    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 158.8k Views 54 Watching
    • H
      heloisec2
      I can't open the bezier.rb file.
      the link doesn't work, is there a solution ?
        From your profile info you should be able to get one of the newer 'bezier' extensions to load into SketchUp - avoid this faff...
        FYI you don't 'open' an RB file - also you don't 'open' an RBZ file either - you 'install' it...
        There are two ways of 'installing' a simple RB file...
        ZIP the irb file.
        Change the resultant file's .zip filetype-suffix to .rbz
        Use SketchUp's Window > Extension-Manager dialog to install the .rbz file [red-button 'Install Extension']
        It should install automatically but if not restart SketchUp to complete it.
        Note that your Extension-Manager's 'Loading Policy' must be set to 'Unrestricted' - because older scripts like this are not 'signed'.
        Run this code in the Window > Ruby-Console [copy+paste+enter]
        UI.openURL("file:///#{Sketchup.find_support_file('Plugins')}")
        Your user's Plugins folder will open.
        Drag-and-drop the RB file into that folder.
        Restart SketchUp to load the RB.
        • G
          GirishIyer
          Does this work on SketchUp 2020 Pro, also i am unable to download the bezier.rb file the link is not reachable
            This extension hasn't received any updates in a long time so it's entirely possible it won't work but you can try it.
              mac93
              excellent tool, but the download link for the .rb file is not working. Would it be possible to repair it? or could someone share the download of the file please? TuT)
              • duanekempD
                duanekemp
                As a heads up/confirmation, I'm testing it in SU21 and it's working.
                Duane Kemp
                Kemp Productions
                Puidoux, Switzerland
                Gallery:
                https://duanekemp.artstation.com/
                • duanekempD
                  duanekemp
                  Is it possible to copy the CKM info tweaked in a test file to a second file to generate scenes?
                  Duane Kemp
                  Kemp Productions
                  Gallery:
                  • duanekempD
                    duanekemp
                    Something odd for me in SU21, I set the camera positions and all played back perfectly until creating scenes.
                    Original position
                    Upon launching "Enter"... the CKM resets or newly sets the camera closer to the object than original distance set up (a scene created specifically for the distance).
                    CKM scene view created
                    What's going on here or what am I missing?
                    Duane Kemp
                    Kemp Productions
                    Gallery:
                    • duanekempD
                      duanekemp
                      @tig said:
                      There are now many better tools available...
                      Hi Tig,
                      What tools are you referring to that produce what CKM could do with camera on bezier curve, adjustable/editable...?
                      I'm getting stuck in that the key frames get exported for animation with Thea Render but, not the smooth motion that CKM produces in SU.
                      Are you referring to DL camera spiral? or something else?
                      Thanks.
                      Duane Kemp
                      Kemp Productions
                      Gallery:
                        That was an olde bezier.rb file I actually attached to a post.
                        There are lots of newer bezier extensions available too...
                        • duanekempD
                          duanekemp
                          OK, that makes more sense. I misunderstood that there were more uptodate plugins that replaced CKM. Thanks for the clarification.
                          Duane Kemp
                          Kemp Productions
                          Gallery:
                          • L
                            Luke_123
                            Hey,
                            the tool seems to be working in SU22, but I haven't figured out yet how to start a new camera path? I thought I had it (pressing Esc?) but when I was nearly satisfied with the new path something (maybe pressing spacebar) must have happened and now there is a crude mix of the old path with some elementes of the new one πŸ˜•
                            Can anyone tell me how it is supposed to work?
                            • B
                              burgel_pavel
                              @macgile said:
                              @tiggz1 said:
                              Awesome feature - Thankyou!!
                              One question - forgive me if I missed it. How do I delete the Camera Key path so I can start from scratch?
                              Thank for reply Tiggz1 πŸ˜„
                              just delete path in background layers.
                              best regard πŸ˜„
                              What is background layer please πŸ˜„
                              • Rich O BrienR Rich O Brien referenced this topic on
                              • 6 / 6
