    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 725.9k Views 99 Watching
    • H
      haymaker
      Further to previous post. It is worth noting that the LOTT toolbar is open on the main screen. The favourite, master and shortcut menus open on laptop and can be dragged to main screen but everything else is stuck on the laptop screen. Its like the vignette strip does not recognise the second screen.
      I am using LOTT V1.6a and LIBfredo6 v12.3a. SU2021 all up to date.
      • fredo6F
        It's funny, because other users have complained that the Vignette Stripe does not follow Sketchup when the main SU window is moved to another monitor (hence the changes I made to keep the Vignette Stripe position relative to the Sketchup viewport).
        I need to think a little bit to see how to accommodate all requirements.
        • H
          haymaker
          Thanks for the prompt response.
          Would it be possible for me to download an earlier version that would work?
          Cheers
          Mike
            rv1974
            Talking of moving to 2nd monitor.. I'm so pleased with rosette behavior - it preserves location perfectly and no more disappearings ☀
            Hope one day palettes will be able to keep their relative location while manipulating SU viewport in precise manner as well.
            • fredo6F
              What is the rosette behavior again?
                rv1974
                I mean vignette. I got addicted to Stromae's Sante lately Haha
                • fredo6F
                  Instead, I would suggest that you install LOTT V1.6b, which includes an option for setting or unsetting the stickiness of the Vignette Stripe to the Sketchup window (ON by default, so you would need to disable it in the Default Parameters).
                  • fredo6F
                    NEW RELEASE: LordOfTheToolbars v1.6b - 06 Jan 22
                    Requirements
                    • LibFredo6: v12.3a or above
                    LordOfTheToolbars 1.6b includes
                    • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Vignette Stripe to the Sketchup Window (default is enabled).
                    Home Page of LordOfTheToolbars for information and Download.
                    Main post of this LordOfTheToolbars thread.
                    • H
                      haymaker
                      Hey.
                      Great customer service.
                      I have updated LOTT to 6b but the problem persists. The vignette strip and the favourite pallets that I have made are stuck on the main laptop screen. I also have the problem that whenever I enter text into a dialogue box then the shortcut keys are activated. For example when I make a component with the name 'nog' as soon as I type O the Edit pallet opens up.
                      I have disabled all my other extensions but it makes no difference. Could this be an installation error. If delete the LOTT extension and reinstall it will I lose all my pallets and shortcuts.
                      Thank you for your help so far. I am really looking forward to getting this sorted as your plugin will improve my workflow.
                      Mike
                      • fredo6F
                        Did you disable the stickiness of the Vignette Stripe in the Default Parameters?
                        For palettes, they are sticky. So I will make an option to release stickiness for them.
                        Good catch. I will fix that.
                        • H
                          haymaker
                          Error message on install
                          Hey
                          I deleted LOTT. I reinstalled it and have attached a screenshot of the error that showed up. I continued with the install and have the same issues. I am not sure if this error has anything to do with the problems I have or not.
                          Mike
                          • H
                            haymaker
                            Sure did, problem still persists, I can work around it by going into windows display settings and making my external screen the main screen however this seems to cause problems, mainly that if I try and open the Preferences or Model info then SU freezes?? So not really an option..
                            Cheers
                            Mike
                            • fredo6F
                              Cheers
                              Mike
                              I sent you a PM for the multiple issues you have
                              • fredo6F
                                NEW RELEASE: LordOfTheToolbars v1.6c - 08 Jan 22
                                Requirements
                                LordOfTheToolbars 1.6c includes
                                • Bug fixing for palette and personal commands shortcuts
                                • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Palettes to the Sketchup Window (default is enabled).
                                  arnestein
                                  Started to look at this very rich looking extension - via SketchupEssentials video.
                                  I have the issue of the main "palette" (Vignette stripe?) not showing up in the Sketchup main window bar - but rather at the top of the screen - See image.
                                  I tried the setting: "Palettes are sticky to the Sketchup window" - still stays on top of screen.
                                  Advice ?
                                  The problem
                                  • fredo6F
                                    For clarification
                                    • Stickiness means that the palettes or Vignette Stripe follow move when the Sketchup window is moved. But you decide where to position them manually
                                    • There are separate stickiness options for the Vignette Stripe and for palettes
                                      arnestein
                                      I got the Vignette stripe to move with the SU window now, thanks.
                                      However, I had do both activate the "Vignette Stripe is sticky" option and then manually move it somewhere over the Sketchup window.
                                      If I did not move it manually somewhere over the Sketchup window, the Vignette option just stayed in one place, even when I moved the SU window.
                                      For me, good enough ☀ !
                                      • fredo6F
                                        NEW RELEASE: LordOfTheToolbars v1.7a - 09 Jan 22
                                        Requirements
                                        • LibFredo6: v12.4a or above
                                        LordOfTheToolbars 1.7a includes
                                        • Bug fixing for list of shortcuts dialog
                                        • Bug fixing for appearance of palettes when never displayed.
                                        • G
                                          greatoe
                                          Hi Fredo, I'm having problem trying this plugin on a M1 chipset Apple MacBook Pro.
                                          I'm on SketchUp Pro 2021 on 16" MacBook Pro with Apple M1 Max running macOS Monterey. And LordOfTheToolbars is not running properly. All other plugins by Fredo is fine, including FredoCorner and JointPushPull. Only when SIP is disabled, LordOfTheToolbars will run without issue.
                                          Will try to make some screenshots later.
                                          • cmeedC
                                            cmeed
                                            Hi Fredo
                                            Thank you for all the time you put into these plugins! legend!!
                                            I've attached a little video of my problem with Palette line breaks, copying of icons and deleting them
                                            I'd guess this is not expected behaviour? or Have i go this completely wrong....
                                            All I'm trying to do is create a few rows of plugins, I also am attempting to move them about to suit my needs.
