    Select Only Solids
    22 Posts 7 Posters 4.5k Views 7 Watching
      Here's a one-liner... Copy+Paste in the Ruby Console + <enter>
      This highlights all solids in the selection.
      s=Sketchup.active_model.selection;a=s.to_a;s.clear;s.add(a.grep(Sketchup;;ComponentInstance)+a.grep(Sketchup;;Group).select{|i|i.manifold?})
      This highlights all solids in the active_entities context.
      m=Sketchup.active_model;s=m.selection;s.clear;s.add(m.active_entities.grep(Sketchup;;ComponentInstance)+a.grep(Sketchup;;Group).select{|i|i.manifold?})
        KrisM
        slbaumgartner & TIG,
        Thanks for your help. A few problems.
        My procedure -
        Select all entities (84 entities total, 7 non solid components, 1 line, rest are solid groups and components.
        Run script.
        slbaumgartner - I get an error message
        Error: <main>:9: syntax error, unexpected keyword_end, expecting '}'
        ย  ย  ย  end ^
        SketchUp:1:in `eval'
        TIG -
        First script - Get 83 Components/Groups in Entity Info box, the 1 line is deselectd, the 7 non solids are still selected.
        2nd script - Get 84 Components/Groups in Entity Info box, which is weird since the 1 line looks like it is deselectd, the 7 non solids are still selected.
        Solid Test1.zip
          slbaumgartner
          That sounds like a cut-and-paste error, as the code worked without that error on my system. The attached Ruby has that method and also the inverse one that selects all solids.
          all_but_solids.rb
            KrisM
            Feeling kind of dumb here. Put the ruby in the plugin folder but cannot for the life of me find where to use it from?
              KrisM
              Also tried opening the ruby in Notepad and Notepad++, copying and pasting into the Ruby console. Nothing happens. I am obviously missing something.
                Jim
                I found myself frequently turning to the Ruby Console for making anything more than simple selections.
                So I made a sel command, and now in the Ruby Console I can type things like:
                sel ;all
                sel ;edges
                sel ;faces
                sel ;groups
                sel 0 [or ;none or ;clear]
                sel ;cons
                sel ;invert
                etc.
                Quite efficient. It's too hackish to share at the moment. I'll try to remember to fix it up and post it.
                  slbaumgartner
                  It was a quick hack, not really a plugin. If you put it into the plugins folder, try opening the Ruby Console and typing SLBTest::all_but_solids or SLBTest::only_solids.
                    KrisM
                    Great. Works like a charm. Thanks very much.
                    • E Offline
                      Einstein
                      Hello, TIG,
                      I know this thread is old, but the problem hasn't been completely solved.
                      Thank you for the script you provided. It works well with groups, but doesn't take components into account. When I run it on a selection, it will filter solids among groups, but not components. All preselected components will stay selected, no matter whether they're solid or not.
                      Tested on SketchUp 2021.
                      I would love to have a plugin that would consider both groups and components and could be launched from Extensions menu. Do you think you could do that?
                        The simple code snippets should select any component_instances AND groups which are solids...
                        Please post an example of how it doesn't work...
                        • E Offline
                          Einstein
                          I have prepared an example model with:
                          1 solid group
                          1 non-solid group
                          1 solid component
                          1 non-solid component
                          In this model your second script selected both components, regardless of their solid state, leaving both groups unselected.
                          Your first script has removed the non-solid group from selection (I preselected all entities), but didn't filter components at all.
                          So none of the scripts worked 100% as expected.
                          solid entity selection - example.skp
                            There was a typo in my code - to select all solids in the active entities context use this fixed version...
                            m=Sketchup.active_model;s=m.selection;s.clear;a=m.active_entities;s.add(a.grep(Sketchup;;ComponentInstance)+a.grep(Sketchup;;Group).select{|i|i.manifold?})
                            The other one, to select only solid components/groups in a selection, works OK...
                            • E Offline
                              Einstein
                              That's strange.
                              In my case, your new code still only filters groups. No components are affected.
                              Do you think that some plugin could interfere with it?
                              • E Offline
                                Einstein
                                I also tested it in SU 2020, where I only have a few basic plugins enabled.
                                I get the same wrong outcome.
                                  You are right !
                                  Another typo - misplaced (...)
                                  Here's a working version [I hope!] to select all solids in the model [active-entities]
                                  m=Sketchup.active_model;s=m.selection;s.clear;a=m.active_entities;s.add((a.grep(Sketchup;;ComponentInstance)+a.grep(Sketchup;;Group)).select{|i|i.manifold?})
                                  • E Offline
                                    Einstein
                                    This one is working, great! ๐Ÿ˜„
                                    I appreciate your help.
                                    • 2 / 2
