    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 726.0k Views 99 Watching
      arnestein
      Started to look at this very rich looking extension - via SketchupEssentials video.
      I have the issue of the main "palette" (Vignette stripe?) not showing up in the Sketchup main window bar - but rather at the top of the screen - See image.
      I tried the setting: "Palettes are sticky to the Sketchup window" - still stays on top of screen.
      Advice ?
      The problem
      • fredo6F
        For clarification
        • Stickiness means that the palettes or Vignette Stripe follow move when the Sketchup window is moved. But you decide where to position them manually
        • There are separate stickiness options for the Vignette Stripe and for palettes
          arnestein
          I got the Vignette stripe to move with the SU window now, thanks.
          However, I had do both activate the "Vignette Stripe is sticky" option and then manually move it somewhere over the Sketchup window.
          If I did not move it manually somewhere over the Sketchup window, the Vignette option just stayed in one place, even when I moved the SU window.
          For me, good enough β˜€ !
          • fredo6F
            NEW RELEASE: LordOfTheToolbars v1.7a - 09 Jan 22
            Requirements
            • LibFredo6: v12.4a or above
            LordOfTheToolbars 1.7a includes
            • Bug fixing for palette and personal commands shortcuts
            • Bug fixing for list of shortcuts dialog
            • Bug fixing for appearance of palettes when never displayed.
            Home Page of LordOfTheToolbars for information and Download.
            Main post of this LordOfTheToolbars thread.
            • G
              greatoe
              Hi Fredo, I'm having problem trying this plugin on a M1 chipset Apple MacBook Pro.
              I'm on SketchUp Pro 2021 on 16" MacBook Pro with Apple M1 Max running macOS Monterey. And LordOfTheToolbars is not running properly. All other plugins by Fredo is fine, including FredoCorner and JointPushPull. Only when SIP is disabled, LordOfTheToolbars will run without issue.
              Will try to make some screenshots later.
              • cmeedC
                cmeed
                Hi Fredo
                Thank you for all the time you put into these plugins! legend!!
                I've attached a little video of my problem with Palette line breaks, copying of icons and deleting them
                I'd guess this is not expected behaviour? or Have i go this completely wrong....
                All I'm trying to do is create a few rows of plugins, I also am attempting to move them about to suit my needs.
                  rv1974
                  @cmeed the plugin needs extra polishing. From my experience you should start a new empty file, make all the desired changes in lott toolbars and restart SU afterwards.
                  Trying to make changes in the middle of long editing of complex files might be too buggy.
                  • cmeedC
                    cmeed
                    WIP! πŸ˜„
                    I was going for a big palette with lots of icons I'll have to plan a bit better and maybe use more palettes with reduced amounts in
                    C
                    • fredo6F
                      NEW RELEASE: LordOfTheToolbars v1.8a - 31 Jan 22
                      Requirements
                      LordOfTheToolbars 1.8a includes
                      • Bug fixing for ghosted icons (appearing grayed-out, although they are installed)
                      • Bug fixing for blocking of UI right after import (specific SU2022)
                      • Bug fixing for line-breaks and insertion of icons in palettes.
                      • fredo6F
                        The problems when inserting and deleting icons and line-breaks should be fixed in LOTT v1.8a.
                        • fredo6F
                          @aismebel said:
                          With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
                          These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
                          Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
                          Very inconvenient (Icons constantly fly off from the places where I installed them (
                          Could you first confirm which SU version you have (SU2018?).
                          Then be more precise on the problem. And could you keep the Ruby console opened when dealing with LOTT, in case there are some error messages displayed.
                          I would also recommend that you upgrade to LOTT V1.8a just published.
                            AISmebel
                            Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
                            https://youtu.be/EWKnFRXS1NE
                              AISmebel
                              Now I use SU 2020. The plugin version is the latest and I update it regularly as soon as a new version appears.
                              Reinstalling the plugin didn't help.
                              • fredo6F
                                If you do not see the Vignette Stripe at start up, it maybe be stuck off-screen (I guess you have multiple monitors).
                                Could you go to the menu Tools > Fredo6 Collection > LordOfTheToolbars > Reset the Vignette Stripe position.
                                  AISmebel
                                  I made a screen recording with another program.
                                  https://youtu.be/e6jSXIc9Dvo
                                  Reset the Vignette Stripe position did not help me 😞
                                  • fredo6F
                                    Could you display the Vignette Stripe? (go to menu Tools > Fredo6 Collection > LordOfTheToolbars > Toggle Visibility of the Vignette Stripe)
                                      AISmebel
                                      Hello. The plugin itself works correctly. It just doesn't load icons.
                                      Yesterday I installed SketchUp 2022. I installed fresh LordOfTheToolbars for it. Problem still exists. So it's not in the plugin itself and not in SU. Maybe the problem is on my PC. Could this happen?
                                      • fredo6F
                                        You seem to have 2 problems
                                        1. The Vignette Stripe does not display
                                        2. The custom toolbars are not showing at startup, but later on
                                        I don't have an explanation for that. I will probably need to send you a special version with traces to find out what is the problem.
                                        In the meantime, could you
                                        • Open the Ruby console
                                        • Close Sketchup with the Ruby console opened
                                        • restart Sketchup
                                        • Check if some errors appear in the Ruby console
                                          AISmebel
                                          1. The custom toolbars are not showing at startup, but later on
                                          • restart Sketchup
                                          "Add help menu!"
                                          "create new"
                                          "created"
                                          #Sketchup::Menu:0x0000023c232015f0
                                          This inscription appeared a minute after the launch of SU. And after I opened the console on my own.
                                          Ruby console didn't open automatically!
                                          • fredo6F
                                            Is this something happening only in SU2022.?
                                            • 27
                                            • 28
                                            • 8 / 28
