[Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
@haymaker said:
Thanks for the prompt response.
Would it be possible for me to download an earlier version that would work?Instead, I would suggest that you install LOTT V1.6b, which includes an option for setting or unsetting the stickiness of the Vignette Stripe to the Sketchup window (ON by default, so you would need to disable it in the Default Parameters).
NEW RELEASE: LordOfTheToolbars v1.6b - 06 Jan 22
Requirements
- LibFredo6: v12.3a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 1.6b includes
- New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Vignette Stripe to the Sketchup Window (default is enabled).
Home Page of LordOfTheToolbars for information and Download.
Hey.
Great customer service.
I have updated LOTT to 6b but the problem persists. The vignette strip and the favourite pallets that I have made are stuck on the main laptop screen. I also have the problem that whenever I enter text into a dialogue box then the shortcut keys are activated. For example when I make a component with the name 'nog' as soon as I type O the Edit pallet opens up.
I have disabled all my other extensions but it makes no difference. Could this be an installation error. If delete the LOTT extension and reinstall it will I lose all my pallets and shortcuts.
Thank you for your help so far. I am really looking forward to getting this sorted as your plugin will improve my workflow.
ThanksMike
Did you disable the stickiness of the Vignette Stripe in the Default Parameters?
For palettes, they are sticky. So I will make an option to release stickiness for them.
Good catch. I will fix that.
Hey
I deleted LOTT. I reinstalled it and have attached a screenshot of the error that showed up. I continued with the install and have the same issues. I am not sure if this error has anything to do with the problems I have or not.
ThanksMike
Sure did, problem still persists, I can work around it by going into windows display settings and making my external screen the main screen however this seems to cause problems, mainly that if I try and open the Preferences or Model info then SU freezes?? So not really an option..
CheersMike
CheersMike
I sent you a PM for the multiple issues you have
NEW RELEASE: LordOfTheToolbars v1.6c - 08 Jan 22
Requirements
LordOfTheToolbars 1.6c includes
- Bug fixing for palette and personal commands shortcuts
- New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Palettes to the Sketchup Window (default is enabled).
Started to look at this very rich looking extension - via SketchupEssentials video.
I have the issue of the main "palette" (Vignette stripe?) not showing up in the Sketchup main window bar - but rather at the top of the screen - See image.
I tried the setting: "Palettes are sticky to the Sketchup window" - still stays on top of screen.
Advice ?
For clarification
- Stickiness means that the palettes or Vignette Stripe follow move when the Sketchup window is moved. But you decide where to position them manually
- There are separate stickiness options for the Vignette Stripe and for palettes
I got the Vignette stripe to move with the SU window now, thanks.
However, I had do both activate the "Vignette Stripe is sticky" option and then manually move it somewhere over the Sketchup window.
If I did not move it manually somewhere over the Sketchup window, the Vignette option just stayed in one place, even when I moved the SU window.
For me, good enough
NEW RELEASE: LordOfTheToolbars v1.7a - 09 Jan 22
Requirements
- LibFredo6: v12.4a or above
LordOfTheToolbars 1.7a includes
- Bug fixing for list of shortcuts dialog
- Bug fixing for appearance of palettes when never displayed.
Hi Fredo, I'm having problem trying this plugin on a M1 chipset Apple MacBook Pro.
I'm on SketchUp Pro 2021 on 16" MacBook Pro with Apple M1 Max running macOS Monterey. And LordOfTheToolbars is not running properly. All other plugins by Fredo is fine, including FredoCorner and JointPushPull. Only when SIP is disabled, LordOfTheToolbars will run without issue.
Will try to make some screenshots later.
Hi Fredo
Thank you for all the time you put into these plugins! legend!!I've attached a little video of my problem with Palette line breaks, copying of icons and deleting them
I'd guess this is not expected behaviour? or Have i go this completely wrong....
All I'm trying to do is create a few rows of plugins, I also am attempting to move them about to suit my needs.
@cmeed the plugin needs extra polishing. From my experience you should start a new empty file, make all the desired changes in lott toolbars and restart SU afterwards.
Trying to make changes in the middle of long editing of complex files might be too buggy. -
WIP!
I was going for a big palette with lots of icons I'll have to plan a bit better and maybe use more palettes with reduced amounts in
C
NEW RELEASE: LordOfTheToolbars v1.8a - 31 Jan 22
Requirements
LordOfTheToolbars 1.8a includes
- Bug fixing for ghosted icons (appearing grayed-out, although they are installed)
- Bug fixing for blocking of UI right after import (specific SU2022)
- Bug fixing for line-breaks and insertion of icons in palettes.
The problems when inserting and deleting icons and line-breaks should be fixed in LOTT v1.8a.
@aismebel said:
With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
Very inconvenient (Icons constantly fly off from the places where I installed them (Could you first confirm which SU version you have (SU2018?).
Then be more precise on the problem. And could you keep the Ruby console opened when dealing with LOTT, in case there are some error messages displayed.
I would also recommend that you upgrade to LOTT V1.8a just published.
Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
https://youtu.be/EWKnFRXS1NE
With your input, this post could be even better ๐
