Fredo means delete the folderC:/Users/PcCom/AppData/Local/LIBFREDO6_DATA_Dirand its contents.
If it's missing then Fredo's tools recreate the folder and its contents when they next run - if they themselves are installed properly...
Try that and report back... -
Hi guys!!!
I don't know why, but just doing what FREDO and you TIG said (closing sketchup, deleting LIBFREDO& folder and it's subfolders) and reopening sketchup again, everything runs smoothly again!!!
I really thank the time spent trying to find a solution to my problem guys. THANKS A LOT. -
Hi Guys,
First, let me preface this by saying I have enjoyed using your tools prior to this version of SkUp, and have been wonderful! Thank you for your contributions.
I am having the same issue with roundcorners (which is what i am currently trying to use) except im on OSX el capitan. I am not sure how to solve this issue. I have the 3 icons loaded, but no actual "adjustment toolbar", and therefore nothing i can actually use...
Has this happened before? Would you be able to give me a hand?
Error: #<NoMethodError: undefined method
no_bandeau' for #<Traductor::Palette:0x007fcf93af4488>> /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/roundcorner_tool.rbs:1050:inpal_sepa_bandeau'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/roundcorner_tool.rbs:1074:inpalette_init' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/roundcorner_tool.rbs:208:ininitialize'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/roundcorner_tool.rbs:129:innew' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/roundcorner_tool.rbs:129:inlaunch'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/roundcorner_tool.rbs:120:inaction__mapping' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbs:123:incall'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbs:123:inlaunch_action' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbs:221:inlaunch_action'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbs:81:inlaunch_action' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbs:96:inblock in startup'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbs:1208:incall' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbs:1208:incommand_invoke'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbs:1190:inblock (2 levels) in build_config_commands' /users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbs:1339:incall'
/users/xxx/library/application support/sketchup 2015/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbs:1339:inblock in add_command' SketchUp:1:incall'Hoping you had a happy Thanksgiving (even though you are {probably} in France)!
Your LibFredo6 version is not up to date. I suggest you refresh it, as well as all my other plugins.
Thank you so much for your prompt reply Fredo!
I went through all these motions several times actually: downloading, and installing Libfredo6, and Roundcorner (all newest versions, etc...) and was still getting the same problem...
My error was in how I was improperly attempting to proceed with updating by simply installing the latest plugin.
This was not overriding (any of) the previous version(s).I finally just used the sketucation plugins uninstaller feature: uninstall roundcorner and libfredo6, quit, relaunch, reinstall Libfredo6, reinstall Roundcorner.
All seems to run normally and excellently now!
Thank you again.
edouard
No.
Try that and report back...just to confirm that doing this actually solved a similar issue I was having with both Fredo6's Tools on Surface and Round Corners (but not his other plugins) - SU pro 2018 on win10. thanks folks!
I have same issue and tried to reinstall/install many times even with Sketchucation plugin maneger but none of the fredo's plugins work for me, and this is the error on Ruby console:
Error: #<NameError: uninitialized constant Traductor::Plugin::G6B>
/users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1868:intem_context' /users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1656:intem_launcher'
/users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:inlaunch_action' /users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:inlaunch_action'
/users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:81:inlaunch_action' /users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:96:inblock in startup'
/users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1407:incommand_invoke' /users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1388:inblock (2 levels) in build_config_commands'
/users/asadullahshafai/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in `block in add_command' -
Make sure you have the latest Sketchucation Extension Store installed along with the latest LibFredo6. Note that these extensions are no longer free so you'll also need to purchase licenses for them.
I have same issue, I also tried to reinstall/install the plugin but none of the fredo's plugins work for me. I've purchased the plugin and already download the latest file. Can you help me?
Error: #<NoMethodError: undefined methodwdlg_from_key' for Traductor::Wdlg:Class> c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:incheck_instance_displayed'
c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:ininvoke' c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:233:ininvoke_quick_launcher'
c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:268:inblock in startup' c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:incommand_invoke'
c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1449:inblock (2 levels) in build_config_commands' c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:inblock in add_command'
c:/users/dimas nur hasanto/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in `block in new' -
To me it looks like you don't have some the latest extension files ??
Make sure you have the very latest extensions and SketchUcation Toolset installed [providing the licensing],... and also the latest LibFredo6 which supports his extensions.
Restart SketchUp after installation and retry...
@tig said:
That's "c:/users/yourusername/appdata/..."
I assume you user-name is in sensible characters ?
Some names with non-ASCII characters might cause issues...BUT you say that the tools seems to load OK... so have you read the usage notes ?
Remember that you will need to select things to make such tools work further !
If you have the 'Ruby Console' open are there any error messages when you try to run the tools ?FYI:
All 'add-on scripts' are actually 'Plugins', but some are written in a special way to become 'Extensions' - all that means is you can stop 'Extensions' loading as SketchUp starts.
They can be 'enabled' later if desired.
If you have the SketchUcation 'Plugins Manager', then you can do the same enable/load/disable with those AND any other 'vanilla' Plugins...I'm facing this error
length' for nil:NilClass> C:/Users/arsha/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/Fredo6_FredoSpline/FredoSplineTool.rb:3974:incusp_within?'
C:/Users/arsha/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/Fredo6_FredoSpline/FredoSplineTool.rb:2408:increation_onMouseMove' C:/Users/arsha/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/Fredo6_FredoSpline/FredoSplineTool.rb:1375:inonMouseMove' -
This looks loke a complication in your model (the curve you draw or edit).
What were you doing exactly?
Could you send it to me or post it here. Thanks
